    EventAdd() doesn't update C4D
    25 Posts 0 Posters 20.4k Views
      On 05/02/2013 at 01:03, xxxxxxxx wrote:
      Hi Nachtmar,
      I found this very useful, maybe it will help you too. I was fighting with positions etc. until I dound this:
      http://www.nerdingoff.com/2012/02/c4d-python-matrix-basics-helper.html
      -Ingvar
        On 05/02/2013 at 09:52, xxxxxxxx wrote:
        You may not want it to be incremental. But that's how your code is set up.🙂
        Your code has a while loop in it that moves the camera if the object is not within the safeFrame view.
        The code that Yannick provided requires this kind of workflow to use it:
        -Check if object is fully in frame
        -if not: Move the object or the camera by some small amount
        -Check again if object is fully in frame
        -Repeat until object is fully in frame
        The incremental moving of the object or camera and then checking it again the scene view requires this to be done in a python tag or plugin. Where the code can run multiple times.
        It's not something you can normally do in the Script Manager script.
        This is a much more common way of placing objects in front of a camera using a script. And it's a lot less code to write:
        from c4d import utils
          obj   = doc.GetActiveObject()             #The object to move
          if obj is None: return False
          box = obj.GetRad()                        #The object's bounding box radius
          bd  = doc.GetActiveBaseDraw()
          cam = bd.GetSceneCamera(doc)
          camMtx = cam.GetMg()
          #Something to compare the camera to the object..Use whatever camera property you want
          focus = cam[c4d.CAMERAOBJECT_TARGETDISTANCE]
          #This is what's commonly called a "translation matrix"
          offset = c4d.utils.MatrixMove(c4d.Vector(0, 0, box.z + focus/7.5))
          newmtx = camMtx * offset
          obj.SetMg(newmtx)                         #Move the object to same place as the camera
          obj.Message(c4d.MSG_UPDATE)               #Update the change made to the object
          c4d.EventAdd()                            #Update C4D that something changed in the scene
          On 06/02/2013 at 01:42, xxxxxxxx wrote:
          Thanks for your replies!
          @ingvair: I'll have a deeper look into this, thank you!
          @ScottA: Thanks for the code, but I believe that I'm still misunderstood. I'll try it this way if you don't mind:
          1. I never wanted to do the code incrementaly, I want to do this with one single calculation
          2. You move the object, I want to move my camera (away from the object)
          3. you turn the object to the camera, I want to keep the angle between camera and object
          4. basically I want the same effect as when I press 'H' on the keyboard, but in a controlled way, so that the selected object is completely in the rendered frame but with its maximal size.
          Here's a picture for more explanation:
          https://sharedspace.uhlmann.de/download2.php?fileid=oqy02MUHr6
            Without wanting to sound rude, but you still do not understand. As I wrote already earlier you
            have to offset your basedaraw matrix, and I think Scott suggested something similar. You are in
            some kind of special scenario, you want to calculate view related data. The base view class
            depends on your camera matrix. Your approach was something like this :
            1. calculate data
            2. check result
            3. update the whole scene
            4. on false : goto 1
            5. on true : exit
            This is an incremental approach. Which is not generally bad, but in combination with updating the
            GUI (moving the camera  to update the base data for the base view) it leads to several problems.
            As I wrote earlier, simply use c4d.BaseView.SetMatrix() it has been made for this exact scenario,
            to offset a baseview.
            ps : i am littledevil 🙂
              On 06/02/2013 at 03:28, xxxxxxxx wrote:
              @Scott: Putting the code into a tag would be necessary when the camera should
              be moved or just be influenced over time (animated), but not when the camera should
              be moved for workflow reasons (like Nachtmahr said the 'H' command)
              -Niklas
                You don't sound rude, I can't deny that I still don't understand this 😉 But I'm eager to learn so I'll ask as long as I get the problem solved :]
                As I wrote earlier, simply use c4d.BaseView.SetMatrix() it has been made for this exact scenario, to offset a baseview.
                I'm sure you mean c4d.BaseView.SetBaseMatrix() because your method doesn't exist. I don'r understand what this method does. The documentation says "Sets the base matrix." - well... I already guessed that... The note says "The base matrix is multiplied with the camera matrix so that it is possible to have e.g. a frontal view into another direction than +Z."
                Ok, so it is multiplied with my camera matrix. I tried it in changing the BaseMatrix via the console
                bm = bd.GetBaseMatrix()
                vec = c4d.Vector(0.1, 0, 0)
                bm.off = vec
                bd.SetBaseMatrix(bm)
                I expected to see a change in view (because it is multiplied with my camera matrix as mentioned above) or something like that or at least in a rendering, but nothing happens.
                So I'm sorry, I still don't understand what this matrix does or how I have to use it. If you can give me a short example I'd be very glad!
                Thanks in advance
                Nachtmahr
                  On 06/02/2013 at 05:44, xxxxxxxx wrote:
                  Nachtmar,
                  have a look at this:
                  http://chicagoc4d.com/C4DPythonSDK/misc/matrixfundamental.html#matrix-fundamental
                  and did you look at the link I sent you in my prevoius post?
                  I struggled with similar things a few days ago. This helped me.
                  -Ingvar
                    On 06/02/2013 at 13:22, xxxxxxxx wrote:
                    I feel like I'm not being clear enough about why you can't (normally) do this kind of thing with a script.
                    You are comparing an object's points to a camera's position. Which means that you have to physically have these objects in the scene to do the comparison. It can't be done virtually in memory where the user doesn't see this happening unless the whole thing is done in a separate document.
                    This kind of thing is much easier to do in a python tag. Because you can re-run the entire code just by using EventAdd() until the condition you're testing for becomes true.
                    You don't have this option in a script. It runs once then you're done.
                    There is no such thing as: Test the objects->Move one of the objects->Test the objects again etc. until you get the desired result.
                    You can't do that in a script.
                    However. That said you can force a script to do this kind of thing.
                    But it's a lot of extra work. And it requires a lot of adding and removing objects.
                    Which might not be considered a good practice.
                    This script will position the camera so the cube is within the safeFrame view.
                    And it does it in one click:
                    def TestPointInFrame(pt, frame) :
                      return pt.x > frame['cl'] and pt.x < frame['cr'] and \
                             pt.y > frame['ct'] and pt.y < frame['cb']
                    def CheckIfInView(cam, obj, doc) :
                      #Get the current BaseDraw
                      safeFrame = bd.GetSafeFrame()
                      #Get the active object bouding box center and radius
                      box = [c4d.Vector() for x in xrange(8)]
                      points = [c4d.Vector() for x in xrange(8)]
                      rd = obj.GetRad()
                      mp = obj.GetMp()
                      #Build the active object bouding box
                      box[0] = c4d.Vector()
                      box[0].x = mp.x - rd.x
                      box[0].y = mp.y - rd.y
                      box[0].z = mp.z - rd.z
                      box[0] *= obj.GetMgn()
                      box[1] = c4d.Vector()
                      box[1].x = mp.x - rd.x
                      box[1].y = mp.y + rd.y
                      box[1].z = mp.y - rd.z
                      box[1] *= obj.GetMgn()
                      box[2] = c4d.Vector()
                      box[2].x = mp.x + rd.x
                      box[2].y = mp.y - rd.y
                      box[2].z = mp.y - rd.z
                      box[2] *= obj.GetMgn()
                      box[3] = c4d.Vector()
                      box[3].x = mp.x + rd.x
                      box[3].y = mp.y + rd.y
                      box[3].z = mp.y - rd.z
                      box[3] *= obj.GetMgn()
                      box[4] = c4d.Vector()
                      box[4].x = mp.x + rd.x
                      box[4].y = mp.y - rd.y
                      box[4].z = mp.z + rd.z
                      box[4] *= obj.GetMgn()
                      box[5] = c4d.Vector()
                      box[5].x = mp.x + rd.x
                      box[5].y = mp.y + rd.y
                      box[5].z = mp.y + rd.z
                      box[5] *= obj.GetMgn()
                      box[6] = c4d.Vector()
                      box[6].x = mp.x - rd.x
                      box[6].y = mp.y - rd.y
                      box[6].z = mp.y + rd.z
                      box[6] *= obj.GetMgn()
                      box[7] = c4d.Vector()
                      box[7].x = mp.x - rd.x
                      box[7].y = mp.y + rd.y
                      box[7].z = mp.y + rd.z
                      box[7] *= obj.GetMgn()
                      #Calculate bouding box coordinates in screen space
                      for i in xrange(len(box)) :
                          points[i] = bd.WS(box[i])
                      #Test if the current object is completely visible in the rendered safe frame
                      for i in xrange(len(points)) :
                          visible = TestPointInFrame(points[i], safeFrame)
                          if not visible:
                              break
                      return visible
                    Zvalue = 0
                      global Zvalue
                      cube = c4d.BaseObject(c4d.Ocube)
                      cube.SetName('Cube')
                      doc.InsertObject(cube)
                      cube.SetBit(c4d.BIT_ACTIVE)
                      c4d.CallCommand(12236) # Make Editable
                      cam = c4d.CameraObject()
                      cam.SetName('Cam')
                      camMg = cam.GetMg()
                      camMg.off = c4d.Vector(0,0,-200)
                      cam.SetMg(camMg)
                      doc.InsertObject(cam)
                      stage = c4d.BaseObject(c4d.Ostage)
                      doc.InsertObject(stage)
                      count = 0
                      while count< 150:   #<--------------- Force the loop to stop after a set amount for safety
                          tempcam = c4d.BaseObject(c4d.Ocamera)
                          doc.InsertObject(tempcam)
                          pos = tempcam.GetAbsPos()
                          tempcam.SetAbsPos(c4d.Vector(0, 0, Zvalue - 3))
                          tempcam.Message(c4d.MSG_UPDATE)
                          Zvalue = pos.z
                          stage[c4d.STAGEOBJECT_CLINK] = tempcam
                          c4d.DrawViews(c4d.DRAWFLAGS_ONLY_ACTIVE_VIEW|c4d.DRAWFLAGS_NO_THREAD|c4d.DRAWFLAGS_NO_REDUCTION|c4d.DRAWFLAGS_STATICBREAK)
                          if CheckIfInView(cam, cube, doc) :break
                          tempcam.Remove()
                          #print Zvalue
                          count +=1
                      #Set the original camera to the position the last cloned camera version was
                      cam.SetAbsPos(c4d.Vector(0,0, Zvalue))
                    Quite a mouthful of code for such a seemingly simple task ain't it. 😉
                      On 06/02/2013 at 15:05, xxxxxxxx wrote:
                      it is also possible without calling DrawViews() by moving the object itself, taking the delta from
                      its original position, move the camera by this delta and reset the object.
                          return pt.x > frame['cl'] and pt.x < frame['cr'] and \n           pt.y > frame['ct'] and pt.y < frame['cb']
                      def CheckIfInView(obj, bd) :
                          #Get the active object bounding box center and radius
                          rd = obj.GetRad()
                          mp = obj.GetMp()
                          points = [bd.WS(p) for p in box]
                              if not TestPointInFrame(points[i], safeFrame) :
                                  return False
                      def MoveObjectRel(op, axis, offset) :
                          axis = axis.GetNormalized()
                          axis.off = op.GetRelPos()
                          op.SetRelPos(axis * offset)
                      def EscapePressed(bc=None) :
                          if bc is None:
                              bc = c4d.BaseContainer()
                              c4d.gui.GetInputEvent(c4d.BFM_INPUT_KEYBOARD, bc)
                          return bc[c4d.BFM_INPUT_CHANNEL] == c4d.KEY_ESC
                          if not op:
                              c4d.gui.MessageDialog("please select an object")
                          if op is cam:
                              return MessageDialog("can not apply on the cam")
                          campos = cam.GetAbsPos()
                          pos = op.GetAbsPos()
                          axis = cam.GetMg()
                          offset = c4d.Vector(0, 0, 10)
                          # Create an undo-state for the camera because we will offset it.
                          doc.AddUndo(c4d.UNDOTYPE_CHANGE, cam)
                          c4d.StatusSetSpin()
                          passes = 0
                          stopped = False
                          while not CheckIfInView(op, bd) :
                              stopped = EscapePressed()
                              if stopped: break
                              passes += 1
                          delta = op.GetAbsPos() - pos
                          op.SetAbsPos(pos)
                          if not stopped:
                              campos -= delta
                          cam.SetAbsPos(campos)
                          c4d.StatusClear()
                        On 08/02/2013 at 05:34, xxxxxxxx wrote:
                        Thank you for your wonderful codes! I experimented the last two days with them and still have a few questions about them.
                        @Scott: You said, that scripts should not be used for this and that I should use a plugin instead. I'm quite open to that but I'm not really sure what the significant changes regarding your code will be. Can I use a complete new (and simpler) approach when using PlugIns? If so, what will it look like? I'm sorry if you had this question already answered, but I still have problems with that.
                        @Niklas: You move the object, not the camera. In future the scene I'll use this script/plugin on will have about 18.000 objects. I couldn't test it yet, but i suppose that this will be a serious performance issue.
                        And you use this line of code "op.SetRelPos(axis * offset)" to set the new offset of the object. If I'm not completely wrong vector math dictates to add the two vectors to get the resulting vector, not to multiply them. Obviously your solution works, so can you please tell me, why you multiply these two vectors instead of adding them? I'm really confused about this fact...
                        I really appreciate all your input and you all are helping me a lot! I'm really looking forward for your further answers. Thanks in advance!
                          On 08/02/2013 at 05:46, xxxxxxxx wrote:
                          Hi Nachtmahr,
                          I am moving the object, because moving the camera would require to redraw the editor in order for
                          BaseDraw.WS() to work correctly. The result is exactly the same. Compare Scotts and mine
                          example. You can watch the editor slowly moving away from the object in Scotts code, mine works
                          almost instantly. Do you really think it is more performant to redraw the editor on each pass?
                          axis is not a vector, it is a matrix. I'm moving the object away from the camera to simulate a
                          "zooming out". After the object is far away enough to fit into the editor view, I reset it to its
                          original position and move the camera about the anmount the object was moved in negative
                          direction.
                          Separately or all at once (so they all fit into the view at once)? Make CheckInView() traverse the
                          hierarchy recursively to check if all objects in the scene are in the frame. You should put all
                          objects under a Null-Object then (to make the simulation of "zooming out" work) assuming you
                          keep sticking to my solution.
                          -Niklas
                            It's a machine imported from a CAD-Tool for rendering. In most cases I have to render seperate parts of the whole machine, so the focusing will affect multiple thousands of objects, but not all of them.
                            You should put all objects under a Null-Object then (to make the simulation of "zooming out" work)
                            I think this won't be possible, because the inner structure of the imported data has to be kept. And if I move the parts under a Null-object I have to seperate them to their old places after the focusing is done. This sounds a bit of overkill to me.
                              On 08/02/2013 at 06:19, xxxxxxxx wrote:
                              You can also just automate the process of putting them under a null-object, run what the script
                              currently does on the null-object (but with taking its children into account) and unpack the null-object
                              again. Still better then redrawing the editor for each pass.
                              If you don't want that workaround, you could also manage to offset the objects aiming for seperately,
                              but this would be more code to write and less perfomant (because of Pythons slow iterations).
                                A plugin or pytag is just the usual choice for this kind of thing. Because they can execute their code several times. Not just once.
                                It's often an advantage to have this ability so you can compare things->move them->compare them again.
                                Most people would probably use a plugin or a pytag for this task you're doing. And take advantage of that running several times thing to do a task like multiple comparisons and moves.
                                But Niklas found a way to do this using a script that's just a s good as using a plugin or a pytag.
                                Normally this kind of task isn't done with a script due to it's run once nature.
                                But people who are clever (like Niklas) can often figure out a way to get around that problem.
                                  On 12/02/2013 at 02:13, xxxxxxxx wrote:
                                  Hey guys!
                                  I did some calculations the last days and it took me quite a while, because I got really confused about that many coordinate systems and matrices and vectors...
                                  Anyways, I managed to get a working code which did the repositioning of my camera in one calculation, without Redrawing or moving objects. It works pretty fine as long as the camera aims directly to the midpoint of the object (need to add an offset to the midpoint to the calculation) and the object is in front of the camera (not necessarily completly). So there is room for improvements 😉
                                  Created on 12.02.2013
                                  from c4d import documents
                                  import math
                                  def GetNewCameraPosition(cam, obj, doc) :
                                    #Get the active object bounding box center and radius, including midpoint as last point
                                    box = [c4d.Vector() for x in xrange(9)]
                                    points = [c4d.Vector() for x in xrange(9)]
                                    rd = obj.GetRad()
                                    mp = obj.GetMp()
                                    #Build the active object bounding box
                                    box[1].z = mp.z - rd.z
                                    box[2].z = mp.z - rd.z
                                    box[3].z = mp.z - rd.z
                                    box[5].z = mp.z + rd.z
                                    box[6].z = mp.z + rd.z
                                    box[7].z = mp.z + rd.z
                                    box[8].x = mp.x
                                    box[8].y = mp.y
                                    box[8].z = mp.z
                                    box[8] *= obj.GetMgn()
                                    #convert bounding box points to Screenspace
                                    #looking for extreme points
                                    minXIndex = maxXIndex = minYIndex = maxYIndex = minZIndex = maxZIndex = 0
                                    minX = maxX = points[minXIndex][0]
                                    minY = maxY = points[minYIndex][1]
                                    minZ = maxZ = points[minZIndex][2]
                                    for i in xrange(1, len(points) - 1) : #-1: Midpoint can never be an extreme point
                                        if points[i][0] < minX:
                                            minX = points[i][0]
                                            minXIndex = i
                                        if points[i][0] > maxX:
                                            maxX = points[i][0]
                                            maxXIndex = i
                                        if points[i][1] < minY:
                                            minY = points[i][1]
                                            minYIndex = i
                                        if points[i][1] > maxY:
                                            maxY = points[i][1]
                                            maxYIndex = i
                                        if points[i][2] < minZ:
                                            minZ = points[i][2]
                                            minZIndex = i
                                        if points[i][2] > maxZ:
                                            maxZ = points[i][2]
                                            maxZIndex = i
                                    #if a pair of indices is equal than a calculation can't be done
                                    if (minXIndex == maxXIndex) or (minYIndex == maxYIndex) or (minZIndex == maxZIndex) :
                                        print 'At least one pair of indices are equal: minX {0}, maxX {1}, minY {2}, maxY {3}, minZ {4}, maxZ {5}\nAborting function'.format(minXIndex, maxXIndex, minYIndex, maxYIndex, minZIndex, maxZIndex)
                                        return cam.GetMg().off
                                    #calculate offset from midpoint to nearest extreme point in z direction in sight of cam
                                    if points[minXIndex][2] <= points[maxXIndex][2]:
                                        offsetX = math.fabs(points[8][2] - points[minXIndex][2])
                                        offsetX = math.fabs(points[8][2] - points[maxXIndex][2])
                                    if points[minYIndex][2] <= points[maxYIndex][2]:
                                        offsetY = math.fabs(points[8][2] - points[minYIndex][2])
                                        offsetY = math.fabs(points[8][2] - points[maxYIndex][2])
                                    #calculate necessary distance between camera and extreme point
                                    fd_x = ((box[maxXIndex] - box[minXIndex]).GetLength() / 2.0) / math.tan(cam[c4d.CAMERAOBJECT_FOV] / 2)
                                    fd_y = ((box[maxYIndex] - box[minYIndex]).GetLength() / 2.0) / math.tan(cam[c4d.CAMERAOBJECT_FOV_VERTICAL] / 2)
                                    #add the corresponding offset
                                    fd_x += offsetX
                                    fd_y += offsetY
                                    #check if calculation went wrong (camera distance can't be negative),
                                    # set the focus distance to distance to midpoint of bounding box
                                    if fd_x > fd_y:
                                        if fd_x <= 0:
                                            print 'fd_x smaller than 0'
                                        cam[c4d.CAMERAOBJECT_TARGETDISTANCE] = fd_x
                                        if fd_y <= 0:
                                            print 'fd_y smaller than 0'
                                        cam[c4d.CAMERAOBJECT_TARGETDISTANCE] = fd_y
                                    #calculate the new camera position
                                    camMg = cam.GetMg()
                                    camMgOff = obj.GetMg().off
                                    camMgOff += camMg.v3.__neg__() * cam[c4d.CAMERAOBJECT_TARGETDISTANCE] #repositioning in negative z-axis
                                    return camMgOff
                                    cam = doc.SearchObject('Cam')
                                    cube = doc.SearchObject('Cube')
                                    camMg = cam.GetMg()
                                    camMg.off = GetNewCameraPosition(cam, cube, doc)
                                    cam.SetMg(camMg)
                                  Any recommandations on this code would be appreciated!
                                  Greetings Nachtmahr
                                    How do i do that ?
                                    I am itterating through all objects at the moment and the result is the camera moves away way too far. (some cubes dimenson 200m camera moves to 246666m)
                                    I need to have my Null-Object with lots of objects inside to be full inside the rendersave frame. Is it posible to get a boundingbox from a Null-Object with its children taken into acount without iterationg through several thousand objects ?
                                    thanks in advance.
                                      On 27/06/2015 at 10:21, xxxxxxxx wrote:
                                      So I managed to add Niklas aabb Boundingbox Routine to your script but I am still getting weird results.
                                      sometimes nothing happens, passes = 0 even when something is not in view,
                                      sometimes it works kind of but the object is way to small in the midle,
                                      sometimes it runs forever in a loop
                                      can we get this as neat and tidy and better working than this "H"-Key in C4D?
                                      kind regrads mogh
                                      # Added Niklas Rosenstein AABB Utility to get the boundingbox of a Null-Object with its Children
                                      # please note that you have to install it
                                      # http://pythonhosted.org/c4dtools/
                                      # https://github.com/NiklasRosenstein/c4dtools <- download from here
                                      import c4dtools.misc.aabb as aabb
                                      #def CheckIfInView(obj, bd) :
                                      def CheckIfInView(obj, rd, mp, bd) :
                                          #rd = obj.GetRad()
                                          #mp = obj.GetMp()
                                          #print box, rd, mp
                                                  return False
                                          if bc is None:
                                          c4d.CallCommand(13957) # Konsole löschen
                                          if not op:
                                          if op is cam:
                                          axis = cam.GetMg()
                                          c4d.StatusSetSpin()
                                          passes = 0
                                          oppasses = 0
                                          stopped = False
                                          box = aabb.AABB()
                                          box.expand_object(op, recursive=True)
                                          print "AABB Values:"
                                          print "Size: ", box.size
                                          print "Midpoint: ", box.midpoint
                                          mp = box.midpoint
                                          rd = box.size
                                          #while not CheckIfInView(op, bd) :
                                          while not CheckIfInView(op, rd, mp, bd) : # pass aabb values to check routine
                                              if stopped: break
                                              oppasses += 1
                                          print "Check in view passes: ", oppasses
                                          op.SetAbsPos(pos)
                                          if not stopped:
                                              campos -= delta
                                          c4d.StatusClear()
