    Evenly distribute selected points.
    Scheduled Pinned Locked Moved Plugin Requests
    1 Posts 0 Posters 703 Views
      On 18/12/2012 at 17:34, xxxxxxxx wrote:
      Is it possible to have a plugin that will allow a user to select a chain of connected points and have them evenly distributed from first to last (evenly spaced) and aligned in a straight line connecting first and last point?
      For example - this is how I see it working:
      User selects a bunch or points.
      User runs script/plugin
      Plugin asks user to select 1st point
      - As user moves mouse around a white highlight snaps to selected points similar to how the knife tool does in line mode.
      - Once chosen point located and highlighted, user left clicks to indicate start point.
      Plugin asks user to select last point
      - Same as 1st pt, user moves to last point, highlight snaps to selected points as mouse moves around but now plugin draws a rubber-band highlight line connecting 1st point and currently highlighted last point.
      - Once last point is chosen, user left clicks to indicate last point.
      Plugin then divides the imaginary line between 1st and last pts into required equal segments and calculates the x/y/z of the each dividing point along this imaginary line.
      Plugin then sets the x/y/z of the 2nd to 2nd-last selected points to these new calculated positions
      The only problem that I can see is how to identify the point sequence 1,2,3,4 etc so that they can be relocated to their new positions in the correct order.
      At the moment, I know ZERO about coffee/ptyhon and cinema 4d scripting but hoping to learn it as soon as possible.
