    created spline disappear in Points Mode
    6 Posts 0 Posters 441 Views
      On 19/09/2012 at 04:14, xxxxxxxx wrote:
      Cinema 4D Version:   13
      Hi
      i have a plugin which creates a SplineObject sets the Points and inserts it into the Document.
      Well all its write but if i select the Spline in Points Mode in Cinema the Spline disappear.
      If I Select a point of the Spline and move it the Spline appears.
      What have i done wrong?
      The Code:
        BaseDocument *doc = GetActiveDocument();
        SplineObject *myspline = SplineObject::Alloc(5,SPLINETYPE_BSPLINE);
        Vector *point = myspline->GetPointW();
        for (int i = 0; i < myspline->GetPointCount(); i++)
            point _.x = (LReal)(i * 100);
            point _.z = (LReal)((i%2) * 100);
        myspline->SetName("newname");
        doc->InsertObject(myspline,NULL,NULL);
      greatings
      RM
        On 19/09/2012 at 04:52, xxxxxxxx wrote:
        Hi and welcome Ralf,
        After changing its points, a point object (polygon, spline etc.) needs to be updated by calling Message(MSG_UPDATE).
        Your code doesn't compile because of the point array declaration and usage. Also don't forget to notify Cinema that a change happened in the scene with EventAdd() to see the created spline effectively added to the scene. Here's the code:
        Vector *points = myspline->GetPointW();
        for (LONG i = 0; i < myspline->GetPointCount(); i++)
            points[i].x = (LReal)(i * 100);
            points[i].z = (LReal)((i%2) * 100);
         **myspline- >Message(MSG_UPDATE);**
         **EventAdd();**
          On 19/09/2012 at 23:00, xxxxxxxx wrote:
          thx for the fast reply
          => could be closed
            On 27/07/2015 at 08:21, xxxxxxxx wrote:
            I have one more question relevant to this post:
            If you create objects inside GetVirtualObjects(), they don't need to be updated, right?
            And there should also be no need to call EventAdd(), right?
            At least I don't have it, and my code works perfectly fine (as far as I can see).
              On 28/07/2015 at 00:50, xxxxxxxx wrote:
              Hi Casimir,
              Exactly. The code I posted above is to be run in the context of a CommandData plugin Execute().
              In ObjectData::GetVirtualObjects() an object created isn't in the document till it's returned. Cinema then takes care of updating the shown object and the document.
                On 28/07/2015 at 02:19, xxxxxxxx wrote:
                Hi Yannick,
                Thanks for your answer, I'm glad I was right 😛
