    longitude / latitude on sphere
    6 Posts 0 Posters 838 Views
      On 27/10/2012 at 16:17, xxxxxxxx wrote:
      Below is a piece of that I used to convert longitude / latitude to sphere coordinates.
      However, it is not working and I cannot see what I do wrong.
      Input e.g. New York lat=40.714, lon=-74.606 and radius=100
      longitude = c4d.utils.Rad(lat)
        latitude = c4d.utils.Rad(lon)
        x = radius * math.cos(latitude)*math.cos(longitude)
        y = radius * math.cos(latitude)*math.sin(longitude)
        z = radius * math.sin(latitude)
        sphereobj = c4d.BaseObject(c4d.Osphere)        # Create new sphere
        sphereobj[c4d.PRIM_SPHERE_RAD] = 20            # set sphere label radius
        sphereobj.SetRelPos(c4d.Vector(x,y,z))         # Set position of sphere
        doc.InsertObject(sphereobj)
        On 28/10/2012 at 13:51, xxxxxxxx wrote:
        Can you be more specific about what "not working" means?
        I tried it like this and it seems to be working as expected:
        import math
          lat = 40.714
          lon = -74.606   #New York
          radius=100
          sphereobj.SetName("NY")                        #Set the name of the sphere
          On 28/10/2012 at 15:02, xxxxxxxx wrote:
          Hi pgroof,
          here's a function I used in a plugin I made for a client.
          def llarToWorld(lat, lon, alt, rad) :
            # see: http://www.mathworks.de/help/toolbox/aeroblks/llatoecefposition.html
            f  = 0                              # flattening
            ls = atan((1 - f)**2 * tan(lat))    # lambda
            x = rad * cos(ls) * cos(lon) + alt * cos(lat) * cos(lon)
            z = rad * cos(ls) * sin(lon) + alt * cos(lat) * sin(lon)
            y = rad * sin(ls) + alt * sin(lat)
            return c4d.Vector(x, y, z)
          -Nik
            On 29/10/2012 at 03:36, xxxxxxxx wrote:
            ScottA, thanks, triggered by your remark I tried again.
            Changing y = -y + set the globe tp -90,90,-90 helped.
            It is ok now.
            Hi NiklasR, yes, what you are using is the flattened version of the algorithm.
            Thanks for your help.
              On 29/10/2012 at 03:37, xxxxxxxx wrote:
              Sorry,
              should be
              Changing y = -y + set the globe to -90,90,-90 helped.
                On 29/10/2012 at 03:39, xxxxxxxx wrote:
                Or even better (I'm missing the edit function here) :
                Changing y to -y (y=-y) and setting the rotation of the globe to -90,90,-90 solved the issue.
