    Fill GeDialog combo box dynamically ?
    6 Posts 0 Posters 823 Views
      On 12/12/2012 at 09:42, xxxxxxxx wrote:
      INFO : C4d r14, Windows Vista 64, Python
      hm,
      sorry it is me again 🙂 Is it possible possible to fill a GeDialog ComboBox dynamically with
      children / entries after the execution of GeDialog.CreateLayout() ? I have got the
      following :
          # dialogContainer is a BaseContainer containg the current dialog settings
          # self.Presets is a BaseContainer containing several Bc of the same structure
          # cHelp is a namespace to some c4d related methods. the whole chain is called
          # from GeDialog.Command() :
          # the bc is saved to file ...
          def savePreset(self, dialogContainer) :
              presetName = c4d.gui.InputDialog('Preset name:','myPreset {0}'.format(len(self.Presets)))
              dialogContainer.SetString(1000, presetName)
              self.Presets.SetContainer(1000 + len(self.Presets), dialogContainer)
              result = cHelp.SaveHyperFile(self.Presets, self.PresetFilePath, self.HyperKey, True)
              if(result) :
                  self.fillComboBox()
                  print self.SetLong(srCon.IDC_PRESET_COMBOBOX, len(self.Presets))
              return result
          # and loaded back here. the ccombox is populated with the new preset names
          def fillComboBox(self) :
              result = cHelp.ReadHyperFile(self.PresetFilePath, self.HyperKey, True)
      	if(type(result) == c4d.BaseContainer) :
      		self.Presets = result
              	self.FreeChildren(srCon.IDC_PRESET_COMBOBOX)
              	counter = 0
              	for item in self.Presets:
      	    		# here i am adding the children, and trying to tell c4d that something had changed.
      	    		# had the flush and changed thingie on a higher level first, but then moved them here
                  		# to be ultrasafe.
                  		self.LayoutFlushGroup(srCon.IDC_PRESET_COMBOBOX)
                  		self.AddChild(srCon.IDC_PRESET_COMBOBOX , counter, item[1].GetString(1000))
                  		self.LayoutChanged(srCon.IDC_PRESET_COMBOBOX)
      		return False
      I am feeling pretty lazzy for just asking again, but i am not sure what is going wrong there.
      When i execute the plugin, everything works as expected. I save the dialog settings to a
      hyper file and load the content back from the hyperfile. The combobox is also populated as
      expected with my preset names, BUT i cannot visually select anything except the first child.
      Programmatically i can set the combobox to any value i want and is also accepted and
      returned correctly (but also not reflected in the gui).
      thanks for your help, as always.
        On 13/12/2012 at 02:54, xxxxxxxx wrote:
        Have you tried removing the calls to LayoutFlushGroup() and LayoutChanged()?
          On 13/12/2012 at 04:41, xxxxxxxx wrote:
          do you mean this in in a special context ? because i am calling both in my fillComboBox()
          loop for each preset found and added, as shown in the snippet. also i am not quite
          sure if i am qusing them both correctly. do they actually expect a group ? i am just
          passing the ComboBox.
                    counter = 0
                        # to be ultrasafe.
            return False
            It seems you return True from inside the loop. This is maybe why you can only select the first child.
              On 13/12/2012 at 05:52, xxxxxxxx wrote:
              sorry about that, that is just a typo I introduced, because the copy/paste messed up
              the indentions (if the true would be there the combobox wouldn always just contain
              one element , but i have all elements, but i can just select the first).
              before :
              selection:
              after :
                On 13/12/2012 at 06:51, xxxxxxxx wrote:
                lol stupid me, if forgot to increase my counter variable and therefor all entries have the same
                ID 🙂
