    Plugin ID Collisions
    14 Posts 0 Posters 1.4k Views
      On 10/10/2012 at 22:15, xxxxxxxx wrote:
      inside your *.xcodeproj folder (yes, it's a folder, osx just hides it from you) there's a project.pbxproj. I always do a string replace of "cinema4dsdk" with my project title when i copy the project files from the sdk. That way i'm sure there is no name conflict.
      I don't really remember which occurrence caused that problem for me, so i replace all to be safe 😉
      You can also just try and replace all occurrences of "cinema4dsdk" in your project tree
        On 10/10/2012 at 23:28, xxxxxxxx wrote:
        Also search for "Product Name" in your Xcode project settings and change it to something unique. I've had the same problem some years ago where SurfaceSPREAD would collide with other plugins even though it had a unique ID. Changing the product name helped for some weird reason that only Xcode fans understand ^^
          On 11/10/2012 at 09:58, xxxxxxxx wrote:
          Thanks to both of you, I've got them working now. I would never have looked inside the xcodeproj to try to fix it.  Thanks a ton.
          Also, I saw a couple threads about SetCallBackURL but none of them had answers, does any one know how it interacts with a HTML custom gui?  Can you get feedback back from it with SetCallBackURL?
          Dan
            On 15/10/2012 at 03:41, xxxxxxxx wrote:
            Hi Dan,
            The URL callback is called whenever a new URL has been selected, either if the user clicked on a link or if the plugin programmer calls HtmlViewerCustomGui::SetUrl(). In the callback you then have access to the string URL of the new page and information on the string encoding.
              On 15/10/2012 at 08:39, xxxxxxxx wrote:
              Thanks, Yannick.
              What I'm mainly confused about is the syntax for calling the function. Would I do:
              //virtual Bool CreateLayout(void)
                     viewer = AddCustomGui(DIALOGID, CUSTOMGUI_HTMLVIEWER, "pyBROWSER", BFH_SCALEFIT|BFV_SCALEFIT, 512, 250, bc);
                    HtmlViewerCustomGuiURLCallback callback;
                    HtmlViewerCustomGui* view;
                    view = (HtmlViewerCustomGui* )viewer;
                    view->SetURLCallback(callback, <#void *user_data#>)
                    view->SetUrl("https://www.google.com/", URL_ENCODING_UTF16);
              If that's right, what would userdata be in this circumstance?
              And how would I set up the call to that callback?
              Dan
                On 15/10/2012 at 09:36, xxxxxxxx wrote:
                A callback is a function, so here's how you can define it for the HtmlViewerCustomGui:
                void htmlViewerCallback(void* user_data, const String& url, LONG encoding, void* reserved)
                    GePrint(url);
                    htmlViewer->SetURLCallback(htmlViewerCallback, NULL);
                The user data is used to have a custom object accessible in the callback so you can set it to NULL if you don't need it. The user data could be set to htmlViewer if you want to access the HtmlViewerCustomGui from the callback for example.
                  On 15/10/2012 at 13:10, xxxxxxxx wrote:
                  Thank again Yannick.
                  Should I be able to just cop and paste that?  I've been trying to get it working but I've been getting an error saying that there's "no function call to SetURLCallback(<unresolved overloaded function>,Null)".
                  I've been reading though your last post here, but I haven't had any luck with that either.
                  Thanks for all the help.
                  Dan
                    On 15/10/2012 at 17:54, xxxxxxxx wrote:
                    Callback methods can be very confusing unless you see a full working example of them in action.
                    So maybe this example will help.
                    This is the entire .cpp code for a very basic dialog plugin example with no external resources.
                    When the plugin opens. The HtmlViewerCustomGui fetches the Google website and displays it in the plugin.
                    When the button is clicked. It loads the Maxon website. Plus... it also calls to the htmlViewerCallback() method and runs the code inside of it.
                    In this case it just prints url.
                    Example:
                    // Testing ID# Only!!!!   Be sure to use a unique ID obtained from www.plugincafe.com
                    #define PLUGIN_ID 1000006
                    #include "c4d.h"
                    #include "gui.h"
                    #include "c4d_symbols.h"
                    #include "customgui_htmlviewer.h"
                    enum
                      MY_HTML_VIEWER = 5000,
                      MY_LABEL,
                      MY_BUTTON,
                      _dummy
                    class myDialog : public GeDialog
                      private:
                          HtmlViewerCustomGui *viewer;
                          C4DGadget *myButton;
                          myDialog(void);
                          virtual Bool InitValues(void);
                          virtual Bool Command(LONG id,const BaseContainer &msg);
                    //This is a custom callback method that will print the url of the webpage when the button is clicked
                      GePrint(url);
                    //The constructor
                    myDialog::myDialog(void){}
                    Bool myDialog::CreateLayout(void)
                      SetTitle("Simple HTML Viewer Example");
                      GroupBegin(0,BFH_SCALEFIT,2,0,"",0);
                          AddStaticText(0,BFH_LEFT,0,0,"My Viewer",0);
                          myButton = AddButton( MY_BUTTON, BFH_SCALEFIT, 80,  15, "Load HTML Page");
                      GroupEnd();
                      //Set up the HtmlViewerCustomGui stuff
                      BaseContainer htmlc;
                      viewer = (HtmlViewerCustomGui* )AddCustomGui(MY_HTML_VIEWER, CUSTOMGUI_HTMLVIEWER, "HTML_WINDOW", BFH_SCALEFIT|BFV_SCALEFIT, 512, 250, htmlc);
                      viewer->SetUrl("https://www.google.com/", URL_ENCODING_UTF16);
                    Bool myDialog::InitValues(void)
                    Bool myDialog::Command(LONG id,const BaseContainer &msg)
                      switch (id)
                          case MY_BUTTON:
                              if (MY_BUTTON)
                                  viewer->SetUrl("http://maxon.net", URL_ENCODING_UTF16);  //Load this HTML page
                                  viewer->SetURLCallback(htmlViewerCallback, NULL);        //Execute whatever code is inside the htmlViewerCallback() method
                              break;
                    ///////// The plugin registration section ///////////////
                    class myHTMLviewer : public CommandData
                      private:
                          myDialog dlg;
                          virtual Bool Execute(BaseDocument *doc);
                          virtual Bool RestoreLayout(void *secret);
                    Bool myHTMLviewer::Execute(BaseDocument *doc)
                      return dlg.Open(DLG_TYPE_ASYNC,PLUGIN_ID, -1, -1, 300,150);
                    Bool myHTMLviewer::RestoreLayout(void *secret)
                      return dlg.RestoreLayout(PLUGIN_ID,0,secret);
                    Bool RegistermyHTMLviewer(void)
                      return RegisterCommandPlugin(PLUGIN_ID,GeLoadString(IDS_HTML_VIEWER),0,AutoBitmap("icon.tif"),String("HTML Viewer"),gNew myHTMLviewer);
                      On 17/10/2012 at 14:17, xxxxxxxx wrote:
                      Thanks so much Scott, it works perfectly.
                      Is there a way to get any other type of information from a website besides a url?  For example could I get an array from a website or something similar?
                      Thanks a bunch!
                      Dan
                        On 17/10/2012 at 14:54, xxxxxxxx wrote:
                        Look up GetTextArea in the docs.
                        That function might possibly read the text in the loaded HTML page.
                        I never use this URL stuff. So I don't really know what all of the possibilities are.
                        I've have had difficulty with understanding how to use the callbacks in the SDK myself. And Yannick helped me understand how to use them in a previous thread.
                        That's really all I can offer advice about.
                          On 18/10/2012 at 11:11, xxxxxxxx wrote:
                          Thanks Scott.  I've been experimenting with the code you provided.  No luck yet but I'm going to keep trying.
                          Dan
