    MCOMMAND_SPLIT [not work]
    4 Posts 0 Posters 533 Views
      On 08/02/2013 at 10:11, xxxxxxxx wrote:
      Hi 🙂
      i have  this script for split polygon face:
      from c4d import utils
      settings = c4d.BaseContainer()
      res = utils.SendModelingCommand(command = c4d. **MCOMMAND_SPLIT** ,
                                      list = [op],
                                      mode = c4d.MODELINGCOMMANDMODE_POLYGONSELECTION,
                                      bc = settings,
                                      doc = doc)
      but not work...
      the new poygon is not created...  There is something that I entered wrong?
      Thanks!
        On 08/02/2013 at 10:58, xxxxxxxx wrote:
        what could help :
        create a copy both of your BaseDocument and your PolygonObject. Insert the poly copy into
        the copy of the BaseDocument and pass these two to SMC. Then insert the result into your
        active BaseDocment.
          On 08/02/2013 at 11:07, xxxxxxxx wrote:
          Try this:
          res = utils.SendModelingCommand(command = c4d.MCOMMAND_SPLIT,
                                          list = [op],
                                          bc = settings,
                                          doc = doc)
           **doc.InsertObject(res[0])**
            On 09/02/2013 at 01:57, xxxxxxxx wrote:
            ferdinand and NiklasR, Thanks for your help 👍 🍺
