    Python Tag and Area Lights
    5 Posts 0 Posters 595 Views
      On 18/09/2012 at 23:31, xxxxxxxx wrote:
      Hi guys!
      I have an area light that I'd like to be set to Object mode and I would like the child to be defined as that object. And, if possible, have a shortcut for this sort of light in the top panel with my other lights.
      I understand this can be done using a Python tag but I know nothing about it.
      If you could help or at least point me in the right direction where I can learn, I would really appreciate it 😄
      Thanks in advance!
        On 19/09/2012 at 11:34, xxxxxxxx wrote:
        Hello.  I think this script will be the button you want, select the objects you want and then when you run it they'll be inserted under a newly created light and put into the objects list.
        from c4d import gui
          objs = doc.GetActiveObjects(True)
          light = c4d.BaseObject(c4d.Olight)
          light[c4d.LIGHT_TYPE] = 8  #set type to area
          inexclude = c4d.InExcludeData()  #Create and inexclude data to set the light's one too.
          doc.InsertObject(light)#insert the object into the scene
          for obj in objs:#if mutliple objects are selected it will insert all of them into the include data
              inexclude.InsertObject(obj,15)
              obj.InsertUnder(light) #move the objects under the newly created light
          light[c4d.LIGHT_EXCLUSION_LIST] = inexclude
        And I think this is the code for a python tag you want:
          obj = op.GetObject()#Get the object that owns the tag
          children = obj.GetChildren() #Get the children of that object
          for child in children:#if mutliple objects are selected it will insert all of them into the include data
              inexclude.InsertObject(child,15)
          obj[c4d.LIGHT_EXCLUSION_LIST] = inexclude
        Dan
          On 20/09/2012 at 04:15, xxxxxxxx wrote:
          Hi Dan! Thanks for the reply! 😄
          What I'm looking for is for the first child to be placed as an object in:
          Light Attributes > Details > Object (right under Area Shape);
          And where did you learn this coding??
            On 20/09/2012 at 09:11, xxxxxxxx wrote:
            No problem, I think this is what you want then.
            The script:
            from c4d import gui
              obj = doc.GetActiveObject()#Gets only the first active object
              if obj != None:
                  light[c4d.LIGHT_AREADETAILS_SHAPE] =6
                  light[c4d.LIGHT_AREADETAILS_OBJECT] = obj #set the selected object as the object field
            The tag:
              child = obj.GetDown() #Get the first child of that object
              obj[c4d.LIGHT_AREADETAILS_SHAPE] = 6 #setting area shape to object
              obj[c4d.LIGHT_AREADETAILS_OBJECT] = child  #Set the object field to the child
            I've been doing Python with C4D for a bit now, I started with this tutorial:  http://chicagoc4d.com/videos/python/189-introduction-to-python  I wouldn't worry about the twitter stuff through.  Everyone on the forum has been a huge help as well.
            Dan
              On 21/09/2012 at 02:57, xxxxxxxx wrote:
              Dude awesome thanks!
              Really appreciate the # explanations! Definitely learned something useful here.
              Cheers, dude.
              David
