    Querying exisiting nodes inside XPresso Editor
    5 Posts 0 Posters 476 Views
      On 03/12/2012 at 14:44, xxxxxxxx wrote:
      Pretty self explanatory I think. The reason I am wanting to do this is to work around the object port object operator bug.
      Basically, I want to just add the port myself, then query the already made node so I can access it's port info. I tried all the selection methods I can think of, but it seems C4D doesn't treat nodes as objects. Thanks for the help.
      Rick
        On 04/12/2012 at 01:39, xxxxxxxx wrote:
        Hi Rick,
        You have to first get the XPResso node master from the XPresso tag calling XPressoTag.GetNodeMaster().
        Then to get the root node use GvNodeMaster.GetRoot() returning a GvNode, which is a subclass of GeListNode (so you can navigate the node tree with node.GetNext(), node.GetChildren() etc.).
          On 04/12/2012 at 06:14, xxxxxxxx wrote:
          So I tried to use the .GetChildren() and the other GeListNode stuff, but instead of getting the one node that is in there, I get an empty list or just a None. Figured i would post my code so maybe it will make it easier. I am currently testing it with just a cube at the top of the Object Manager with the said xpresso tag with the object operator inside already set up, along with a couple of spheres below to test the list function. Thanks for the help.
          from c4d import gui
          _
          _
          _
          _
          _    _
          _    op = doc.GetFirstObject()_
          _    tag = op.GetFirstTag()_
          _    nodeMaster = tag.GetNodeMaster()_
          _    selected = doc.GetActiveObjects(0)_
          _    bc = c4d.BaseContainer_
          _    for sel in selected:_
          _        _
          _        l=100 * selected.index(sel)_
          _        _
          _        controllerNode = nodeMaster.GetChildren()_
          _        pointNode = nodeMaster.CreateNode(nodeMaster.GetRoot(), c4d.ID_OPERATOR_POINT, insert=None, x=300, y=l)_
          _        objNode = nodeMaster.CreateNode(nodeMaster.GetRoot(), c4d.ID_OPERATOR_OBJECT, insert=None, x=500, y=l)_
          _        objNode[c4d.GV_OBJECT_OBJECT_ID] = sel_
          _        objNode.AddPort(c4d.GV_PORT_INPUT, c4d.ID_BASEOBJECT_GLOBAL_POSITION)_
          _        _
          _        _
          _        CPport = controllerNode[0].GetOutPort(0)_
          _        OPport = pointNode.GetInPort(0)_
          _        PPport = pointNode.GetOutPort(1)_
          _        GPport = objNode.GetInPort(0)_
          _        _
          _        CPport.Connect(OPport)_
          _        PPport.Connect(GPport)_
          _    _
          _    nodeMaster.Message(c4d.MSG_UPDATE)_
          _    c4d.EventAdd()_
          _if _name__=='_main__':
          _    main()
                **nodeMaster = tag.GetNodeMaster()**
            does this actually work ? because GetNodeMaster() is a c4d.modules.graphview.GvNode member
            and not a GeListNode member, you have to call it from an actual GraphView node. edit : and please
            use a monospace font to post your code or the code, /code tags.
              On 04/12/2012 at 10:36, xxxxxxxx wrote:
              THANK YOU! I just realized it was Gv NodeMaster, and not Get NodeMaster that I needed to use to get the root node. I need to pay better attention to these things. Anyway here is the final code snippet if anyone is interested. Thanks for the help everyone.😄
              from c4d import gui
              _
              _
              _
              _
              _    _
              _        _
              _        l = 100 * selected.index(sel)_
              _        _
              _        rootNode = nodeMaster.GetRoot()_
              _        controllerNode = rootNode.GetChildren()_
              _        _
              _        _
              _        _
              _    _
              _    c4d.EventAdd()_
              _    main()
