    running plugin from different folder
    7 Posts 0 Posters 704 Views
      On 04/12/2012 at 12:17, xxxxxxxx wrote:
      Cinema 4D Version:   14
      is it possible to run the plugin from different folder
      example:
      normal plugin is located at Maxon\cinema4d\plugins\myplugin
      can i make it run from path (for example) "c:\myplugin"
        On 04/12/2012 at 13:58, xxxxxxxx wrote:
        No, it isn't, unless you don't load the plugin yourself from a plugin which again lies in Cinema 4D's plugin directory.
        -Nik
          On 04/12/2012 at 14:04, xxxxxxxx wrote:
          well i want to do this ...but how 😄
          (i know i need to load the plugin custom folder path from another plugin inside cinema4d plugins folder)
          i just need basic steps no need for actual code
            On 04/12/2012 at 14:33, xxxxxxxx wrote:
            You should be able to do this using an Environment Variable set up.
            Did this long ago for a while but its very "global" (All Cinema versions see
            this link)
            Some efforts here:
            http://forums.cgsociety.org/showthread.php?f=47&t;=948633&highlight;=Environment
            Lennart
              On 04/12/2012 at 20:01, xxxxxxxx wrote:
              well from what i've seen (what i understand) is that you have changed environment variables to force cinema4d to look at the folder u want ...but that's not exactly what i want (as i want my plugin to be shipped and don't know if it will be possible to change other ppl environment variables in windows)
              what I (imagined) to be possible is to:
              1-make the main plugin file .cdl/.cdl64 inside cinema4d plugins folder
              2-make a part in that main plugin file to refer to a custom path of another precompiled plugin file (another .cdl/.cdl64) -_- like loading plugin from another plugin (if this is possible)
                On 04/12/2012 at 23:28, xxxxxxxx wrote:
                1. Load the library (using the OS API)
                2. Redirect PluginStart(), PluginMessage() and PluginEnd() to it.
                Best,
                Niklas
                  On 05/12/2012 at 06:31, xxxxxxxx wrote:
                  thanks alot niklas 🙂
                  I think it should do the trick (though i didn't test it yet) but looking promising 😄
