    Visual Measurer
    4 Posts 0 Posters 394 Views
      On 05/09/2012 at 09:38, xxxxxxxx wrote:
      Cinema 4D Version:   14
      Hey everyone,
      I am playing around trying to create a visual measuring line for the viewport.  Ultimately I want to be able to click on a point on an object,  and draw a line from the object point to any other point in space and determine the length of that line.  for example,  if I click on a point of a cube,  then drag my mouse out to some arbitrary point in the viewport,  I was to be able to determine the distance between the two points.
      So to accomplish this I have been trying getting the  object point,    we'll call it (A)   and the point where the mouse is,   we'll call it (B)     and then drawing a line between the two...    so I say
      A = WS(point);
      B = Vector(x, y, 0);
      bd->DrawLine(A, B, NOCLIP_Z);
      then I want to get the length of the line to use it as a measurement.
      So I do
      Real length = Len(A - B);
      the problem is I get very wrong numbers when I do this..
      let's say I draw a line from one point in a cube to the other,   and expect that the distance between the two points is 200.      the numbers I get from my setup is like 500...
      Any thoughts on what I might be doing wrong?
      Shawn
        On 06/09/2012 at 05:42, xxxxxxxx wrote:
        Howdy,
        It looks like you're converting to screen coordinates, but not converting back to world coordinates before calling the Len() function.
        Adios,
        Cactus Dan
          On 06/09/2012 at 08:12, xxxxxxxx wrote:
          Ah..   Thanks Dan!  Should've caught that.   I appreciate it!
            On 12/09/2012 at 03:16, xxxxxxxx wrote:
            Just in case you missed it, are you aware of Cinema's Measure & Construction tool? Seems to do the same.
