    plugin tag works just for 1 object
    19 Posts 0 Posters 2.6k Views
      On 07/11/2012 at 08:13, xxxxxxxx wrote:
      (you're missing prefixes for TIMELINEONOFF and CAMONOFF).
      so they are suppoed to be named TTIMELINEONOFF and TCAMONOFF
      as they are used in a tag?
      best wishes
      Jops
        On 07/11/2012 at 11:58, xxxxxxxx wrote:
        Hi Jops,
        _
        > >> I know, that my code looks awfull._
        Well, you're learning, as everyone here is. You'll write more clear code by time for sure.
        > >> I still have problems of understanding classes, initialistaion and the rest of this objectbased
        >>> stuff.
        I can really really recommend the official Python tutorial. It allows you to dive in very quickly. It
        is easy to understand and starts from bottom up. Once I was starting out with Python, I read it
        although I have been trying to write Python for about a month already (and had over a year
        experience with COFFEE). It helped me a lot understanding the mechanisms of Python and of
        OOP programming in general.
        _> >> I now use the method, as you said (was it wrong the way I did it (it wasnt object oriented
        >>> right?)) _
        Not necessarily because of that reason (it actually was kind of OOP, however), but it is
        1. easier to read
        2. I don't know about the internals of Py4D, but it could be possible that there is a reason
          the method was implemented (either just for convenience, or maybe it does some
          additional actions).
        > >> for the naming conventions... I will have a look at them, thats a good thing. _
        It's not just for making it easier to read (because you immediately know what the symbol
        belongs to), but also prevents naming collisions (as I stated in the thread linked above).
        _
        > >> my execute is just a shortend version (as mentioned)
        I must have missed that, sorry. 😉
        > >> and unfortunately havent seen a answer to it in your post 😞
        That is due to the fact that there was no direct answer in my post. 😛 I think the problem lies
        in the Execute() method, therefore it's a good thing that you have posted the complete code
        now. As I didn't read it was the "shortened" version, I was wondering if this is really the complete code.
        No. Symbols in Cinema 4D are prefixed with what they belong to (also mentioned in the thread
        linked above). Like MSG_~, PRIM_~, COLOR_~, SPLINECONTROL_~. Therefore, it is recommended
        to prefix your symbols with PLUGINNAME_~. This avoids name-collisions and is easier (especially
        for others) when reading your code.
        Description-symbols are embedded into the c4d module (that's why names can collide). When your
        plugin is installed, you can do "print c4d.TIMELINEONOFF" for example, and it will yield 1001 in
        the console.
        Unfortunately I currently cannot see the issue directly from the code. Is it possible that
        you upload the complete plugin-folder (including resource files) somewhere? If you want, I can
        try to find the issue and correct your code.
        Just FYI, the way you store the information (frame, offset, zoom) is not OOP style. 😉
        Best,
        Niklas
          On 08/11/2012 at 01:56, xxxxxxxx wrote:
          Hi Niklas,
          thanks a lot for this response. kind words and good information
          thanks to your information I now understand the need of prefix naming for Symbols and corrected them in the code.
          I uploaded everything adn sent you the link via PM
          also best
          Jops
            On 09/11/2012 at 01:43, xxxxxxxx wrote:
            Hi Jops,
            I've recieved the message, thank you.
            It's rather simple, but it didn't occurr to me earlier. As I already said, the
            way you store the frame, offset and zoom data is not OOP style. And that is
            actually why your plugin doesn't behave the way you want it.
            When tags are executed in Cinema 4D, they are invoked one after another. (Ok,
            sometimes even parallel, but not every tag at once!) When the tag on the first
            object is being executed, it does its stuff and checking, etc. AND (now comes
            the fatal thing) : It sets the global information of the last frame, offset and zoom.
            The problem here is the word global. When the first tag was executed,
            the frame, offset and zoom values are already updated, and therefore, all other
            tags will work on different data than the first tag.
            However, it's rather easy to solve. In general, it's considered
            bad style using globals in Python (and many other languages as well). They
            cannot be ommited sometimes, but their use can be reduced.
            You can imagine the current situation like the following : Every tag is a pupil
            in school, and they all have to do the same task.
            - What you are doing, is let them solve it on the chalkboard. And after the
              first pupil has solved it, all other pupils don't have to do it anymore.
            - What a teacher should do, if all pupils must do the work on their own, is
              to give each pupil their own sheet.
            Transferred to the world of OOP programming: Store the information in the
            Tag-instance instead of in the global scope.
            class TagPlugin(c4d.plugins.TagData) :
              def __init__(self) :
                  super(TagPlugin, self).__init__()
                  self.last_frame = -1
                  # etc..
              def Execute(self, tag, doc, op, bt, priority, flags) :
                  frame = doc.GetTime().GetFrame(doc.GetFps())
                  if frame != self.last_frame:
                      self.last_frame = frame
                  # etc..
            Some other notable things:
            - visible = 1, Rather use a boolean, like visible = True
            - Rather use implicit boolean checking, like if not visible:
            - I personally prefer spaces rather than tabs. This way, you have more control
              over the look of your code.
            - Class names are usually CamelCase. It's not a must, but widely accepted in
              the community.
            - It's very unusual to write variable-names CamelCase with the first letter
              being uppercase. CamelCase with starting with a lowercase letter (mostly found
              in Java) or even underscore separated variable names (and all lowercase, the
              more Pythonic way) are more conform.
            - As I already stated, you don't have to define your description symbols in the
              plugin-file. They are embedded in the c4d module. You can
              write data.GetBool(c4d.FSPA_TIMELINEONOFF).
            See the PEP8 for information about the Python style-guideline
            (which, again, is not a must, just a guideline).
            Best,
            Niklas
              On 09/11/2012 at 02:04, xxxxxxxx wrote:
              Hi Niklas,
              wow fantastic response! thanks you.
              it will take a while till I got my head around this all (and corrected it in the code 🙂
              best regards
              Jops
                On 09/11/2012 at 04:59, xxxxxxxx wrote:
                Hi Niklas,
                again thanks a lot. I managed to make all the corrections but
                data.GetBool(c4d.FSPA_TIMELINEONOFF) doesnt work... I dont think that ists a big problem. i will just stick to the way I got it working 🙂
                now I will integrate some more features and userdata.
                I am quite hopefull that I can handle it from here. my plan is to make the plug public in the near future on my website.
                never the less, if you want to have a look at the final code...I will send it to you.
                I hope to get done today 🙂
                best regards
                Jops
                  On 09/11/2012 at 05:27, xxxxxxxx wrote:
                  Hi Jops,
                  Sorry, forgot to tell you about it. 🙂 That may be due to the symbolcache Cinema 4D generates. If
                  you change your plugin resource, Cinema might not be able to detect this and the symbolcache
                  won't change. The symbols in this file are loaded and then embedded into the c4d module, instead
                  of parsing all resources once again (which would delay startup time). You can manually delete the
                  file from your plugin while developing, but make sure your plugin does not delete it when you have
                  released it.
                  The file is located at %appdata%/MAXON/Cinema 4D RXX/prefs. It is called coffeesymbolcache in
                  R12 and symbolcache in R13+.
                  Best,
                  Niklas
                    On 12/11/2012 at 03:16, xxxxxxxx wrote:
                    Hi Niklas,
                    but then it seems to me that handling the way I do is more stable?
                    if I release a new version of the plugin I have to take care about the cache on every computer the former version was installed?
                    best regards
                    Jops
                      On 12/11/2012 at 03:58, xxxxxxxx wrote:
                      Hi Niklas,
                      my plugin is not running on the renderfarm 😞
                      is there something I have to care about?
                      I uploaded the current version.
                      best regards
                      Jops
                        On 12/11/2012 at 04:01, xxxxxxxx wrote:
                        ok maybe I have to explain something... that might be the root of the problem.
                        I have to find out If the scene is rendered in the picturefiewer or in the editorview. therefor I check:
                        if doc == documents.GetActiveDocument() :
                        this works fine for the picturemanager and the editor view but maybe not for the renderfarm.
                        the plugin is installes on every client.
                        best regards
                        Jops
                          On 12/11/2012 at 07:42, xxxxxxxx wrote:
                          You should get the correct doc with:
                          doc = mytag.GetObject().GetDocument()
                          Lennart
                            On 15/11/2012 at 05:44, xxxxxxxx wrote:
                            Thanks lennart,
                            that was by the way something I was looking for, as GetOrigin doesnt work for a plugin 🙂
                            but:
                            I actually was looking for a possibility to find out if the szene is rendered in the pictureviewer, the renderfarm or the editorview.
                            this little function works good for the editor and pictureviewer, but not for the netrender (unfortunately 😞
                                      def is_render() :
                                           # find out if rendered in Pictureviewer
                                                return False
                            best regards
                            Jops
                              On 15/11/2012 at 06:18, xxxxxxxx wrote:
                              ok one step further:
                              this code works for pictureviewer and batchrender but not for netrender 😞
                                        def is_render() :
                                             # find out if rendered in Pictureviewer, batchrender and net
                                             if c4d.documents.GetBatchRender().IsRendering() : # finds out if batchrender
                                                  return False
                                             if doc == documents.GetActiveDocument() : # finds out if pictureviewer
                                                  return False
                              so maybe someone knows how I can find out If the scene is rendering with netrender?
                              thanks a lot
                              Jops
                                On 15/11/2012 at 08:12, xxxxxxxx wrote:
                                Have you tried to call c4d.CheckIsRunning(c4d.CHECKISRUNNING_EDITORRENDERING) and c4d.CheckIsRunning(c4d.CHECKISRUNNING_EXTERNALRENDERING)?
                                  On 16/11/2012 at 01:29, xxxxxxxx wrote:
                                  Hi Yannick,
                                  thanks again. unfortunately I didnt find it in the SDK searching for render and rendering 😞
                                  but now you told be 🙂 thanks
                                  not working ... but I dont need it anyway
                                  working for pictureviewer and netrender but not for batchrender
                                  so to include batchrender the function looks loke this:
                                            def is_rendering() :
                                                 if c4d.CheckIsRunning(c4d.CHECKISRUNNING_EXTERNALRENDERING) or c4d.documents.GetBatchRender().IsRendering() :
                                                      return False
                                  it seems to work. great!
                                  thank you all for the help
                                  Jops
                                    On 17/11/2012 at 03:22, xxxxxxxx wrote:
                                    again... thanks a lot to all that helped me.
                                    I published the Plugin Fs_preview_accelerator on my website.
                                    http://www.webarts.net (english button is in the upper right corner.
                                    best regards
                                    Jops
