    Turn Off UNDOs?
    20 Posts 0 Posters 1.8k Views
      On 13/03/2013 at 12:14, xxxxxxxx wrote:
      GeDynamicArray.FreeArray() to free the memory of the array.
      You shouldn't have to ever free the GeDynamicArray itself!
        On 13/03/2013 at 13:23, xxxxxxxx wrote:
        OK. Thanks Robert.
        Even after using that in the destructor. I'm still getting leaks.
        If I free bitmaps after using them throught my code I can get rid of the leaks. But that messes up the way the plugin works.
        Images don't get created, updated, saved, etc.
        I didn't think about checking for memory leaks until I had written the entire plugin.
        That was a big mistake. Now I'm paying the price.
          On 13/03/2013 at 14:40, xxxxxxxx wrote:
          Best thing to do is remove (comment out) things one section at a time and see where the leaks stop occurring. If you can, start at the stuff that runs latest and work your way back.
            On 13/03/2013 at 15:04, xxxxxxxx wrote:
            Yeah. I've been trying to do that. But it's hard to debug because I used so much dynamic creation stuff in it.
            I think I'll have to start over and create a simpler version without the tree GUI and all the fancy dynamic stuff to figure out why the memory is leaking.
            If I don't kill myself first.😉
            What a total nightmare this project has been. Like pulling an elephant through a peephole.😂
            Thanks for being patient with me and helping me with it.
              On 14/03/2013 at 12:27, xxxxxxxx wrote:
              Yannick,
              I tried to use: doc->AddUndo(UNDOTYPE_CHANGE_SMALL, tag);
              But I can't figure out where to use this. Because what I'm doing is so unusual.
              I'm not trying to stop added tags from being deleted during an undo operation.
              I'm trying to prevent my dynamically created bitmap buttons from getting deleted from the GeDialog.
              The existence of those buttons are tied to an array in the tag's hyperfile.
              The AsyncTest SDK example uses a variable called "row" to control the dynamically generated gizmos. But I'm using an array stored in the tag's hyperfile to do the same kind of thing.
              What seems to be happening is that when an Undo operation is executed in C4D. One of the things it does is delete existing data from a tag's hyperfile. At least that's what looks like is  happening.
              When the Undo occurs. The tag's hyperfile appears to be getting cleared, along with my array data. Which then has the final result of deleting my Bitmap buttons on the GeDialog.
              I've never seen anyone use the hyperfile system so extensive like I'm using it.
              So this could just be a case of trying to do things with it that it was never meant to handle.
                On 14/03/2013 at 14:01, xxxxxxxx wrote:
                You may need to implement CopyTo() if you haven't already.  Whenever an undo is stored, Init() and CopyTo() (among other things) are called.  When an undo is undone, Init() and CopyTo() are called.  With CopyTo(), you need to duplicate any relevant data that isn't stored directly in the object's BaseContainer (DataInstance).
                It could be that when an undo is undone (Ctrl-Z), your bitmap array is not being recreated (or it was not stored in the undo in the first place), therefore you lose that data when undone.
                  On 14/03/2013 at 15:12, xxxxxxxx wrote:
                  Ok. I'll give it a try Robert.
                  I'm not very clear on how CopyTo() works. Your code is the only example I have on it. But I'll give it try.
                  BTW: I found where my memory leak was coming from.
                  It's coming from a function I was using to render the images
                  BaseBitmap *RenderDocument(BaseDocument *doc, LONG width, LONG height, Bool activeOnly)
                    if (!doc) return NULL;
                    BaseObject *bg = BaseObject::Alloc(Obackground);                             //Create a background object
                    doc->InsertObject(bg, NULL, NULL);                                           //Add it to the OM
                    bg->SetBit(BIT_ACTIVE);                                                      //Background object needs to be selected to work with the RenderActive option
                    bg->SetParameter(ID_BASEOBJECT_USECOLOR, 2, DESCFLAGS_SET_0);                //Set the use color option to ON
                    bg->SetParameter(ID_BASEOBJECT_COLOR, Vector(.32,.32, .32), DESCFLAGS_SET_0); //Set the color for the background
                    BaseBitmap *bmp = BaseBitmap::Alloc();
                    if (!bmp) return NULL;
                    bmp->Init(width, height);
                    RenderData *renderData = doc->GetActiveRenderData();
                    if(activeOnly) renderData->SetParameter(RDATA_ACTIVEOBJECTONLY, TRUE, DESCFLAGS_SET_0);
                    else renderData->SetParameter(RDATA_ACTIVEOBJECTONLY, FALSE, DESCFLAGS_SET_0);
                    BaseContainer container = renderData->GetData();
                    container.SetLong(RDATA_XRES, width);
                    container.SetLong(RDATA_YRES, height);
                    container.SetLong(RDATA_RENDERENGINE, RDATA_RENDERENGINE_STANDARD);
                    RenderDocument(doc, container, NULL, NULL, bmp, RENDERFLAGS_EXTERNAL, NULL);
                    bg->Remove();
                    BaseObject::Free(bg);
                    return bmp;
                  This function gets called every time a new image is created.
                  And I think what was happening is every time it executed. A new Alloc was created but never freed.
                  I tried using BaseBitmap::Free(bmp) at the end of it. But it crashes.
                  I'm still trying to find a solution to freeing this code properly. I'm a newb at handling memory.
                    On 14/03/2013 at 15:26, xxxxxxxx wrote:
                    1. If your bmp allocation fails, you never free bg.
                    2. If you are returning the bmp to replace one that has already been allocated and stored in your tag, then, yes, you will need to free the old one before allocating a new one to replace it.  One way to do this safely would be to return the bmp to a local variable in the method calling RenderDocument() and if it is not null and the one being replaced is not null then free the one being replaced and set the pointer to the one returned and stored in the local variable.  Think of it as a swap sort of.
                      On 17/03/2013 at 10:05, xxxxxxxx wrote:
                      I'm trying to figure out how to use the CopyTo() method. But the docs only show how to copy a simple variable. Nothing as complex as bitmaps and arrays.
                      This is what I've got so far.
                      It doesn't crash. But it also doesn't solve my Undo problem. I have no idea if I'm doing this right because the docs don't show how to handle bitmaps and arrays.
                      I think I might be saving the array images to the tag. But not re-saving them back to the array?
                      class StorageTag : public TagData
                        INSTANCEOF(StorageTag,TagData)
                            BaseBitmap *render;                      //<--The images that get saved into the images array
                            BaseBitmap *dbm;                         //<--The bitmap used to transfer the images in the array to the tag
                            LONG imagecount;
                            GeDynamicArray<BaseBitmap *> images;     //<--This is the array of images I want to CopyTo() the tag
                            StorageTag();
                            ~StorageTag();
                            Bool Read(GeListNode* node, HyperFile* file, LONG level);
                            Bool Write(GeListNode* node, HyperFile* file);
                            virtual Bool CopyTo(NodeData* dest, GeListNode* snode, GeListNode* dnode, COPYFLAGS flags, AliasTrans* trn);
                            virtual Bool Message(GeListNode *node, LONG type, void *t_data);
                            virtual EXECUTIONRESULT Execute(BaseTag *tag, BaseDocument *doc, BaseObject *op, BaseThread *bt, LONG priority, EXECUTIONFLAGS flags);
                            static NodeData *Alloc(void) { return gNew StorageTag; }
                      Bool StorageTag::CopyTo(NodeData* dest, GeListNode* snode, GeListNode* dnode, COPYFLAGS flags, AliasTrans* trn)
                        StorageTag *dtag = (StorageTag* )dest;
                        if (!dtag) return FALSE;
                        dtag->imagecount = imagecount;           //This works OK
                        //dtag->render = render;                 //Crashes!!!
                        //dtag->images = images;                 //Crashes!!!
                        dbm = BaseBitmap::Alloc();               //This works OK
                        //render->CopyTo(dbm);                   //Crashes!!!
                        //dtag->render = dbm;
                        for(LONG i=0; i<images.GetCount(); i++)
                            images[i]->CopyTo(dbm);              //<----This doesn't crash...But it doesn't fix my Undo problem either
                      I need more information how to use the CopyTo() method with an array filled with bitmaps.
                      Please and thank you.
                          // You can't do this - you need copies, not just pointing to the originals!
                          // could it be that render has not been allocated yet?
                          if (render)
                              // Only one bitmap has been allocated!  Corrected in for loop
                              if (!dbm)    return FALSE;
                              // Not sure if this is necessary but check it
                              dbm->Init(render->GetBw(), render->GetBh);
                              dtag->render = dbm;
                          else GePrint("StorageTag.CopyTo.render == NULL");
                              dbm->Init(images[i]->GetBw(), images[i]->GetBh);
                              // Might need a cast here (??), try it without but keep in mind
                              static_cast<BaseBitmap*>(images[i])->CopyTo(dbm);              //<----This doesn't crash...But it doesn't fix my Undo problem either
                              // the [] operator for GeDynamicArray is for access only.  Not sure if you can set to it.  Push() and Insert() exist for this purpose
                              dtag->images.Push(dbm);
                          On 17/03/2013 at 11:28, xxxxxxxx wrote:
                          It works!!!
                          I got compile errors for the Init() code parts. So I just commented them out and it seems to work fine without them.
                          I can't thank you enough for all your help Robert.🍺
                          You should be working for Maxon.
