    Adding and managing documents Layers
    4 Posts 0 Posters 423 Views
      On 11/03/2013 at 07:36, xxxxxxxx wrote:
      Hi everyone !
      I did a little search here and on cgtalk but couldn't find anything about the subject, and the sdk is still cryptic for me sometimes..
      Is there a way to create/delete a layer, set its name, add objects to it and so on ?
      I thought I can solve with this: http://chicagoc4d.com/C4DPythonSDK/modules/c4d.documents/LayerObject/index.html#c4d.documents.LayerObject
      but evidently I didn't understood how it works.
      Basically what I would like to do is a script that creates a new layer, sets its name to something, and add selected objects to it. I'm ok (i think) with adding objects to the layer, but i can't figure how to add the layer itself.
      Any advice, example or reference I can check would be great !
      Massimiliano
        On 11/03/2013 at 08:06, xxxxxxxx wrote:
        Hi Massimiliano,
        Methods dealing with layers are exposed in several classes: LayerObject, BaseDocument and BaseList2D.
        Here's a commented code snippet showing how to deal with layers:
            # Create a new layer
            layer = c4d.documents.LayerObject()
            # Set layer name (Calls C4DAtom.SetName())
            layer.SetName("New Layer")
            # Assign the active object to the newly created layer
            # (Calls BaseList2D.SetLayerObject())
            if op is not None:
                op.SetLayerObject(layer)
            # Get the invisible root layer
            layerRoot = doc.GetLayerObjectRoot()
            # Insert the layer under the root
            layer.InsertUnder(layerRoot)
          On 11/03/2013 at 08:26, xxxxxxxx wrote:
          wow, that was fast 🙂 Thanks a lot Yannick.
          I wrongly interpreted a layer as an object "attribute" instead of an object itself, it makes more sense now 🙂
          massimiliano
            On 11/03/2013 at 08:44, xxxxxxxx wrote:
            Yes, a layer is an entity inside CINEMA, not just an attribute or parameter.
            LayerObject (representation of a layer) inherits BaseList2D: C4DAtom->GeListNode->BaseList2D->LayerObject.
            I'll improve layers documentation because this isn't obvious.
