    Setting SplineData gridlines through code
    10 Posts 0 Posters 1.3k Views
      On 14/09/2012 at 11:41, xxxxxxxx wrote:
      How can I change, in python, the number of gridlines (vertical or horizontal, it doesn't matter) of a SplineData field?
      I know that I must use:
      SplineCustomGui.SetGridLineCountH(n)
      for setting the number of horizontal lines. But how?!?!
      Rui Batista
        On 14/09/2012 at 12:36, xxxxxxxx wrote:
        If, at least, I knew how to get the SplineCustomGui of my SplineData.
        But that is not clear in the SDK 😞
        If I can't even get the SplineCustomGui of an element, how am I supposed to use SetGridLineCountH(n)?
          On 14/09/2012 at 14:24, xxxxxxxx wrote:
          Damn! I can't even create an instance with:
          customgui=c4d.gui.SplineCustomGui()
          What can we do with this class?!?!?
          Rui Batista
            On 14/09/2012 at 15:52, xxxxxxxx wrote:
            This is exasperating!!!
            How is it that something as simple as changing the number of gridlines of a spline data element proves to be soooooo complicated?!
            If a class is not accessible, why is it in the SDK?
            Rui Batista
              On 14/09/2012 at 16:12, xxxxxxxx wrote:
              I have read this in the C++ SDK:
              Spline data type (CUSTOMDATATYPE_SPLINE) for the SplineCustomGui GUI. Cannot be instantiated directly.
              If it can't be instantiated directly, how can we instantiate it indirectly?
                On 15/09/2012 at 13:33, xxxxxxxx wrote:
                Hello Rui, _
                > > If it can't be instantiated directly, how can we instantiate it indirectly?_
                GeDialog.AddCustomGui() instanciates it internally and returns a reference to the created BaseCustomGui instance. I couldn't find a way, in Python, to retrieve a custom-gui that was instantiated by the dialog-resource loader.
                But afaik you are currently working on an Object plugin. Afaik we are not able to obtain the BaseCustomGui instance from descriptions. I'm sorry but I can not tell you how to do what you want to achive. I'm actually not even sure how to do this in C++. An official statement would be very appreciated!
                -Niklas
                  On 16/09/2012 at 00:47, xxxxxxxx wrote:
                  +100
                  i can't get it too.
                  sample code:
                  from c4d import gui,storage
                  SPG = 1001
                  DGR = 1002
                  BUTTON_1 = 1003
                  class TestSplGui(gui.GeDialog) :
                    global spl
                    def CreateLayout(self) :
                        global spl
                        self.AddButton(BUTTON_1, c4d.BFH_LEFT, 150, 15, "Test")
                        self.LayoutFlushGroup(1002)
                        self.GroupBegin(DGR, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT)
                        bc = c4d.BaseContainer()
                        bc[c4d.SPLINECONTROL_GRID_H] = False
                        bc[c4d.SPLINECONTROL_GRID_V] = True
                        bc[c4d.SPLINECONTROL_Y_MIN] = 0
                        bc[c4d.SPLINECONTROL_Y_MAX] = 50
                        bc[c4d.SPLINECONTROL_MINSIZE_V] = 10
                        bc[c4d.SPLINECONTROL_GRIDLINES_V] = 50
                        spl = self.AddCustomGui(SPG, 1009059, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0, bc)
                        self.GroupEnd()
                        self.LayoutChanged(1002)
                    def InitValues(self) :
                        self.SetTitle("Test")
                        self.GroupEnd()
                    def Command(self, id, msg) :
                        global spl
                        if id==BUTTON_1:
                          print spl.GetGridLineCountV()
                          spl.SetGridLineCountV(10)
                    dlg = TestSplGui()
                    #DLG_TYPE_MODAL = > synchronous dialog
                    #DLG_TYPE_ASYNC = > asynchronous dialogs
                    dlg.Open(dlgtype=c4d.DLG_TYPE_ASYNC, defaultw=800, defaulth=600)
                    On 16/09/2012 at 03:25, xxxxxxxx wrote:
                    Thank you for the replies.
                    So, Maxon, if it is impossible to get access to that, why is it in the SDK?
                      On 18/09/2012 at 02:08, xxxxxxxx wrote:
                      It's in the SDK because (same as what Niklas said before) GeDialog.AddCustomGui() creates an instance of a SplineCustomGui in a dialog if you call it with CUSTOMGUI_SPLINE.
                      But when you declare it in a description you don't have access to the SplineCustomGui, only the SplineData. In that case in the resource description file you can set the number of grid horizontal/vertical steps with GRIDSIZE_H/GRIDSIZE_V flags. You can look at the Spline Deformer resource file to see how a SPLINE description element can be declared: resource\modules\objects\res\description\osplinedeformer.res.
                        On 18/09/2012 at 02:40, xxxxxxxx wrote:
                        I have set the grid divisions in my description file.
                        But my plugin creates sets of knots dynamically and I would like to match the grid divisions with the number of knots created.
                        It is a shame that it can't be done 😞
