    External Control (possibly Arduino)
    Scheduled Pinned Locked Moved General Discussion
    3 Posts 0 Posters 687 Views
      On 23/02/2013 at 07:22, xxxxxxxx wrote:
      Hi all,
      I'm just getting started with plugin development, and one idea i had was for an external controller handled by a plugin. Does the sdk have anyway of handling a serial port for example or even talking to a secondry piece of software that could read basic commands sent and trigger the 'callCommand' for example.
      The idea is to use a series of hardware buttons ect to control various buttons on the interface controlled by an arduino or something else plugged in via usb.
      I understand that there has been some success with using python and the pyserial module but was wondering if there was a starting point that someone could point out that I could start investigating / learning.
      Regards,
      Ian.
        On 26/02/2013 at 12:54, xxxxxxxx wrote:
        im pretty sure python and arduino work well together, as there is a library
        http://playground.arduino.cc/interfacing/python
        check it out.
        You can definitly import any library you want into c4d using python so i would start with this.
          On 02/03/2013 at 00:27, xxxxxxxx wrote:
          Hi thats great thanks, I had a play with python and can get serial communication so will continue to play. Thanks again
