    store data with the document
    3 Posts 0 Posters 480 Views
      On 17/12/2012 at 16:01, xxxxxxxx wrote:
      info : R14, Vista64, Python
      i have got a stupid question again. i have got a command plugin generating data for a
      c4d file stored in a multilevel BaseContainer. currently i am saving these data with a
      hyperfile which is a bad solution, because renaming or moving the c4d file breaks the
      connection between the data and the c4d file. so i am looking for a better place now.
      i want :
      1. to store the data within the file
      2. the data not to be visible to the user (as a object, material or tag node)
      possible ways i have been looking into :
      1. use BaseDocument.SetData()
        1. is this way even possible ?
        2. i have tried the following simple example:
            * console output:
            * SystemError: source\pymodules\c4d\PyBaseContainer\PyBaseContainer.cpp:1095: bad argument to internal function
            *       * import c4d
            * def main() :
            *     bc = c4d.BaseContainer()
            *     bc.SetBool(c4d.DOCUMENT_RENDERLOD, True)
            *     doc.SetData(c4d.DOCUMENT_RENDERLOD, bc)
            * if __name__=='__main__':
            *     main()
      3. so, how is the correct way to feed this method ?
      4. can i use own type ids and which id would i have to use without conflicting with other ids ? my plugin id ?
      1. use a NodeData plugin
        1. is it possible to create some NodeData subtype plugin type and add it in *hidden* mode into the document ?
        2. the sdk says it is even possible to inherit from c4d.plugins.nodeData itself, but when i do so, my plugin hasn't any access to the methods provided by NodeData.
      sorry for this bunch of questions, but i have really tried to solve this on my own without any real
      success. i would be really thankful for a push into the right direction. i have also tried the search
      function on this without any useable result.
      thanks for reading and any help.
        On 18/12/2012 at 00:28, xxxxxxxx wrote:
        Hi Ferdinand,
        To easily save data within a document or object, check this post.
        This is the simplest way in Python but remember that the ID to store the data has to be unique;
        generate it like a plugin ID.
        BaseDocument.SetData() is only useful with the defined document settings.
        console output:
        In Python you can just do this:
            doc[c4d.DOCUMENT_LOD] = 0.5
        So, basically the operator [] is the way to go when dealing with parameters and the CINEMA API.
          On 18/12/2012 at 04:26, xxxxxxxx wrote:
          thanks
