    Adding a "Link" object to dialog
    3 Posts 0 Posters 345 Views
      On 19/11/2012 at 19:32, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Platform:    Mac  ;
      Hello
      I am slowly working my way through C++ the C4D way.
      Working on MacOS 10.6 under XCode 4.5. So all my experiments are based on cinema4dsdk and other examples I have found here and elsewhere.
      My question is:
      How do I add a "LINK" field to a dialog?
      Looking at some code from the NoskeWiki below all gadgets are created with "Add..." but going through the documentation I can't find any info on how to add a LINK to a dialog. I know how to put a LINK in a .res file but then have not been successful yet to actually use the data from a res file in a command/tool plugin. I did it in a Expression Plugin. Sorry, this is probably a real rookie question.....
        virtual Bool CreateLayout(void)
          this->SetTitle( "Object Converter" );
          LONG SC_VH = BFH_SCALEFIT | BFV_SCALEFIT;
          GroupBorderSpace( 10, 10, 10, 10 );
          GroupSpace(5,5);
          AddStaticText   (DLG_LBL1, BFH_LEFT,0,0, "This plugin helps ready, clean and reduce models for export to programs ", BORDER_NONE);
          AddStaticText   (DLG_LBL2, BFH_LEFT,0,0, "like Unity. Click 'Help' for more info.", BORDER_NONE);
          AddStaticText   (DLG_LBL3, BFH_LEFT,0,0, "", BORDER_NONE);
          GroupBegin( DLG_GRP2,SC_VH,2,0,"actions based on object names:",BFV_GRIDGROUP_EQUALROWS );
            GroupBorder(BORDER_WITH_TITLE|BORDER_THIN_IN);
            GroupBorderSpace( 5, 5, 5, 5 );
            GroupSpace(3,3);
            //AddSeparatorH   (SC_VH);
            AddStaticText   (DLG_LBL4, BFH_LEFT,100,0,"action:", BORDER_NONE);
            AddStaticText   (DLG_LBL5, BFH_LEFT,30,0,"text", BORDER_NONE);
            AddCheckbox     (DLG_CHK_DEL1,   SC_VH,100,0,"delete objects containing:");
            AddEditText     (DLG_EDIT_DEL1STR, SC_VH,30,0);
            AddCheckbox     (DLG_CHK_TURNON,  SC_VH,0,0,"make visible objects \" \" \" \" \" \" \" \":");
            AddEditText     (DLG_EDIT_TURNONSTR,SC_VH,0,0);
        On 19/11/2012 at 23:25, xxxxxxxx wrote:
        // As a member of your class, for instance
        LinkBoxGui*    myLinkBox =    NULL;
        // In GeDialog.CreateLayout()
        BaseContainer    tbc;
        tbc.SetBool(LINKBOX_HIDE_ICON,        FALSE);
        myLinkBox =    (LinkBoxGui* )AddCustomGui(MY_LINK_BOX_ID,CUSTOMGUI_LINKBOX,String(),BFH_SCALEFIT|BFV_SCALEFIT,0L,0L,tbc);
        if (!myLinkBox)        return FALSE;
        // GeDialog.Message
        LONG IPPDialog::Message(const BaseContainer& msg, BaseContainer& result)
          //GePrint(BaseContainerToString(msg));
          LONG    mid =    msg.GetId();
          if        (mid == BFM_DRAGRECEIVE)        return Msg_DragReceive(msg, result);
          return GeDialog::Message(msg, result);
        // IPPDialog.Msg_DragReceive - BFM_DRAGRECEIVE
        // - How to verify and accept what is being dropped into the LinkBox
        LONG IPPDialog::Msg_DragReceive(const BaseContainer& msg, BaseContainer& result)
          // LinkBox
          if (!CheckDropArea(MY_LINK_BOX_ID, msg, TRUE, TRUE))    return GeDialog::Message(msg, result);
          if (msg.GetLong(BFM_DRAG_LOST))                            return GeDialog::Message(msg, result);
          LONG        cursor =    MOUSE_POINT_HAND;
          LONG        type =        0L;
          void*        object =    NULL;
          BaseObject*    op =        NULL;
          GetDragObject(msg, &type, &object);
          if ((type == DRAGTYPE_ATOMARRAY) && (((AtomArray* )object)->GetCount() == 1L) && ((AtomArray* )object)->GetIndex(0))
              op =    (BaseObject* )((AtomArray* )object)->GetIndex(0L);
              // Add whatever restrictions here (such as only allowing Spline objects, for instance)
              if (op->IsInstanceOf(Obase))    cursor = MOUSE_INSERTCOPY;
              else
                  cursor =        MOUSE_FORBIDDEN;
                  op =            NULL;
          if (msg.GetLong(BFM_DRAG_FINISHED))        myLinkBox->SetLink(op);
          return SetDragDestination(cursor);
          On 26/11/2012 at 18:48, xxxxxxxx wrote:
          Thanks for posting this code!
          Sorry I am a bit late. Was out of town over Thanksgiving.
          I'll try this out later tonight.
          Peter
