    escape / un-escaping strings
    5 Posts 0 Posters 506 Views
      On 12/03/2013 at 08:59, xxxxxxxx wrote:
      Hi, I'm not sure if my title is accurate enough.
      But, I'm thinking about having a User Data entry field where I can copy / paste the Python ID for certain object parameters (none specific), and then use that in a custom effector to alter that parameter.
      So, I'm not sure if there's a simple way to translate the string. I've been looking at other ways to escape / un-escape strings in Python, but everything I've seen so far is more complicated than calling something like eval('stringToEval')
      I will continue to search, but thought I'd post here in the mean time.
      Jim
        On 12/03/2013 at 09:44, xxxxxxxx wrote:
        simply use eval.
        print obj[eval('c4d.{0}'.format(obj[c4d.ID_USERDATA,1]))]
        edit : and before someone starts complaining, yeah it is pretty sloppy and unsafe, so you
        might want to add some fallbacks and double checks.
          On 12/03/2013 at 09:48, xxxxxxxx wrote:
          Thanks ferdinand.
          I was just about to post that I got it to work 😊
          My approach seems a bit different than yours though.
          p   = op[c4d.ID_USERDATA,4]
          obj[eval(p)] = <some value>
            On 12/03/2013 at 09:49, xxxxxxxx wrote:
            I do not recommend the eval function. See this excellent blog post why.
            Better use getattr:
            try:
                val = getattr(c4d, obj[c4d.ID_USERDATA, 1])
            except AttributeError:
                pass
            -Niklas
              On 12/03/2013 at 10:01, xxxxxxxx wrote:
              Niklas,
              Ouch. That article sure makes eval() scary.
              I will take your suggestions.
              Thank you,
              Jim
