    Spline is not updated after i move point using Pyt
    2 Posts 0 Posters 270 Views
      On 28/01/2013 at 18:29, xxxxxxxx wrote:
      I am using Python to move a spline's point. But the spline itself is not updated in the C4D viewport, the point moves alone, together with its tangent(s). Only after I grab the handles and manually move the point a little, the whole spline is updated. What code can I write to have the spline immediately follow the node's movements?
      def Execute(self, tag, doc, op, bt, priority, flags) :
            spline = tag.GetObject()
            oldPos = spline.GetPoint(0)
            newPos = c4d.Vector(oldPos.x + 10, oldPos.y + 10, oldPos.z)
            spline.SetPoint(0, newPos);
      -Ingvar
        On 29/01/2013 at 00:23, xxxxxxxx wrote:
        Ok, found out about it myself. It is in the SDK doc, under PointObject.
        One needs to call obj.Message ( c4d.MSG_UPDATE )
        -Ingvar
