    Bitmap Distortion Shader Example Questiosn
    2 Posts 0 Posters 209 Views
      On 21/03/2013 at 15:06, xxxxxxxx wrote:
      Cinema 4D Version:   13
      Platform:    Mac  ;
      Hello all, back with a couple more question, this time about the Bitmap Distortion Shader.
      I've been experimenting with it and I've found some things that I don't understand.
      Does ShaderData::Output() browse through the points in any specific order?  From the print tests I've done it seems to be essentially random.
      How would I find adjacent points to the current cd->p point?  And what defines a point?  They don't seem to be evenly spaced or anything from what I can tell.
      Thanks for any possible help.
      Dan
        On 21/03/2013 at 18:21, xxxxxxxx wrote:
        as nobody is answering here, i just drop two things.
        1. ChannelData coordinates are in UVW space. you could theoretically sample neighbouring
        areas by calling output just with a modified ChannelData.uVW value. getting the sample for
        neighbouring pixels can be quite complicated i guess (as you would have to do the raytracing).
        2. the samples are not evenly spaced due to projection a mesh curvature. for a planar
        surface with an orthgonal frontal projection output should e called in evenly spreaded steps.
