    GeDialog Set combo default and hide/show fields
    8 Posts 0 Posters 958 Views
      On 22/11/2012 at 03:15, xxxxxxxx wrote:
      Cinema 4D Version:   13
      Platform:    Mac  ;
      Language(s) :     Phyton ;
      Hi guys, I'm playing with dialogs and trying to figure out some things. With a little searching on forum I ended up having this code in a script, the code kinda works but I can't get a couple things:
      - How do I set the default value (selected option) of a combo box ? .SetLong doesn't seem to work
      - Is It possible to hide/show gadgets (or disable/enable) upon the selected value in a combo box ?
      This is the code:
      from c4d import gui
      def sweep_circle(rad) :
          print "Sweep circolare con raggio = ", rad
      def sweep_square(lato) :
          print "Sweep quadrata lato = ", lato
      class ExampleDlg(gui.GeDialog) :
             def CreateLayout(self) :
                 #create the layout of the dialog
                 self.GroupBegin(999, c4d.BFH_SCALEFIT, 2, 1)
                 self.AddStaticText(1000, c4d.BFH_LEFT, name="Sezione")
                 self.AddComboBox(1001, c4d.BFH_SCALEFIT)
                 self.AddChild(1001,10011,"Circle")
                 self.AddChild(1001,10012,"Square")
                 self.AddStaticText(1002, c4d.BFH_LEFT, name="Radius")
                 self.AddEditNumberArrows(1003, c4d.BFH_LEFT)
                 self.AddStaticText(1006, c4d.BFH_LEFT, name="Edge Lenght")
                 self.AddEditNumberArrows(1007, c4d.BFH_LEFT)
                 self.AddButton(1004, c4d.BFH_SCALE, name="Close")
                 self.AddButton(1005, c4d.BFH_SCALE, name="OK")
                 self.GroupEnd()
             def InitValues(self) :
                 #initiate the gadgets with values
                 self.SetReal(1003, 10, min=0, step=0.1)
                 self.SetReal(1007, 10, min=0, step=0.1)
                 self.SetLong(1001, 1)
             def Command(self, id, msg) :
                 #handle user input
                 if id==1005:
                     if self.GetLong(1001)==10011:
                          rad = self.GetReal(1003)
                          sweep_circle(rad)
                          self.Close()
                     elif self.GetLong(1001)==10012:
                         lato = self.GetReal(1007)
                         sweep_square(lato)
                         self.Close()
                         print "Nessuna sezione"
                         gui.MessageDialog("Seleziona una sezione")
                 elif id==1004:
                     self.Close()
      dlg = ExampleDlg()
      dlg.Open(c4d.DLG_TYPE_MODAL, defaultw=300, defaulth=50) # ASYNC = floating, MODAL = dialogo standard
      What I want is to show Radius field only when Circle option is selected from the combo, and Edge Length only when Square is selected..don't really know if I can do it in a script.
      Any advice would be great ! thanks
      Massimiliano
        On 22/11/2012 at 05:44, xxxxxxxx wrote:
        Hi Massimiliano,
        You add the child with 10011 and 10012 but you set the default value with 1 :
        You should pass 10011 instead.
        You can disable/enable gadgets with GeDialog.Enable().
        It's also possible to build dynamic groups with this sequence:
        GeDialog.LayoutFlushGroup(...) # Removes all gadgets from a group
        GeDialog.GroupBegin(...)
        # Add gadgets
        GeDialog.GroupEnd()
        self.LayoutChanged(...)
          On 22/11/2012 at 05:58, xxxxxxxx wrote:
          Thank for you response Yannick!
          For the combo default, Ok now I'm getting how this works 🙂
          For GeDialog.Enable() I'm a little confused on where should I put it... inside CreateLayout, InitValues or Command ?
          M.
            In both InitValues() (to set the initial state of gadgets) and Command() (to respond to the combo box selection changes) you should call a method of your own named like UpdateGadgets().
            This method would enable or disable the gadgets depending on the combobox selection.
              On 22/11/2012 at 06:45, xxxxxxxx wrote:
              Ok, I will try to make it work 🙂 Thanks
                On 24/11/2012 at 18:44, xxxxxxxx wrote:
                I finally managed to get a dialog...thanks for all the suggestions!
                I have now a dialog with custom 'Ok' and 'Cancel' buttons...but..is there a way to get the OK button pressed when Enter key is pressed on the keyboard ?
                M.
                  On 26/11/2012 at 01:51, xxxxxxxx wrote:
                  Hi Massimiliano,
                  With the SDK you can easily add 'OK' and 'Cancel' buttons to a dialog with GeDialog.AddDlgGroup():
                  self.AddDlgGroup(c4d.DLG_OK|c4d.DLG_CANCEL)
                  This method creates 'OK' and 'Cancel' buttons with IDC_OK and IDC_CANCEL identifiers respectively.
                  To sets the focus to 'OK' button use GeDialog.Activate():
                  self.Activate(c4d.IDC_OK)
                  Finally in Command() you can then filter the buttons:
                  if id==c4d.IDC_OK:
                  	print "OK was pressed"
                  elif id==c4d.IDC_CANCEL:
                  	print "Cancel was pressed"
                    On 26/11/2012 at 12:51, xxxxxxxx wrote:
                    Hi Yannick!
                    Thanks again for your help.
                    This the result of my efforts so far: its a plug-in to sweep multiples splines at once with either circular or square profile..like QuickPipe with a twist 🙂 Surely the code can be improved, but seems to work..
                    import os
                    from c4d import documents, plugins, bitmaps, gui
                    #updated version
                    PLUGIN_ID = 1029425
                    splineList = None
                    def checkObj(obj_list) :
                        spline = 0
                        tot = len(obj_list)
                        for obj in obj_list:
                            tipo = obj.GetTypeName()
                            if (obj.CheckType(c4d.Ospline) or obj.CheckType(c4d.Ospline4side) or
                                obj.CheckType(c4d.Osplinearc) or obj.CheckType(c4d.Osplinecircle) or
                                obj.CheckType(c4d.Osplinecissoid) or obj.CheckType(c4d.Osplinecogwheel) or
                                obj.CheckType(c4d.Osplinecontour) or obj.CheckType(c4d.Osplinecycloid) or
                                obj.CheckType(c4d.Osplineflower) or obj.CheckType(c4d.Osplineformula) or
                                obj.CheckType(c4d.Osplinehelix) or obj.CheckType(c4d.Osplinenside) or
                                obj.CheckType(c4d.Osplineprimitive) or obj.CheckType(c4d.Osplineprofile) or
                                obj.CheckType(c4d.Osplinerectangle) or obj.CheckType(c4d.Osplinestar) or
                                tipo == "MoSpline" or
                                obj.CheckType(c4d.Osplinetext) or isinstance(obj, c4d.SplineObject)) :
                                spline = spline+1
                        if spline < tot :
                            #print "Tutti gli oggetti devono essere splines"
                            return False
                        obj_list = doc.GetActiveObjects(0)
                        if not obj_list:
                            gui.MessageDialog('At least one spline must be selected')
                        elif checkObj(obj_list) :
                            global splineList
                            splineList = obj_list
                            dlg = QuickSweepDlg()
                            gui.MessageDialog('Only splines can be selected')
                    def sweep_circle(rad,originals) :
                        doc=documents.GetActiveDocument()
                        k=0
                        doc.StartUndo()
                        c4d.CallCommand(100004767)
                        for spline in splineList:
                            k=k+1
                            sweep = c4d.BaseObject(c4d.Osweep)
                            sez = c4d.BaseObject(c4d.Osplinecircle)
                            phong = c4d.BaseTag(c4d.Tphong)
                            phong[c4d.PHONGTAG_PHONG_ANGLELIMIT]=True
                            phong[c4d.PHONGTAG_PHONG_ANGLE]=c4d.utils.Rad(80)
                            phong[c4d.PHONGTAG_PHONG_USEEDGES]=True
                            sez[c4d.ID_BASELIST_NAME] = sez.GetName()+"_section"
                            tracciato = spline.GetClone()
                            sez[c4d.PRIM_CIRCLE_RADIUS] = rad
                            sweep[c4d.ID_BASELIST_NAME] = "Sweep_"+spline.GetName()
                            doc.InsertObject(sweep)
                            doc.AddUndo(c4d.UNDOTYPE_NEW,sweep)
                            if originals==True:
                                tracciato.InsertUnder(sweep)
                                tracciato[c4d.ID_BASELIST_NAME] = tracciato.GetName()+"_path"
                                doc.AddUndo(c4d.UNDOTYPE_CHANGE,spline)
                                spline[c4d.ID_BASELIST_NAME] = spline.GetName()+"_path"
                                spline.InsertUnder(sweep)
                            sez.InsertUnder(sweep)
                            sweep.InsertTag(phong)
                        doc.EndUndo()
                    def sweep_square(lato,originals) :
                        k=0
                        doc.StartUndo()
                            k=k+1
                            sez = c4d.BaseObject(c4d.Osplinerectangle)
                            sez[c4d.PRIM_RECTANGLE_WIDTH] = lato
                            sez[c4d.PRIM_RECTANGLE_HEIGHT] = lato
                            if originals==True:
                    class QuickSweepDlg(gui.GeDialog) :
                            def UpdateDlg(self, id) :
                                if id==10011:
                                    self.Enable(1002,True)
                                    self.Enable(1003,True)
                                    self.Enable(1006,False)
                                    self.Enable(1007,False)
                                elif id==10012:
                                    self.Enable(1002,False)
                                    self.Enable(1003,False)
                                    self.Enable(1006,True)
                                    self.Enable(1007,True)
                                self.LayoutChanged(999)
                                self.SetTitle("QuickSweep")
                                self.GroupBegin(999, c4d.BFH_SCALEFIT, 2, 5, groupflags=c4d.BFV_GRIDGROUP_EQUALROWS|c4d.BFV_GRIDGROUP_EQUALCOLS)
                                self.GroupBorderSpace(10, 10, 10, 10)
                                self.GroupBorderNoTitle(c4d.BORDER_ROUND)
                                self.AddStaticText(1000, c4d.BFH_LEFT, name="Section")
                                self.AddCheckbox(1008, c4d.BFH_LEFT, initw=0, inith=0, name="Keep original(s)")
                                self.GroupEnd()
                                self.GroupBegin(998, c4d.BFH_SCALEFIT, 2, 1)
                                self.AddDlgGroup(c4d.DLG_CANCEL|c4d.DLG_OK)
                                #self.AddButton(1004, c4d.BFH_SCALE, name="Close")
                                #self.AddButton(1005, c4d.BFH_SCALE, name="OK")
                                self.GroupEnd()
                                self.SetLong(1001, 10011)
                                self.SetBool(1008, False)
                                self.UpdateDlg(self.GetLong(1001))
                                #handle user input
                                if id==c4d.IDC_OK:
                                        sweep_circle(rad,self.GetBool(1008))
                                        self.Close()
                                       sweep_square(lato,self.GetBool(1008))
                                       self.Close()
                                    self.Close()
                                elif id==c4d.BFM_INPUT:
                                    if msg[c4d.BFM_ACTION_ESC]==True:
                                        print "Action Escaped"
                                        self.Close()
                    class QUICKSWEEP(plugins.CommandData) :
                        pass
                        def Execute(self, doc) :
                        # load icon.tif from res into bmp
                        bmp = bitmaps.BaseBitmap()
                        fn = os.path.join(dir, "res", "QuickSweep.tif")
                        bmp.InitWith(fn)
                        # register the plugin
                        okyn = plugins.RegisterCommandPlugin(id=PLUGIN_ID, str="Quick Sweep", info=c4d.PLUGINFLAG_COMMAND_HOTKEY, icon=bmp, help="Quick sweep multiple splines", dat=QUICKSWEEP())
                        print ""
                        print "-------------- QuickSweep 1.0 by Visualtricks ----------------"
                        if okyn:
                            print "QuickSweep 1.0 initialized "
                            print "Something went wrong - QuickSweep could not initialize"
                        print "----------------------------------------------------------"
                        print ""
                    can be downloaded from here: http://www.visualtricks.it/site/wp-content/uploads/2012/11/QuickSweep1.zip
                    If anyone wants to give any advice, will be appreciated ! 🙂
                    Massimiliano
