    LinkBox in .res not work
    19 Posts 0 Posters 2.5k Views
      On 02/01/2013 at 05:24, xxxxxxxx wrote:
      you din't asign the linkbox gui to a variable. you just used a variable with the name linkBox.
      def CreateLayout(self) :
      self.LoadDialogResource(IDD_RISORSA)
      # Here you don't
      def Command(self, id, msg) :
      if id == 10006:
         # but here you use self.linkBox as if a LinkBoxGui has been asigend to it.
         # This line should actually raise a runtime error.
         print self.linkBox.GetLink()
      # Here you asign it to variable
      self.linkBox = self.AddCustomGui(MY_LINKBOX, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0)
      if id == 10006:
         # which you use here to access the LinkBoxClass
      littledevil Thank you so much for your help I know that this is how it works.
      but I was wondering how to make it work with a c4d.CUSTOMGUI_LINKBOX in . res file
      sorry if I can't express myself well 🙂
      and thanks for the patience that you have shown 🙂
        On 02/01/2013 at 06:50, xxxxxxxx wrote:
        well, my example was aimed at a res file solution. you have to always think of how c4d works.
        almost everything has to be broken down into a BaseContainer. so if you have a gui which holds
        a textbox and a checkbox c4d creates somewhere a BaseContainer which looks something like
        this pseudocode :
        myDialogBc = c4d.BaseContainer()
        myDialogBc[myTextBoxID] = 'TextBoxText'
        myDialogBc[myCheckBoxID] = checkBoxCheckValue
        when you call in your dialog :
        self.setString(myTextBoxID, 'new fancy string')
        c4d writes this internally into the bc of your dialog. which would be for our pseudo code
        example :
        myDialogBc[myTextBoxID] = 'new fancy string'
        but a BaseContainer can only contain certain data types. There are the basic data types like
        string, long and so on and there are CustomDataTypes. those are plugins which tell c4d how to
        store a specific class (which can hold any data) in a BaseContainer(). CustomGuis are a form
        of these CustomDataTypes.
        so when you have a LinkBoxGui in your dialog you have to get the LinkBoxGui class from the
        BaseContainer first and then you can use the methods provided by the class to change/read
        the data.
        # imagine this linkbox has been added in a resfile
        # we use FindCustomGui to get the class stored in the BaseContainer at our ID
        myLinkBox = self.FindCustomGui(MY_LINKBOX, c4d.CUSTOMGUI_LINKBOX)
        #do something with the linkbox class
        print myLinkBox.GetLink()
          On 02/01/2013 at 12:32, xxxxxxxx wrote:
          ^Using the code method you provided will create a LinkBox gizmo in the dialog. But when you try to grab the object in it the result is always None.
          Here's a complete plugin example.
          When LoadDialogResource() is used. The return from it is always None.
          When LoadDialogResource() is commented out. The Linkbox works and returns what's inside of it properly.
          https://sites.google.com/site/scottayersmedia/res Based Linkbox.zip
          Also note in the .res file the comment I wrote that the accept flag for the linkbox throws an error too! 😠
          This is why I avoid using .res files for dialogs at all costs. And only use them for making dialog based spline GUI's.
          It's either buggy, broken, or just plain not documented properly by Maxon.
            Yes ScottA, I'm the same I your opinion 🙂
            Thank you ScottA and Thanks even littledevil !Thumbs Up[URL-REMOVED]
              https://sites.google.com/site/scottayersmedia/.res Based Linkbox.zip
              that is simply not true. i haven't red your whole example code, but i saw a comment saying
              c4d crashes when you set the refuse and and accept flags. this is kind of obvious because
              both these flags are description flags and dialog ressources  are not descriptions. you have
              also be careful about the lifettime of the linkbox class.
              however here is little example plugin showing the two LinkBox methods which are exposed to
              python in action (GetLink, SetLink). the plugin loads a dialog from a ressource file , creates on
              init a cube and inserts the cube into the document, then asigns it to the linkbox and as the last
              action it prints the linkbox content to the console.
              if this really doesn't work for you (which i cannot really believe) this has to be an OS problem.
              http://www.file-upload.net/download-7003752/LinkBoxGui.zip.html
              import os, sys, string
              from c4d import bitmaps, documents, gui, plugins
              PID = 1000001
              class fhLinkBoxDialog(gui.GeDialog) :
                  def __init__(self) :
                      self.LinkBox = None
                      geRessource = plugins.GeResource()
                      geRessource.Init(os.path.dirname(__file__))
                      result = self.LoadDialogResource(10001, geRessource, 0)
              	if (result) :
                      	linkBox = self.FindCustomGui(10002, c4d.CUSTOMGUI_LINKBOX)
                      	cube = c4d.BaseObject(c4d.Ocube)
                      	doc.InsertObject(cube)
                      	linkBox.SetLink(cube)
                      	print linkBox.GetLink(doc, c4d.Ocube)
                      return result
              class fhLinkBoxExample(plugins.CommandData) :
                      self.ManagerDialog = fhLinkBoxDialog()
                  def Execute(self, doc) :
                      screen = gui.GeGetScreenDimensions(0, 0, True)
                      result = self.ManagerDialog.Open(dlgtype  = c4d.DLG_TYPE_ASYNC,
        pluginid = PID,
                                                  			      xpos     = int(screen['sx2'] / 2) - 300,
                                                 			      ypos     = int(screen['sy2'] / 2) - 300)
                      return result
                  dir, f = os.path.split(__file__)
                  c4d.plugins.RegisterCommandPlugin (id   = PID,
                                                     str  = "fhLinkBox",
                                                     help = "",
                                                     info = 0,
                                                     dat  = fhLinkBoxExample(),
                                                     icon = None)
                On 02/01/2013 at 17:35, xxxxxxxx wrote:
                Doh!
                Thanks for posting that code ferdinand.
                I was returning True in my CreateLayout() method instead of returning the resource variable.
                No wonder I was getting None type errors. 😊
                @Caleidos4d,
                I updated my example file because it works properly now.
                Just drop any object into the linkbox gizmo and click the "execute" button. And it will get the name of the object in the linkbox.
                The other gizmos don't do anything they're just there as filler. So ignore them.
                Let me know when you've got the file. Because I'm going to delete it.
                  @Caleidos4d,
                  Hi ScottA!
                  I realized just now that you've updated the post, I haven't had time to download the updated version of the file, thanks anyway 🙂
                    On 12/01/2013 at 12:25, xxxxxxxx wrote:
                    I wondered what happened to you. 🙂
                    It has a bunch of notes and gizmo code in it for my own reference purposes that might be confusing to people. That's why I deleted it.
                    If you still want it just send me your e-mail address in a private message and I'll send it to you.
                      On 12/01/2013 at 12:47, xxxxxxxx wrote:
                      i have sended my email address in private messagge, Thank ScottA!!
                        c4d.gui.GeDialog.LoadDialogResource() returns a boolean value, just like ~.CreateLayout() expects
                        as return type.
                        Best,
                        -Niklas
                          On 12/01/2013 at 17:09, xxxxxxxx wrote:
                          When returning True in the CreateLayout() method. I only get proper results from locally created gizmos using the ADD() type coding method.
                          Returning True while using a .res file in the CreateLayout() method results in zero values from my gizmos.
                          In order to use a .res file and get proper results from my gizmos.
                          This is an example of what I have to use in CreateLayout() :
                          res = self.LoadDialogResource(ResBasedMenu)
                          self.mylink = self.FindCustomGui(MY_LINK, c4d.CUSTOMGUI_LINKBOX)
                          return res
                          Same thing goes for C++ plugins.
                          Everything is working fine for me now.
                            On 13/01/2013 at 03:27, xxxxxxxx wrote:
                            Hi Scott,
                            What Cinema 4D release are you working with? I'm using R14 and do not hit this problem, but
                            I remember there have been issues in an old R13 version with FindCustomGui(). However, the
                            following code works in R13.051+ (maybe even older versions) including R14 of course.
                            class MyDialog(c4d.gui.GeDialog) :
                            result = self.LoadDialogResource(res.DLG_TEST)
                            self.link = self.FindCustomGui(res.EDT_LINK, c4d.CUSTOMGUI_LINKBOX)
                            print "Return value of self.LoadDialogResource() :", result
                            # No difference in returning True or `result` here (for me).
                            def InitValues(self) :
                            self.SetReal(res.EDT_WIDTH, 100, 0)
                            self.SetReal(res.EDT_HEIGHT, 100, 0)
                            if id == res.BTN_OK:
                            op = self.link.GetLink()
                            print "Link in linkbox:", op
                            elif id == res.BTN_CANCEL:
                            self.Close()
                            You can find my complete set-up here, but it requires c4dtools installed.
                            Best,
                            Niklas
                              On 13/01/2013 at 09:22, xxxxxxxx wrote:
                              I think I was using R12 at the time.
                              If I get a chance I'll try testing in R13.
