    Mass-spring system updating
    4 Posts 0 Posters 478 Views
      On 25/02/2013 at 02:22, xxxxxxxx wrote:
      Cinema 4D Version:   R12
      In order to perform some soft-body deformations using a deformer object, I want to use a mass-spring system applied to the vertices and edges of the polygonized mesh sent to ModifyObject().  My problem is that I definitely do not want to create the mass-spring system every time ModifyObject() is called but only initially and when there are changes to the object being deformed that might require a rebuild of the system.  Would GetDirty(DIRTYFLAGS_DATA) be enough?  What if the user edits the mesh in some way (for already polygon objects)?  What messages might I be looking for in my deformer object from its 'parent' (if any)?
        On 28/02/2013 at 12:43, xxxxxxxx wrote:
        No one?  I had an inkling that checking for DIRTYFLAGS_DATA in ModifyObject() wouldn't work.  It updates the system constantly because it is always dirty.  It only needs to be done if the user changes some property or the mesh - really, not just to kick in ModifyObject().
        Any takers?
          On 28/02/2013 at 14:01, xxxxxxxx wrote:
          Alrighty, then.  After a bit of experimentation, this works the best.  I provide this to alleviate the suffering of others in the future. 🙂
          Note: the mass-spring system is created/recreated in ModifyObject() only because I get a ready-made polygon object.
          // ObjectData.CheckDirty
          void DeformerObj::CheckDirty(BaseObject* op, BaseDocument* doc)
            if (!doc)                        return;
            if (!op)                        return;
            // Check Deformed object
            BaseObject*        dop =            op->GetUp();
            if (dop)
                ULONG        dd =            dop->GetDirty(DIRTYFLAGS_MATRIX|DIRTYFLAGS_DATA);
                if (dd != dDirty)
                    dDirty =    dd;
                    op->SetDirty(DIRTYFLAGS_DATA);
                    // A data change constitutes a need to recreate Mass-Spring System
                    needInitMassSpring =    TRUE;
                    return;
            // Check Collider object
            BaseContainer*    bc =            op->GetDataInstance();
            if (!bc)                        return;
            // - Get linked object
            BaseObject*        lop =            (BaseObject* )bc->GetLink(DEFORMER_OBJECT, doc, Obase);
            if (!lop)                        return;
            ULONG            dirtyness =        lop->GetDirty(DIRTYFLAGS_MATRIX|DIRTYFLAGS_DATA);
            // - Linked object is not dirty
            if (dirtyness == cDirty)        return;
            // - is dirty
            cDirty =                        dirtyness;
            On 01/03/2013 at 00:08, xxxxxxxx wrote:
            Hi Robert,
            Thanks for sharing the solution.
