    MSG_DESCRIPTION_COMMAND
    4 Posts 0 Posters 386 Views
      On 03/12/2012 at 20:43, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Platform:      Mac OSX  ;
      Language(s) :
      Oh what a newbie I am!
      I am just trying to learn how to actually process messages coming from my toolPlugin.
      Using mostly the c4dsdk source and the SDK docs.
      If I understand correctly I use DescriptionToolData for a toolPlugin. Therefore I use this Message function (below). For all I know I should see "ObjectAligner: Message" in the console after clicking a button or other gadget in the dialog. And that is true. From what I understand - and the sample code backs me up - I should also see "MSG_DESCRIPTION_COMMAND" to tell me that my function actually did receive one of those. But I don't and "some other command" is shown.
      So, just to make sure:
      in
      Message (BaseDocument *doc, BaseContainer &data, LONG type, void *t_data)
      LONG type is MSG_DESCRIPTION_COMMAND (or another one from the list)
      t_data pointing to a descID and its 'id' member contains the actual gadget
      Yikes, I am wasting so much time on this. Every time I understand this a little better something like this gets in the way and I can't make sense of it.
      Bool ObjectAligner::Message (BaseDocument *doc, BaseContainer &data, LONG type, void *t_data)
          GePrint("ObjectAligner: Message");
          if (type==MSG_DESCRIPTION_COMMAND) {
              GePrint("MSG_DESCRIPTION_COMMAND");
          } else {
              GePrint("some other command");
        On 10/12/2012 at 12:32, xxxxxxxx wrote:
        Just FYI. This issue is solved. Tried to delete this post.
        Peter
          On 10/12/2012 at 13:17, xxxxxxxx wrote:
          Or better yet, let us know what fixed it, ok? 🙂
          Someone down the line might run into a similar issue.
          Lennart
            On 10/12/2012 at 18:13, xxxxxxxx wrote:
            Sorry, of course!
            The fix is very embarrassing. It was working all along and the line "GePrint("some other command");" was throwing so many messages in the console that I overlooked the single "MSG_DESCRIPTION_COMMAND" I was looking for.
            In the meantime I am still learning how to extract all the information from the dialog.
            Peter
