    Hide/Unhide GeDialog Gizmos?
    2 Posts 0 Posters 444 Views
      On 06/11/2012 at 12:48, xxxxxxxx wrote:
      Cinema 4D Version:   13
      I'm trying to hide/unhide gizmos in a GeDialog. But once they are hidden I can't manage to bring them back again.
      Here's my button code that calls the hide/unhide for a gizmo
      Hide works fine. But the unhide code does not work:
          switch (id)
            case MY_BUTTON_HIDE:
                HideElement(MY_GIZMO, TRUE);       //Tell C4D to hide this gizmo
                LayoutFlushGroup(GIMO_GROUP_ID);   //Redraw the gizmo's group reflecting the changes
                LayoutChanged(GIMO_GROUP_ID);      //Tell C4D the GeDialog has changed
                break;
            case MY_BUTTON_UNHIDE:
                HideElement(MY_GIZMO, FALSE);
                LayoutFlushGroup(GIMO_GROUP_ID);  //<--This code block does not bring the gizmo back!?
                break;
      Do I need to use a gadget *ptr for this?
      The docs show an example how to create a gadget ptr
      C4DGadget* ptr = dlg.AddStaticText(123, ...); // Generates GadgetPtr(123)
      Which I'm assuming is placed inside the CreateLayout() method?
      But then I'm unclear how to actually use this new ptr.
      Normally I would create a ptr like this as a class member variable so it's available for use in all the methods in my plugin. But the way it's written in the docs it appears to be created as a local CreateLayout() variable.
      So I don't know how to actually use that ptr in my Command() method where my buttons code is?
        On 06/11/2012 at 16:51, xxxxxxxx wrote:
        Doh!
        Nevermind. I found what I was doing wrong.
        By using LayoutFlushGroup() when hiding the gizmo. I am basically deleting the gizmo from the dialog. So it has no way of returning back to where I started from when I choose to unhide it.
        So the code needs to be like this:
            switch (id)
                  LayoutChanged(GIZMO_GROUP_ID);     //Tell C4D the group this gizmo is in has changed
                  break;
                  HideElement(MY_GIZMO, FALSE);     //Tell C4D to unhide this gizmo
                  break;
        The way the docs are written. It sort of led me to believe that we had to use Flush to hide/unhide gizmos.
        But that's not the case.
