    Assign a standard icon to a script automatically
    3 Posts 0 Posters 552 Views
      On 11/09/2012 at 03:25, xxxxxxxx wrote:
      C4D Ver. 13
      Lang: python
      Hi Everyone,
      this is probably a noob question but I can't figure it out. I created some (very basic) scripts that simply add a c4d tag to an object. I made it for xpresso tag, target, and some other tags I use frequently, to have them docked in the interface. The code is this simple:
      from c4d import gui
         obj = doc.GetActiveObject()
         if obj is None :
            gui.MessageDialog('Nessun oggetto selezionato')
         doc.StartUndo()
         xtag = c4d.BaseTag(c4d.Texpresso)
         obj.InsertTag(xtag)
         doc.AddUndo(c4d.UNDOTYPE_NEW, xtag)
         doc.EndUndo()
      The script by default has the generic python icon, is possible to have it assigned one of the standard C4D icons that represent the tag is going to be created ?
      Thank for any advice !
      Max
        On 11/09/2012 at 05:32, xxxxxxxx wrote:
        Hi, create an icon file (*.tif) and put it with the same name as the script in the same folder.
        test.py
        test.tif
        Cheers, Seb
          On 11/09/2012 at 06:12, xxxxxxxx wrote:
          Hi, and thanks for your reply !
          I kinda knew this method, but still it requires me to generate an icon file each time/script.
          What I would like to do is to fetch an icon from (already registered) standard c4d icons in the script, and assign it to the script itself. For standard icons I mean this: http://chicagoc4d.com/C4DPythonSDK/modules/c4d.bitmaps/
