    Custom Member Crashes
    3 Posts 0 Posters 310 Views
      On 15/11/2012 at 07:38, xxxxxxxx wrote:
      Cinema 4D Version:   14
      Platform:      Mac OSX  ;
      Hallo,
      I have a problem with a Tag Plugin, which is crashing if I delete an unnecessary Variable from the Header. So I came to thinking that I might be doing something that is forbidden anyway. My header looks like this:
      class TransferTag : public TagData
          private:
              BaseContainer ChangesBC; //unnecessary BaseContainer
              CTransfer * CTrans; //custom class
              Real AreaRadius;
              virtual void Free(GeListNode* node);
              static NodeData *Alloc(void) { return gNew  TransferTag; }
              CTransfer * GetTransfer(BaseObject * Asker, Real Radius); //custom member function
      The function "GetTransfer" is called by other Plugin Objects and returns *CTrans from private. Is it allowed to do so?
      Jonnz
        On 15/11/2012 at 10:00, xxxxxxxx wrote:
        Hi Jonnz,
        yes it is allowed. Have you recompiled all other files that reference your plugin? The relative
        memory location of the *CTrans has changed and object files that were
        compiled with previous version reference it from the wrong position. Although you are not
        accessing the attribute directly, but through a function call, there may be the possibility the
        compiler has inlined the function (depending on your compiler options).
        I currently can't think of another reason.
        Best,
        Niklas
          On 15/11/2012 at 13:16, xxxxxxxx wrote:
          Hi Niklas,
          thanks for your help. I'm happy to know that it's allowed to do that, so I can keep working.
          Since I have cleaned the project several times and checked if the compiler is inlineing the function, I guess the problem must lie somewhere else.
          Regards
          Jonnz
