    restructure project
    13 Posts 0 Posters 1.5k Views
      On 21/02/2013 at 01:02, xxxxxxxx wrote:
      OK Thanks to littledevil.
      But how can I solve the problem?
      I'm a try-and-error-Coder!
      Do you know anybody how can help me!
      (I would pay for the solution!)
      Thanks again
        On 21/02/2013 at 10:04, xxxxxxxx wrote:
        hm,
        there are multiple problems with your approach. here is how i would do it :
        http://codepad.org/DpEBjT7O
        i am taking a selection based approach, as this makes things a bit easier (and faster)
        and also adds the possibility to exclude objects from the process. simply select all objects
        manually or programmatically if you want to run it over the whole document.
        edit, the code, the codepad link won't last forever:
        # --- connect & delete all objects of the current selection, which have the same material
        # --- assigned to them. objects which have multiple materials assigend to them will be skipped.
        # --- objects with multiple material tags holding the same material will be connected.
            selection = doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_CHILDREN)
            dic = buildDict(selection)
            for key in dic:
                connect(dic[key])
        # --- connect & delete a object list
        def connect(objlist) :
            if len(objlist) > 1:
                for i in xrange(len(objlist)) :
                    if i == 0:
                        doc.SetActiveObject(objlist[i], c4d.SELECTION_NEW)
                        doc.SetActiveObject(objlist[i], c4d.SELECTION_ADD)
                c4d.CallCommand(16768)
        # --- get material used by this baseobjct. returns none for multiple materials.
        # --> BaseMaterial | None
        def getMaterial(obj) :
            material = None
            if isinstance(obj, c4d.BaseObject) :
                taglist  = obj.GetTags()
                for tag in taglist:
                    if tag.GetType() == c4d.Ttexture:
                        # single tag
                        if material == None:
                            material = tag.GetMaterial()
                        # multiple tags of the same material
                        elif material == tag.GetMaterial() :
                            pass
                        # multiple tags
                        else: return None
            return material
        # --- build a dict of all materials in the given selection. each key contains a list
        # --- with the objects which carry only this material in their texturetag(s).
        # --> dict
        def buildDict(selection) :
            result = {}
            for objA in selection:
                matA = getMaterial(objA)
                for objB in selection:
                    if objA is not objB:
                        matB = getMaterial(objB)
                        if matA == matB and matA and matB:
                            mkey = matA.GetName()
                            if mkey in result:
                                if objA not in result[mkey]:
                                    result[mkey].append(objA)
                                if objB not in result[mkey]:
                                    result[mkey].append(objB)
                                result[mkey] = []
            return result
        edit : using the material name as a dict key isn't really a brilliant idea, as it would merge
        different material objects with the same name into one object. you should change the
        dict key to a string repr of the material object ...  mkey = str(matA)
          On 22/02/2013 at 02:17, xxxxxxxx wrote:
          You are my Hero!!!
          BUT:
          My eyplanation of my problem wasn't exact enought:
          I wantet to change form this structure
          Würleh0 Material-1
          Würfel1 Material-2
          Würfel2 Material-1
          Würfel3 Material-3 #merge and the next
          Würfel4 Material-3        +
          Würfel14 Material-1 #merge and the next
          Würfel15 Material-1        +
          Null
          |-- Würfel4 Material-1
          |-- Würfel2 Material-2
          Null1
               |-- Würfel6 Material-2 #merge and the next
               |-- Würfel7 Material-2        +
               Null2
               | |-- Würfel8 Material-1
               |   |-- Würfel9 Material-2 #merge and the next
               |   |-- Würfel10 Material-2        +
               |-- Würfel11 Material-3 #merge and the next
               |-- Würfel12 Material-2          +
          to the folowing:
          Würleh0 Material-1
          Würfel1 Material-2
          Würfel2 Material-1
          Würfel3 Material-3 #merged objects
          Würfel14 Material-1 #merged objects
          Null
          Null1
               |-- Würfel6 Material-2 #merged objects
               Null2
               |   |-- Würfel9 Material-2 merged objects
               |-- Würfel11 Material-3 merged objects
          I uploaded the result-File here:
          http://www.vision4d.de/downloads/001%20Testscene%20klein%20-%20after%20restructure.c4d
          Mayby you can hlep me by this problem???
          Thanks a Lot lot lot lot............lot lot lot
            On 22/02/2013 at 05:49, xxxxxxxx wrote:
            ah ok, i thought this behaviour of your code was unintended. you could stick
            more ore less with orginal code, but instead of merging the objects from within
            your loop you would build up a result list. you could use the python tuple feature
            to make things easier.
            result = []
            if current_material == last_material:
            	result.append((last_object, current_object))
            for obja, objb in result:
            	merge(obja,objb)
              On 22/02/2013 at 06:27, xxxxxxxx wrote:
              Hi LittleDevil;
              It seams for me that it is very easy vor you to change the first code.
              What shall I change?
              Could you pleas make th changes?
              Thanks a lot
                On 22/02/2013 at 08:08, xxxxxxxx wrote:
                as your pm sounded kind of desperate, i did the work for you 😉 this does now exactly what you
                wanted it to do. for more you will have to dig yourself through python or hire someone as you suggested.
                    connectList(buildList())
                def buildList() :
                    result           = []
                    current_object   = doc.GetFirstObject()
                    last_object      = None
                    current_material = None
                    last_material    = None
                    while current_object:
                        current_material = getMaterial(current_object)
                        if current_material != None and last_object != None:
                        last_material = current_material
                        last_object   = current_object
                        current_object = walk(current_object)
                    return result
                def connectList(objlist) :
                    for objA, objB in objlist:
                        doc.SetActiveObject(objA, c4d.SELECTION_NEW)
                        doc.SetActiveObject(objB, c4d.SELECTION_ADD)
                    material = None
                        for tag in taglist:
                                    pass
                                else: return None
                    return material
                def walk(obj) :
                    if not obj: return
                    elif obj.GetDown() :
                        return obj.GetDown()
                    while obj.GetUp() and not obj.GetNext() :
                        obj = obj.GetUp()
                    return obj.GetNext()
                  On 23/02/2013 at 03:10, xxxxxxxx wrote:
                  Hello at all,
                  and first of all my thanks to littledevil.
                  The problem seams to be not as easy.
                  The code above works with the postetd (reducesd) testscene well!
                  But with my original scene not.
                  It analysed it and it seams for me that the varriable result[] looses informations. (I did a print result)
                  Here is a new testscene:
                  http://www.vision4d.de/downloads/002_Testscene_klein.c4d
                  For that I can help me by my own, I need help at the following problem:
                  I try to explane in words:
                  goto first objekt                                         (no problem)
                  step throug the scene                               (no problem)
                  test if the actual object is a null-objekt     (no problem)
                  if yes:                                                        (no problem)
                     is a part of the name is "wand"              Problem starts here!
                         if yes:
                         merge all polygonal objekts in this null-objekt with the same
                         material to one object
                  The problem for me ist to find "all" polygon-objekts in a null-object and merge them to one!!!
                  Because:
                  when I find two following to each other and mergin them, the aktual objekt is not the merged on.
                  So i'm loosing my aktual position in the project.
                  How can I merge them and than place my aktual objekt pointer to the mergesd on?
                  Thanks a lot to all good ideas.
                    On 23/02/2013 at 09:35, xxxxxxxx wrote:
                    1. finding a substring in a string is pretty asy in python. str.find will return the index of
                    the first occurance of the given substring. it will return -1 for no mtach.
                    'I am a string'.find('I am')
                    2. for changing the object count in the document and looping through the content - you
                    could use other methods, but the easiest approach would be to build up a list of objects
                    which have to be merged and do the merging after you have looped through all the objects.
                    like i did it in my examples.
                      On 24/02/2013 at 05:26, xxxxxxxx wrote:
                      @ ferdinand:
                      But why does your way stuggle with the biger scene I posted?
                      I looking for a way to build a list of all Polygonal objects listet in a Null-object whitch have the same material and combine them and then continue!.
                      The question is:
                      How could I store the next object to continue with this object after combining the collected objects?
                      Thanks a lot for your patience
                        On 24/02/2013 at 12:00, xxxxxxxx wrote:
                        ok, now I found the problem:
                        The code only works when:
                        not more than two objact following have the same material!!!
                        and:
                        when nor the first 2 objekts have the same material!!!
                        So, has anybody out there a idea how to bild the list for varriable amout of objekts with same material following to each other?
                        Thanks a lot!
                          On 25/02/2013 at 10:41, xxxxxxxx wrote:
                          you have just to build up a longer list instead of pairs, like in my first example. but as you do not
                          care for earlier occurances of sequences of the current material you do not have to use a dict, you
                          can just build up a list of lists.
                          def buildList() :
                              result           = []
                              templist         = []
                              last_object      = None
                                  if current_material != None:
                                      if current_material == last_material and last_object != None:
                                          templist.append((current_object))
                                          if len(templist) > 1:
                                              result.append(templist)
                                          templist = []
                                          templist.append(current_object)
                              return result
                              for sublist in objlist:
                                  for i in xrange(len(sublist)) :
                                      if i == 0: doc.SetActiveObject(sublist[i], c4d.SELECTION_NEW)
                                      else: doc.SetActiveObject(sublist[i], c4d.SELECTION_ADD)
                              material = None
                                  for tag in taglist:
                                              pass
                                          else: return None
                              return material
                          def walk(obj) :
                              if not obj: return
                                  obj = obj.GetUp()
