    Problems with c4d.utils.Neighbor
    4 Posts 0 Posters 426 Views
      On 08/02/2013 at 08:57, xxxxxxxx wrote:
      Hi everyone,
      I want to convert an edge to a point selection and then get the corresponding neighboring polys.
      If I want to use the neighbor class it doesn't seem to work properly. If I try to initialize it the following way
          obj = doc.GetActiveObject()
          nb = c4d.utils.Neighbor
          nb.Init(obj,None)
          poly_a, poly_b = nb.GetEdgePolys(point_a,point_b)
      the console says:
      TypeError: descriptor 'Init' requires a 'c4d.utils.Neighbor' object but received a 'c4d.PolygonObject'
      Though the SDK clearly states that Init requires a PolygonObject and optionally a BaseSelect.
      What am I doing wrong here? Might be a stupid question, but I didn't use python for a long time in Cinema and the SDK always gives me headaches...
      Kind Regards
        On 08/02/2013 at 08:59, xxxxxxxx wrote:
        You did not instantiate the Neighbor class. You just assigned the class itself to a new variable.
        nb = c4d.utils.Neighbor()
        The reason for the error message is, that you can call the Init() function the procedural way, too:
        nb.Init(obj, None)
        # same as
        c4d.utils.Neighbor.Init(nb, obj, None)
          On 08/02/2013 at 10:50, xxxxxxxx wrote:
          you can also compute the indices for yourself.
          subindex = edge_index%4
          cpoly = obj.GetPolygon((edge_index - subindex )/4)
          if subindex  == 0:
          	a, b = cpoly.a, cpoly.b
          if subindex  == 1:
          	a, b = cpoly.b, cpoly.c
          if subindex  == 2:
          	a, b = cpoly.c, cpoly.d
          if subindex  == 3:
          	a, b = cpoly.d, cpoly.a
          you will have to do half the work with the neighbour class anyway 🙂
          edit: assuming that cpoly.c != cpoly.d, if not 2 is a,b = cpoly.c, cpoly.a
            On 09/02/2013 at 04:34, xxxxxxxx wrote:
            Works fine now. Thank you.🙂 The small mistakes...😲
