__rmul__ Bug
On 08/10/2012 at 08:23, xxxxxxxx wrote:
Hy there,
as you can see in the "attached" file, the python __rmul__ is not always correct. Ie. I am suspecting it is the __rmul__, as I can zero-out the offset manually and not use the __rmul__ and then it works fine.
I really don't know, what could go wrong in this example and how this is related to the spline in use. When you start it, you have a camera which is not aligned to the spline. Looking into the XPresso, you can see, that the __rmul__ seems to return a wrong result. The same code as COFFEE works fine.
If you switch the spline "This Spline Breaks Python _rmul_" in the XPresso by the "Spline ok", it also works fine. If you use the COFFEE code (re-wire XPresso), it also always works fine.
So, here something somehow goes wrong.
maxxPS: Its really unfortunate, that we can't attach anything here. The linked example won't be there forever, so this post is soon useless. I really can't explain how to get to this "setup", so attaching a "working wrong" example seems the only way here.
On 09/10/2012 at 07:43, xxxxxxxx wrote:
You don't get the same result because COFFEE's GetMulV() doesn't include the offset in the multiplication but Python's __rmul__ does (equivalent to GetMulP()).
With Python you can call MulV() if you don't want the offset to be taken into account. -
On 09/10/2012 at 10:16, xxxxxxxx wrote:
With Python you can call MulV() if you don't want the offset to be taken into account.Hy Yannick,
yes, it is clear that GetMulV() does not include the offset (as I also pointed out in the second sentence in my first post and in the python code itself). The Python __rmul__ is defined as:
Matrix.\__rmul\_\_( self , other )If both objects are of type
Matrix, it multiplies the left hand matrix by the right hand matrix. Is the left object of typeMatrixand the right one ofVectorso multiply the vector by the matrix, this includes any translation in the matrix. In the last case, the left object can be of typeVectorand the right one of typeMatrixso it multiplies the vector by the matrix, this does not include any translation.
So, in the case of the left object being a Vector and the right one being a Matrix , we should get the same result as with COFFEE GetMulV(). This is not the case in the example.Edit: Ok, it seems that the offset is the only problem here. This explains all the behaviors, I see now. But still either the docs are wrong, or the way the function works.
André -
On 09/10/2012 at 15:56, xxxxxxxx wrote:
Note that the tangent is not a rotation vector.
It's a position vector, one unit from the point.
Thus any of your matrix tests might show errors.
Point being at 0,0,0 then the point and tangent pos
will give you the rotation.
(tangent - vector(0,0,0,)) : that is the same as
the tangent itself in a VectorToHPB() function.Since you are getting the global position from your
spline node, You would only need a matrix output in
the py node feeding your Cameras Global Matrix.import c4d from c4d import utils as u def main() : global Outm rot = u.VectorToHPB(tangent) m = u.HPBToMatrix(rot) m.off = oPos Outm = mCheers
Lennart -
On 09/10/2012 at 17:10, xxxxxxxx wrote:
Hy Lennart,
the tangent itself in a VectorToHPB() function.I try to follow your explanation here, but I think I don't see your point. Especially:
Can you elaborate on this?
The 'tangent' variable is the direction in which the tangent points, in local coordinates of the spline-object. So in order to align an object absolute (say to the objects Z-Axis), one would need to convert the tangent direction to global coordinates.
import c4d from c4d import utils as u def main() : global Outm rot = u.VectorToHPB(tangent) m = u.HPBToMatrix(rot) m.off = oPos Outm = mIn this example here, the camera would align to the tangent 'as seen in local spline coordinates', thus would be wrong, as soon as you rotate the axis of the spline. Or did I understand you wrong?
the py node feeding your Cameras Global Matrix.Yes, thanks for the hint. But this is no real-life example
I was only trying to reproduce this __rmul__ problem, the application (ie. align the camera) is only for demonstration purpose.Cheers,
André -
On 09/10/2012 at 17:31, xxxxxxxx wrote:
You wrote:
"The 'tangent' variable is the direction in which the tangent points, in local coordinates of the spline-object"No, that is what I tried to point out. It is not a (direct) direction.
It's a position. Using that position will give you the direction using i.e.VectorToHPB().
The example I made works as it it rotates the Camera along the spline (just as AlignToSpline Tag
set to tangential) no matter how the spline object is rotated or the camera is placed under a parent.Cheers
Lennart -
On 09/10/2012 at 17:58, xxxxxxxx wrote:
Just that we mean the same, is this how you suggest?
Ok, I will have a look at this.
Thank you,
André -
Yes you're right, the description of __rmul__ is wrong in the case of a left object Vector and a right object Matrix: it includes any translation in the matrix. I'll fix the description.
Ok, thank you!
André
