    Polygonal Object
    21 Posts 0 Posters 13.2k Views
      On 29/11/2012 at 03:49, xxxxxxxx wrote:
      that would be OK. I'm only after a polygon object of my own - so not a generator object that can (for example) change fillet number or radius etc. Just a plain boring old poly object or my own that can be edited with modelling tools.
      In that case all you'd need is a CommandData plugin to insert a polygon object into the scene when requested. Your plugin would create the necessary object plus any points and polygons required (otherwise it would be empty and you wouldn't see anything) then insert it. That's a one-off action, the user can then edit the object as desired. You wouldn't need an ObjectData plugin at all.
        On 29/11/2012 at 15:59, xxxxxxxx wrote:
        Ah, I had a tinker with CommandData but that doesn't appear to be quite what I was after. Might be my explaining 😃
        What I'm after is an actual editable polygon object plugin. So my plugin would be an editable polygon object that sits in the object manager.
        WP.
          On 30/11/2012 at 01:26, xxxxxxxx wrote:
          I think that's not possible. To be a plugin which sits in the OM and generates geometry it has to be an ObjectData. To produce any geometry an ObjectData will return a virtual object. If it's a virtual object you can't edit it. The moment you make it editable it ceases to be a generator object and just becomes an ordinary poly object.
          I'd be very happy for someone else to correct me on that but TBH I really think that it can't be done.
            Not sure what you really want. If your object is just an editable polygon object, and it's not parametric - in what way, then, does it differ from the standard polygon object that you already have?
            What is the functionality that you want to associate with your object, if it is not generated, and all you want is the standard edit functions?
            Perhaps you should describe a usecase. What is a user supposed to do with that object, what is the problem that it solves, in what way does the object's functionality help him?
              On 04/12/2012 at 17:35, xxxxxxxx wrote:
              Hi Cairyn,
              I've got to be a little careful of saying what it's for at the moment, as it's being built for a project that is under NDA. There was intentions following this project that an alpha version be made available, and following that a formal public version. Though if it doesn't work in the first place, other software may take it's place. I'm just lucky I have a little bit of time before these decisions are made, and am hence trying to make something of this in the hope of keeping the project in Cinema as much as possible (I'm hoping entirely!).
              But for the purpose of this thread, the plugin would differ from the general polygon object quite a bit in terms of it's main use and the AM layout. For instance with the layout - there is no Basic or Coord tabs or any of the auto generated tabs etc. All the menus are custom built that do specific actions and functions that can replace half a dozen other objects and tags. Possibly more. It's a bit of an all-in-one object if you like. Aimed at keeping the Object Manager cleaner, simpler, and to feel faster and more efficient to work with (as well as some possible functions that don't currently exist). It's not, however, designed to replace the general polygon object as such. It's purpose built for one area of 3D only really. And while you could possibly model a mountain range or a car in it for example, I don't see why you wouldn't do those things with the normal polygon object.
              Probably doesn't help much I know, but can't really say a lot more at the moment 😃 But for the moment, the bottom line is it needs to be it's own polygon object.
              WP.
                On 05/12/2012 at 05:16, xxxxxxxx wrote:
                spedler is correct. You will need to create an Object plugin and it will need to use GetVirtualObjects() to output the resultant polygon object and possibly tags. As explained in the SDK documentation, C4D creates a deform cache of rudimentary objects (polygon objects) which are then passed to the editor or renderer. Even if you create your own 'polygon object' plugin, it still needs GetVirtualObjects() so that it can be deconstructed to the built-in polygon objects. In other words, you can't bypass the built-in object types completely - at some point, the results need to be deconstructable into them. Your object plugin would not be able to be edited like a polygon object unless you want to also write a custom set of tool plugins to allow point/edge/polygon highlighting and editing of various sorts.
                Just to add, while it would be great, one cannot extend the built-in types using plugins. For instance, you cannot derive a plugin from PolygonObject to extend or change it capabilities. You would need to implement it from scratch out of ObjectData - and we've already showed you how that must happen.
                  On 05/12/2012 at 06:59, xxxxxxxx wrote:
                  Hello;
                  hmm, I see... although I must admit that I follow a different philosophy. I am not a fan of "all in one" or "we do it differently" concepts since they tend to either clash with other concepts, or run afoul of future changes. Difficult to say from this vague description, maybe it's something awesome, but in general I like it better if new tools keep the well-known tools and principles of C4D and build on it, instead of going the "almost the same but better and with different menus" route.
                  That said, how about adding a new tag to an arbitrary standard polygon object? For me, tags are a familiar way to enhance the functionality of an object. They can carry a new GUI with new functions, and store any additional values, without disrupting the normal functionality of the polygon object they are attached to.
                    On 05/12/2012 at 17:24, xxxxxxxx wrote:
                    Hmmm,
                    thanks folks. Looks like this isn't going to be possible through an object plugin. Not sure how keen I am to make a GVO object with my own poly selection tools etc. But thanks Rob, something to consider. Will also look at the tag option - something I admittedly haven't put much thought towards - thanks Cairyn.
                    It's really meant as an inhouse proprietory plugin for now, but was thinking along the lines of making it available for others for their feedback in the future if all went well.
                    Is support able to tell us what OBJECT_POLYGON and OBJECT_POINT are for, and when/how they're used?
                    WP.
                      On 06/12/2012 at 09:29, xxxxxxxx wrote:
                      I got information on OBJECT_POLYGON and OBJECT_POINT flags from the developers.
                      The flags are used to allow that an object can carry points or polygons like a regular point or polygon object. The joint object is an example for that: it allows arbitrary geometry.
                      Coupling with OBJECT_GENERATOR will only work in a way where the generator takes the points and polygons as input. Getting both output plus the polymesh rendered at the same time is not possible (as a generator object by definition disappears while its output is visible).
                      If you want to develop a plain point/poly plugin OBJECT_GENERATOR does not need to be set.
                        On 06/12/2012 at 18:21, xxxxxxxx wrote:
                        Hi Yannick,
                        thanks for the clarification - that makes sense. Does that mean though that without the OBJECT_GENERATOR flag, the object is meant to be seen as a 'normal' editable polygon object?
                        Or is there a function (or something - basedraw??) that's meant to be there for this to work? As I can edit my object etc, add polys to it and so on like a normal polygon object, but I just can't see it in the viewport. It renders out fine though.
                        I'd understand if we're not able to access this info. And my apologies if I'm being a pest about it too, but I'd rather find out before going too much further if possible 😃
                        WP.
