    Serial check - how ?
    13 Posts 0 Posters 1.2k Views
      On 18/10/2012 at 07:35, xxxxxxxx wrote:
      Hello Forum,
      we would like to protect our Python script.
      How do we get the serial number out of C4D, so that we can limit the Script to our customers?
      Some code snippets would be appreciated...
      Kind regards,
      Ronald
        On 18/10/2012 at 08:35, xxxxxxxx wrote:
        Scripts (expressions and Commands) cannot be protected. You need to make plugins of them to -somewhat- protect
        them using the Scripts ->"Source Protector..." command in Cinema.
          On 18/10/2012 at 10:26, xxxxxxxx wrote:
          Das muss gehe!
          from c4d import gui
              gui.MessageDialog('Hello World!')
          si = c4d.GeGetSerialInfo(c4d.SERIALINFO_MULTILICENSE)
              if len(si['nr']) > 0:
                  # Multi-license, do something
                  print "Multi-license"
                  print si
                  si = c4d.GeGetSerialInfo(c4d.SERIALINFO_CINEMA4D)
                  print "Single-license"
                  print si
                  # Single-license, do something
          Thit code works fine!
          But:
          I need te eleven digits from the right
          like in EXCEL "right(si,11)".
          This could be compaired with something.
          If the result is "true" the Phyton-Script would be executet.
          With the Souce-protector the Script should be protected.
          Kind regards
          Ronald
            On 18/10/2012 at 10:46, xxxxxxxx wrote:
            Hi, as tcastudios said only Python Plugins can be protected. Scripts can not be encrypted.
            Cheers, Sebastian
              On 18/10/2012 at 10:51, xxxxxxxx wrote:
              Ok,
              Thanks a lot.
              This ist the reason why it dosen't work!
              So I have to translate my Script to a Plugin.
              I think questions will follow
                On 22/10/2012 at 06:09, xxxxxxxx wrote:
                Everything in my plugin works greate
                Only on last Problem:
                The serialchek never turns to the ok???
                I've filtert the serialnumber,only the 11 numbers to a varriable.
                Then i Compare it with a number.
                But it never runs through the "true" - part
                Could it be that I compare a sting with a number?
                How can I solve the problem?
                Thanks to all here
                import math
                import os
                from c4d import documents, plugins, bitmaps
                PLUGIN_ID = 1000000
                SERIENNUMMER = 'hier muss zum Testen die eigene Seriennummer eingegebenwerden'
                def check_serialinfo() :
                    sn = si['nr']
                    print sn
                    print SERIENNUMMER
                    if (sn == SERIENNUMMER) :# !!! here is the problem!!!
                        print 'ok'
                        print 'not ok'
                    print 'Seriennummerncheck beendet'
                class MYPLUGIN(plugins.CommandData) :
                pass
                def Execute(self, doc) :
                        check_serialinfo()
                    # load icon.tif from res into bmp
                    bmp = bitmaps.BaseBitmap()
                    fn = os.path.join(dir, "res", "icon.tif")
                    bmp.InitWith(fn)
                    # register the plugin
                    okyn = plugins.RegisterCommandPlugin(id=PLUGIN_ID, str="V4D-Seriennummerncheck", info=c4d.PLUGINFLAG_COMMAND_HOTKEY, icon=bmp, help="", dat=MYPLUGIN())
                    print " "
                    print "----------------------------------"
                    print "Seriennummernchek ", okyn
                  On 22/10/2012 at 06:19, xxxxxxxx wrote:
                  Well, according to how I read your code, you're comparing the variable 'sn' which is a string to the string constant 'SERIENNUMMER' which is a different string. So it will always fail.
                  What you should be doing is taking the plugin serial number your user entered and somehow getting the C4D serial out of that so you can compare it to 'sn'. How you do that depends on how you generated the serial number in the first place, and only you know that. But you would normally generate a plugin serial from the 11 digits of the user's C4D serial which they send you when they buy a licence.
                  Of course, f you are going to give this plugin away then you don't need to do any serial checking at all.
                    On 22/10/2012 at 06:27, xxxxxxxx wrote:
                    Hi Spedler,
                    you are wright.
                    I want to type my serial number in the variable at the beginning.
                    Then ich want to compare it with the serialnumber of my license.
                    The print sn and print SERIENNUMMER shows the same values in the console.
                    But: the compare (sn == SERIENNUMMER) retuns a false!!!
                    Do you know why?
                    Thanks a lot
                      On 22/10/2012 at 06:37, xxxxxxxx wrote:
                      Beats me then, sorry. I don't use Python but I would have thought that your code should work.
                        On 22/10/2012 at 06:41, xxxxxxxx wrote:
                        Hi spedler,
                        thats the problem
                        Beleave me! It dosn't work
                        But why???
                          On 22/10/2012 at 07:11, xxxxxxxx wrote:
                          Ok, i found something:
                          one is string and one is long!
                          So: how can I check the type of a varriable and how can I convert it.
                          Thanks a lot
                            On 22/10/2012 at 09:34, xxxxxxxx wrote:
                            The serial number returned by GeGetSerialInfo returns a string, so you either have to declare the SERIENNUMMER variable as a string (by putting the digits in quotes) or you can typecast sn to an integer with int(sn).
                            I recommend the latter.
                            SERIENNUMMER = 14300012345
                                sn = si['nr']
                                print sn
                                print SERIENNUMMER
                                if (int(sn) == SERIENNUMMER) :# !!! here was the problem!!!
                                    print 'ok'
                                    print 'not ok'
                              On 23/10/2012 at 00:12, xxxxxxxx wrote:
                              Thanks to Sparkle,
                              it works now greate.
                              slowly but shurly I will learn how to use Phyton in C4D.
                              Thanks a lot again
