    what are dead objects ?
    13 Posts 0 Posters 1.6k Views
      On 28/11/2012 at 11:42, xxxxxxxx wrote:
      hey,
      thanks for your reply. when i change
      obj = InExclude.ObjectFromIndex(doc, i)
      to
      obj = InExclude.ObjectFromIndex(None, i).GetClone(c4d.COPYFLAGS_NO_MATERIALPREVIEW)
      it doesn't change much. the smc returns one dead spline instead of the amount set in the cloner. is
      cloning meant in a different way ? i have to admit i always kind of ignored that topic "clone xyz, or it
      will blow up into your face", as it didn't really caused me any trouble in the past, even if the sdk said
      so 🙂
        On 28/11/2012 at 14:12, xxxxxxxx wrote:
        Are you doing this in an expression rather than a command,
        as you are using a InEx List?
        Lennart
          On 28/11/2012 at 14:16, xxxxxxxx wrote:
          i am doing this from a python xpresso node.
            On 28/11/2012 at 14:35, xxxxxxxx wrote:
            Then don't 🙂
            It's living on the edge modifying the document at runtime.
            Generally do this in a command (that you call from your xpresso node (havent tried))
            or in a message body of an expression (so you can control the document while executing)
            Lennart
              On 28/11/2012 at 15:15, xxxxxxxx wrote:
              hey,
              thanks for your help. with "do this in a command" you suggest using a CommandData plugin ?
                On 28/11/2012 at 16:00, xxxxxxxx wrote:
                A regular Command script could do, unless you want to call it from
                something else. Then a registered Command Plugin would be better
                as you can call it by it's Plugin ID. (Command scripts tend to change their
                ID over time, strangely enough)
                Lennart
                  On 29/11/2012 at 01:44, xxxxxxxx wrote:
                  hm,
                  doesn't change anything.
                  - script version
                  - more explicit usage of SMC CSTO
                  - did the clone object/document thing the sdk suggests for CSTO
                  something doesn't feel right, i am either making a fundamental mistake, or smc is bugged (again)
                  at that point. never had to do all this cloning stuff in the past. there is also the fact, that when you
                  start cloning things before smc (the object, the document or both) the smc just returns one object.
                  or in other words - is just ignoring the cloner (although I explicitly set NOGENERATE to False in its
                  settings).
                  i am also pretty unsure about this documents.IsolateObjects() method thing. do i have to search
                  my objects in the document by myself or is the passed object list now automatically referencing
                  objects in the new document ?
                  from c4d import utils as u
                  from c4d import documents
                      userData =  doc.SearchObject("UserData")
                      objList = inExclude2List(userData[c4d.ID_USERDATA,1])
                      splines = getSplines(objList)
                      for n in splines:
                          print n
                  def inExclude2List(InExclude) :
                      result = []
                      for i in range (InExclude.GetObjectCount()) :
                          result.append(InExclude.ObjectFromIndex(doc, i))#.GetClone(c4d.COPYFLAGS_CACHE_BUILD))
                      return result
                  def getSplines(objects) :
                      result = []
                      cloneDoc = documents.IsolateObjects(doc, objects)
                      # doesn't change anything
                      # objects = []
                      # objects.append(cloneDoc.GetFirstObject())
                      for obj in objects:
                          if (obj.CheckType(c4d.Ospline)) :
                              result.append(obj)
                              children = obj.GetChildren()
                              if(children != None) :
                                  result += iterateObjectTree(children)
                          else :
                              set = c4d.BaseContainer()
                              set[c4d.MDATA_CURRENTSTATETOOBJECT_INHERITANCE] = True
                              set[c4d.MDATA_CURRENTSTATETOOBJECT_KEEPANIMATION] = True
                              set[c4d.MDATA_CURRENTSTATETOOBJECT_NOGENERATE] = False
                              smc = u.SendModelingCommand(command = c4d.MCOMMAND_CURRENTSTATETOOBJECT,
                                                          list = [obj],
                                                          mode = c4d.MODELINGCOMMANDMODE_ALL,
                                                          bc = set,
                                                          doc = cloneDoc)[0]
                              print "smc", smc
                              if (smc.CheckType(c4d.Ospline)) :
                                  result.append(smc)
                              children = smc.GetChildren()
                      return result
                  def iterateObjectTree(objectList) :
                      result = []
                      for obj in objectList:
                                  result.append(obj)
                      return result
                  edit: just for the record - console output for this is :
                  smc <c4d.BaseObject object called 'Cloner/Null' with ID 5140 at 0x0000000006E180D0>
                  <dead c4d.SplineObject object at 0x000000000FD185F0>
                  edit no. 543957 :
                  also the whole - cloner objects aren't the cause for dead objects, but null objects thing applies also to this script version.
                  imghttp://oi47.tinypic.com/1zoetll.jpg
                    On 29/11/2012 at 05:28, xxxxxxxx wrote:
                    This is a variable scope problem. If you print the splines at the end of getSplines(), before returning them, they're valid.
                    But once the list is returned to main(), splines are no more valid because they were stored in a local list and they don't belong to any document.
                    To resolve this, you should create a new document in your main() and then pass it to getSplines() in order to insert the resulting object for SMC CSTO.
                      On 29/11/2012 at 07:38, xxxxxxxx wrote:
                      I'm not sure what you are getting at in the end
                      but the following works fine.
                      Lennart
                      from c4d import gui, utils as u
                      #CSTO
                      def csto(obj) :
                          csto_bc     = c4d.BaseContainer()
                          csto_objs   = u.SendModelingCommand(
                              list    = [obj],
                              bc      = csto_bc,
                              doc     = obj.GetDocument())
                          return csto_objs[0]
                          act_obj = doc.GetActiveObjects(False)[0] # First Active Object with an Userdata InEx List
                          if not act_obj: return True # Nothing Selected
                          try: inexlist = act_obj[c4d.ID_USERDATA,1]
                          except: return True # Emty or no list
                          doc.StartUndo()
                          for i in xrange(inexlist.GetObjectCount()) :
                              o = inexlist.ObjectFromIndex(None,i)
                              cobj = csto(o)
                              doc.AddUndo(c4d.UNDOTYPE_NEW,cobj)
                              doc.InsertObject(cobj,None,None)
                          doc.EndUndo()
                        this solved my problem, thanks 🙂
