    How do I return / get the values from a dialogbox?
    4 Posts 0 Posters 484 Views
      On 15/11/2012 at 07:52, xxxxxxxx wrote:
      How do I return the values from a dialogbox.
      I tried to set the var globaly and edit it but no luck.
      thanks in advance
      kind regards mogh
      from c4d import gui
      variablebox = 0.4 # unnecessary ???
      GROUP_ID1=1000
      TEXTBOX=1001
      BUTTON1=1002
      BUTTON2=1003
      class ExampleDlg(gui.GeDialog) :
          def CreateLayout(self) :
              #creat the layout of the dialog
              self.GroupBegin(GROUP_ID1, c4d.BFH_SCALEFIT, 3, 1)
              self.AddEditText(TEXTBOX, c4d.BFH_SCALEFIT)
              self.AddButton(BUTTON1, c4d.BFH_SCALE, name="Start")
              self.AddButton(BUTTON2, c4d.BFH_SCALE, name="Close")
              self.GroupEnd()
          def InitValues(self) :
              #initiate the gadgets with values
              self.SetString(TEXTBOX, "0.1")
          def Command(self, id, msg) :
             #handle user input
              if id==BUTTON1:
                  variablebox = self.GetString(TEXTBOX) #here is something wrong <-----
                  self.Close()
              elif id==BUTTON2:
                  self.Close()
      dlg = ExampleDlg()
      dlg.Open(c4d.DLG_TYPE_MODAL, defaultw=500, defaulth=80)
      def main(undo = True) :
          print variablebox #here is something wrong <-----
        On 15/11/2012 at 08:37, xxxxxxxx wrote:
        To get values from your dialog after it's closed you should declare them as member variables in your dialog's class.
        Also, there's something inconsistent here: if you want to get a float value it's better to create a float field with AddEditNumberArrows() for example.
          On 16/11/2012 at 03:07, xxxxxxxx wrote:
          Hm what are member variables? can you give an example how to implement them?
          I tried with "return variablebox" and setting the var in the class as a default which seems to work but i cant overwrite it. or returning the newly set variablebox ....
          thanks in advance
          mogh
            On 16/11/2012 at 03:32, xxxxxxxx wrote:
            self.variablebox = self.GetReal(TEXTBOX)
            was my mistake ... got it thanks
