    Combobox in Combobox in python
    7 Posts 0 Posters 792 Views
      On 24/10/2012 at 03:41, xxxxxxxx wrote:
      How to define a combobox in a combobox using Python?
      See for example the Physical Sky > Time and Location > City GUI.
        On 24/10/2012 at 06:33, xxxxxxxx wrote:
        Are you talking about having a popup menu displayed when we click on the combo?
        If you take a look at the description of the Physical Sky ( modules\advanced render\sky\res\description\oskyshader.res ) you can see that the City combo is defined as:
        LONG SKY_POS_CITY_COMBO
            PARENTCOLLAPSE;
            CUSTOMGUI SKY_II_CITYLIST;
            ANIM OFF;
        So you can see that it's made with custom gadget; unfortunately it's not possible to develop custom GUIs with the Python SDK, only in C++.
        Or are talking about the collapsing of City parameter?
        In its declaration you can see PARENTCOLLAPSE flag and Time Zone attribute is declared with PARENTCOLLAPSE SKY_POS_CITY_COMBO to tell CINEMA his collapse parent:
        LONG SKY_POS_TIMEZONE
            PARENTCOLLAPSE SKY_POS_CITY_COMBO;
            CYCLE
                SKY_POS_TZ_OS;
                SKY_POS_TZ_CUSTOM;
          On 24/10/2012 at 06:54, xxxxxxxx wrote:
          What I mean is that like the City comboboxx in the Physical Sky, first select the continent, that displays another combobox with all countries on that continent.
          Then select a country, that displays all cities in that country.
          I'm sorry, I do not understand what you mean with "collapsing of City parameter"?
            This is a dynamic popup menu calculated by the custom GUI.
            I'm referring to the parameters that you can show or hide below City parameter.
              On 24/10/2012 at 12:02, xxxxxxxx wrote:
              Ok, clear.
              Do you have an example of such a popup menu?
              Sorry, I see you just told me
              "unfortunately it's not possible to develop custom GUIs with the Python SDK, only in C++."
                Ok, clear.
                No, I just said that we can't build custom gadgets in Python but we can of course create dynamic popup menus.
                Here's an example of a recursive popup dialog:
                from c4d import gui
                def BuildMenuRecursive(menu, level, maxlevel) :
                    offset = 10*level
                    menu.SetString(c4d.FIRST_POPUP_ID+offset,   'Item '+str(offset+1))
                    menu.SetString(c4d.FIRST_POPUP_ID+offset+1, 'Item '+str(offset+2))
                    level += 1
                    if level==maxlevel:
                        menu.SetString(c4d.FIRST_POPUP_ID+offset+2, 'Item '+str(offset+3))
                        submenu = c4d.BaseContainer()
                        submenu.SetString(1, 'Item '+str(offset+3))
                        BuildMenuRecursive(submenu, level, maxlevel)
                        menu.SetContainer(c4d.FIRST_POPUP_ID+offset+2, submenu)
                    menu.SetString(c4d.FIRST_POPUP_ID+offset+3, 'Item '+str(offset+4))
                # Build main menu recursively
                # With a maximum of 5 menus
                BuildMenuRecursive(menu, 0, 5)
                # Show popup dialog
                result = gui.ShowPopupDialog(cd=None, bc=menu, x=300, y=300)
                print result
                  On 27/10/2012 at 16:11, xxxxxxxx wrote:
                  Thanks, I'll give it a try.
