    Returning another class' function value
    61 Posts 0 Posters 63.4k Views
      On 18/02/2013 at 01:56, xxxxxxxx wrote:
      Hi Nik,
      just to clarify a few points for you:
      what's the sense of passing a string that is not used at all?
      the string is used in MyClass1 (which is actually a GeUserArea) but the userarea code is hundreds of lines long so I was a bit reluctant to paste all of that. The example I've been providing above is just a basic translated version of what I have.
      Are you calling Init() before MyString() ?
      As it's a user area, Init is called first. However the string is being updated/defined in a few other functions so it is in use elsewhere, and is for other purposes.
      You're also missing the return-type for the Init() method. Also note that a void parameter is
      deprecated for C++ and is used in C only.
      My mistake in translating things over. Needless to say the string (and the GeUserArea) all runs as expected, and the string variable is filled well before any call to the "MyString()" function is run. The issue seems to be if you get the function's string value from another variable - the string value (both the function's and the class level variable) are when passed to another class.
      WP.
        Sure.Here's a small example:
        class MyTag;                <-- In raw C++ this is how you tell the compiler to go get the MyTag class
                                        Problem: This works fine in raw C++. But not when doing it inside of a C4D plugin.
        class MyDialog : public GeDialog{
            public:        MyTag tag;           <--- Complier error: Undefined class!!?
                GeDialog Overrides
                Blah, blah, etc..
        class MyTag : public TagData{
            public:        MyDialog dlg;         <--- MyDialog has been seen by the compiler and works fine
                                           Note: This works fine in both raw C++ and in C4D plugins
                TagData Overrides
                Blah, blah, etc..
        this shouldn't work in a "raw C++" environment, either.
        That's a normal forward declaration, and it works. I use it all the time.
        To clarify, there is nothing like "CINEMA 4D C++". It's all the same. Standard compiler, standard language, just some custom classes and structs.
        No difference in language behavior whatsoever.
          On 18/02/2013 at 03:31, xxxxxxxx wrote:
          Hi Jack,
          the behaviour with the forward declaring seems to be different, as I get the same compiler error as Scott when forward declaring like that in a C4D plugin.
          WP.
            Hi Jack,
            WP.
            "In C++, classes can be forward-declared if you only need to use the pointer-to-that-class type (since all object pointers are the same size, and this is what the compiler cares about)."
            Can't use forwards declation with
            MyTag tag;
            It's just C++, guys. Nothing funny going on here at all.
              On 18/02/2013 at 04:29, xxxxxxxx wrote:
              Yes, that's right. The problem you get is usually because the compiler did not parse the classes definition
              at the point you want to access a member in the current translation unit. When you forward-declare a class
              from a header that does not define the class, you must at least include the header defining the class in the
              implementation file so the compiler knows about its definition when the class is used.
              -N
                Can you post a working example of bottom up class sharing then?
                Fused is correct about the pointer. I posted my example from memory. And I forgot to use a pointer to the bottom class's prototype in my example. It's been a while since I tried doing this and forgot about the pointer.
                But even if I do use a pointer to the bottom class's prototype. I still get an undefined class error when I try to actually use that pointer in my code.
                Again.
                In Raw C++ it's very common to do a bottom up type of sharing of a class to it's previous class.
                But in C4D plugins it's not something I can do at all. And apparently other people are having the same problem.
                We need to see a working example of bottom up class sharing.
                  On 18/02/2013 at 08:13, xxxxxxxx wrote:
                  Like this one ?
                      class SecondOne;
                      class FirstOne
                      	friend SecondOne;
                      	FirstOne(SecondOne &ref)
                      		: m_first_string("first_string")
                      		, m_ref_to_second(ref)
                      	void Print();
                      	void PrintSecond(SecondOne &ref);
                      private:
                      	String m_first_string;
                      	SecondOne	&m_ref_to_second;
                      class SecondOne
                      	friend FirstOne;
                      	SecondOne()
                      		: m_second_string("second_string")
                      		, m_first(*this)
                      	void Print() { GePrint(m_first.m_first_string); }
                      	void PrintFirst(FirstOne &ref);
                      private:
                      	String m_second_string;
                      	FirstOne	m_first;
                      void SecondOne::PrintFirst( FirstOne &ref )
                      	GePrint(ref.m_first_string);
                      void FirstOne::PrintSecond(SecondOne &ref)
                      	GePrint(ref.m_second_string);
                      void FirstOne::Print()
                      	GePrint(m_ref_to_second.m_second_string);
                    On 18/02/2013 at 08:27, xxxxxxxx wrote:
                    Doh!
                    I was going to edit my post to say that we need to see a working example of the bottom up class sharing. Using the existing SDK classes (tag, GeDialog, object, etc..). Not custom hand made classes.
                    But you were too quick Remo.🙂
                    I was wondering if maybe using generic custom classes to test this on isn't a good way to test this. Because custom classes don't have header files or inheritance in them the same as the built-in SDK classes.
                    So I'm wondering if the reason I'm getting undefined class errors is because of the way the built-in SDK classes are set up with their .h files and inheritance structures.
                    Do you happen to know if that code will also work for the built-in SDK classes Remo?
                    Have you tried this using two of the existing SDK classes?
                      On 18/02/2013 at 08:55, xxxxxxxx wrote:
                      Hm, do you mean ObjectData, TagData ?
                      The short answer is it is not allowed and make no sense.
                      C4D own all this stuff.
                      Of course you can still use pointers to it.
                      BaseObject [URL-REMOVED]*obj= BaseObject[URL-REMOVED]::Alloc(MY_PLUGIN_ID);
                      An the ObjectData is then inside of BaseObject.[URL-REMOVED]
                      This can be acceded using GetNodeData().
                        On 18/02/2013 at 09:50, xxxxxxxx wrote:
                        Then I'm right back to square one. Not being able to up share my tag's class members with a previous GeDialog's class.
                        Which is why I say that working in these C4D plugins is sometimes different than working in Raw C++.
                        Based on your post. It sounds like sharing two SDK classes is better done by allocation. And not by trying to break down the OOP class structure between them.
                        Since this has nothing to do with the OP. I better stop posting here and return control back to WickedP.
                        I apologize for hijacking your thread WP.
                        Thanks for the information guys. I'm always learning new things from you guys.
                          Then I'm right back to square one. Not being able to up share my tag's class members with a previous GeDialog's class.Which is why I say that working in these C4D plugins is sometimes different than working in Raw C++. Based
                          between them.Since this has nothing to do with the OP. I better stop posting here and return control back to WickedP.I apologize for hijacking your thread WP.Thanks for the information guys. I'm always learning new things from you guys.-ScottA
                          You can definitely do that (not easily across different plugins DLLs tho).
                          What you are missing is a cast.
                          And you also have to call GetNodeData() on the tag. You plugin tag is not derived from C4DAtom (like BaseTag) but from NodeData.
                          The NodeData is attached to the GeListNode (which is derived from C4DAtom ).
                          To safely get the pointer to your plugins node data from a BaseTag:
                          BaseTag* yourTag = BaseTag::Alloc(YOUR_PLUGIN_ID);//(where ever you may be getting it from, allocate?)
                          YourPluginClass* yourPlugin = NULL;
                          if(yourTag != NULL && yourTag->GetType() == YOUR_PLUGIN_ID)
                              yourPlugin = static_cast<YourPluginClass*>(yourTag->GetNodeData());
                          edit: fixed some stuff
                            On 18/02/2013 at 11:13, xxxxxxxx wrote:
                            Regarding forwards declaration of classes. You can only forwards declare them when all you do after forwards declaration is declaring a pointer. As soon as you access it, you need to include the header file.
                            Examples...
                            Wrong:
                            class BaseTag;
                            class class1
                                BaseTag* tag; // forwards declaration is fine, since we are just declaring the a pinter.
                                void doStuff()
                                    LONG type = tag->GetType(); // Compiler error. "Undefined class BaseTag". When using the pointer the compiler needs to know more about the class.
                            Right:
                            #include <c4d.h> // Inlcudes "c4d_basetag.h"
                            class class1
                                BaseTag* tag;
                                void doStuff()
                                    LONG type = tag->GetType(); // No compiler error. The compiler knows the class.
                              On 18/02/2013 at 12:58, xxxxxxxx wrote:
                              Thanks fused.
                              But I'm not sure how to write your casting code. I don't know what "YourPluginClass" supposed to be standing for?
                              Here's an example of a dialog class with a tag class below it. And trying to share one of the tag's class members with the GeDialog class above it:
                              #define DIALOG_PLUGIN_ID 1000001   //The GeDialog plugin's ID
                              #define TAG_PLUGIN_ID     1000002   //The Tag plugin's ID
                              //-------- The GeDialog plugin --------------------//
                                    MyDialog();
                                    BaseTag* tag;
                                    void doStuff()
                                        GePrint(LongToString(type));
                                    //GeDialog Overrides
                                    Bool CreateLayout();
                                    Bool InitValues();
                                    Bool Command(LONG id, const BaseContainer& data);
                                    Bool CoreMessage(LONG id, const BaseContainer& data);
                              MyDialog::MyDialog()  //The GeDialog's constructor
                                GeDialog();
                                tag = BaseTag::Alloc(TAG_PLUGIN_ID);
                                MyDialog* MyDialog = NULL;
                                if(tag != NULL && tag->GetType() == TAG_PLUGIN_ID)
                                    //yourPlugin = static_cast<YourPluginClass*>(tag->GetNodeData()); //<----Not sure how to write this..What does "YourPluginClass" stand for?
                                    MyDialog = static_cast<MyDialog*>(tag->GetNodeData());  //<-------wrong!
                                    MyDialog = static_cast<GeDialog*>(tag->GetNodeData());    //<-------wrong!
                              ... etc.
                              //-------- The tag plugin -------------------------//
                              class StorageTag : public TagData
                                    static NodeData* Alloc()
                                        return gNew StorageTag;
                                    LONG imagecount;         //<---I want to share this class member so I can use it inside the MyDialog class
                                    //Overrides
                                    StorageTag();
                                    Bool Init(GeListNode* node);
                                    void Free(GeListNode* node);
                                    Bool Read(GeListNode* node, HyperFile* file, LONG level);
                                    Bool Write(GeListNode* node, HyperFile* file);
                                    Bool Message(GeListNode* node, LONG id, void* msgData);
                              ...etc.
                                On 18/02/2013 at 13:14, xxxxxxxx wrote:
                                YourPluginClass stands for the class derived from NodeData (from which TagData, ObjectData, etc are dervied). In your example that would be StorageTag.
                                    StorageTag* MyTag = NULL;
                                        MyTag = static_cast<StorageTag*>(tag->GetNodeData());
                                  On 18/02/2013 at 13:33, xxxxxxxx wrote:
                                  Ok thanks.
                                  Fixed that. But still running into undeclared errors.
                                    GeDialog();
                                    StorageTag* MyTag = NULL;          //<------------ undeclared identifier :-(
                                    On 18/02/2013 at 13:42, xxxxxxxx wrote:
                                    You've missed the forward-declaration, then.
                                      On 18/02/2013 at 13:47, xxxxxxxx wrote:
                                      Oh, you need to declare StorageTag first and MyDialog.
                                      So:
                                      The other option would be to move each classes declaration/definition into it's own h/cpp files and have them the MyDialog file include/forwards declare the StorageTag (don't forget "#pragma once"/include guards).
                                        Forwards declaration will not work here unless he splits the class declaration and function definitions into h and cpp files (as the actual function definition is using the forwards declared class).
                                          On 18/02/2013 at 13:54, xxxxxxxx wrote:
                                          Moving the tag's class above the GeDialog class defeats the whole purpose of what I'm trying to do.🙂
                                          Sharing downwards is fairly simple.
                                          But sharing upwards is proving to be very, very difficult.
                                            Moving the tag's class above the GeDialog class defeats the whole purpose of what I'm trying to do.🙂Sharing downwards is fairly simple.But sharing upwards is proving to be very, very difficult.-ScottA
                                            edit: actually you *could* move MyDialog::MyDialog() below the declaration of StorageTag. Declare both classes first, then provide the implementations. But that would then sum up about all your available options.
                                            No it's not, what you are trying is simply impossible with c++ 😉
                                            Solution: One class, one .h and one .cpp file:
                                            MyDialog.h:
                                            #pragma once
                                            #include <c4d.h>
                                                    MyDialog();
                                                    BaseTag* tag;
                                                    void doStuff()
                                                    Bool InitValues();
                                            MyDialog.cpp:
                                            #include "MyDialog.h"
                                            #include "StorageTag.h" // Storage tag used, need to include
                                                GeDialog();
                                            //Register function here.
                                            ... etc.
                                            StorageTag.h:
                                            #pragma once
                                            #include <c4d.h>
                                                    static NodeData* Alloc();
                                                    //Overrides
                                                    StorageTag();
                                            StorageTag.cpp:
                                            NodeData* StorageTag::Alloc()
                                            ...etc.
