    find out if generator object?
    3 Posts 0 Posters 640 Views
      On 08/11/2012 at 08:28, xxxxxxxx wrote:
      Hi There,
      generator objects have a green hooklet next to the visibility indikator lights in the object manager. (for exapmle array, cloner but also cube or deformer).
      I found out that you can activate and deactivate them with:
      BaseObject.SetDeformMode(mode)
      and read them with
      BaseObject.GetDeformMode(mode)
      I was surprised to see that you also can set and read this parameters if an object doesnt habe the hooklet (for example a polygonobject)
      2 questions:
      - is it bad to set the deformmode to False (standard is True) if the object has no hooklet (for example a polygonobject)
      and if so:
      - is there a easier way do distinguish between them (generator not generator) than to compare it to a list of object types?
      thanks a lot
      Jops
        On 08/11/2012 at 11:31, xxxxxxxx wrote:
        1. I don't know but shouldn't think so
        2. call GetInfo() on the object and test for the flag OBJECT_GENERATOR
        In C++:
        if(obj->GetInfo( ) & OBJECT_GENERATOR)
        // it is a generator...
        else
        // it isn't a generator
        Note that primitive objects such as the Cube are also generators so the flag is set for such objects. If this matters you will have to test against a range of objects to exclude those you don't want. Or, you can also test for the flag OBJECT_INPUT - any generator which accepts another object as its input will have this set (e.g. the HyperNURBS) but the Cube etc. primitives will not.
          On 09/11/2012 at 01:55, xxxxxxxx wrote:
          Hi Spedler,
          thanks a lot your C++ code is nearly exactly the python code:
          if obj.GetInfo() & c4d.OBJECT_GENERATOR:
              print "a generator"
              print "not a generator"
          works perfect as far as I can see
          thanks again.
          Jops
