    Create Shader Not Rendering
    4 Posts 0 Posters 431 Views
      On 05/03/2013 at 15:45, xxxxxxxx wrote:
      I have a problem where I have code that creates a shader and loads a file into the color and alpha channel and activates the alpha channel, but then nothing will render in either the viewport or the Picture Viewer. If I disable the alpha I can render again, but I dont know why I can render with both? Any ideas? Thanks!
      Using R14 Studio
      from c4d import documents
                      #replace with your path
                      file = "/Volumes/Textures/Leaves/Leaf1.tif"
                      def insertobj() :
                          obj = c4d.BaseObject(c4d.Oplane)
                          doc.InsertObject(obj)
                      mat = c4d.BaseMaterial(c4d.Mmaterial)
                      sha = c4d.BaseList2D(c4d.Xbitmap)
                      sha[c4d.BITMAPSHADER_FILENAME]  = file
                      mat.InsertShader( sha )
                      mat[c4d.MATERIAL_COLOR_SHADER]  = sha
                      mat[c4d.MATERIAL_USE_ALPHA]=True
                      mat[c4d.MATERIAL_ALPHA_SHADER]  = sha
                      mat.Message( c4d.MSG_UPDATE )
                      mat.Update( True, True )
                      doc.InsertMaterial( mat )
                      insertobj()
                      mat = doc.SearchMaterial("Mat")
                      obj = doc.SearchObject("Plane")
                      doc.SetActiveObject(obj)
                      doc.SetActiveMaterial(mat)
                      c4d.CallCommand(12169);
        On 05/03/2013 at 16:18, xxxxxxxx wrote:
        you cannot assign the same instance of a shader to multiple channels. that is a limitation of
        the c4d material system. you have to create a copy first.
        mat[c4d.MATERIAL_ALPHA_SHADER] = sha.GetClone()
        edit : note that you might run into more problems, when you try to copy more complex
        shader setups this way, due to the unpredictable way c4d.c4datom.getclone() works.
        copying shaders which contain object (instance) references themselves will not always
        return the expected results.
          On 06/03/2013 at 07:22, xxxxxxxx wrote:
          The shader also has to be inserted into the material's shader-list. Use BaseMaterial.InsertShader()
          for this. This has to be done for every single clone of the shader as well. Do not invoke it twice
          per shader.
          Best,
          -Niklas
            On 06/03/2013 at 08:18, xxxxxxxx wrote:
            Thanks for your responses, that makes sense. However, when add the .GetClone() on the end it doesn't load the image into the alpha for me? was there more that has to be done?
            I tried what Niklas said about inserting the shader again with something like this:
            mat.InsertShader( sha.GetClone() )
            Edit: ok I got it, I think it was a newb thing. I assigned the sha.GetClone to variable first then it worked. Thanks again guys!
            sha2 = sha.GetClone()
            mat[c4d.MATERIAL_ALPHA_SHADER] = sha2
            mat.InsertShader( sha2 )
