    Gradient Shader
    11 Posts 0 Posters 969 Views
      On 02/09/2012 at 13:36, xxxxxxxx wrote:
      Cinema 4D Version:   13
      can anybody please help me to retrieve the data of a gradien shader? The code below always provides NULL. Am I using the wrong Resource ID? I tried it with the ones from xs**gradient.h, they match the shader panel in the attribute manager.
      BaseShader *sh = chn->GetShader();
      if (sh->GetType() == Xgradient)
          if (sh->GetParameter(DescLevel(1000), d, DESCFLAGS_GET_0)) // Xs**gradient
              Gradient *gr = (Gradient* )d.GetCustomDataType(CUSTOMDATATYPE_GRADIENT);
              if (gr)
                   // ... gr is NULL
        On 02/09/2012 at 17:01, xxxxxxxx wrote:
        I'm using Python but maybe you need to use something like InitRenderStructure()
        and InitRender(gr) ?
        Then possibly get the pixel at UVW x,y.
        Haven't done it with a gradient shader but rather a Color Gradient Userdata.
        Lennart
          On 03/09/2012 at 00:53, xxxxxxxx wrote:
          Hello Klaus,
          BaseContainer::GetCustomDataType() accepts two arguments. The first one is the ID of the description element, the second the ID of the data-type.
          Gradient* gr = (Gradient* ) d.GetCustomDataType(MY_GRADIENT_ID, CUSTOMDATATYPE_GRADIENT);
          If the gradient is part of your own description for your plugin, you need to initialize it in NodeData::Init().
          -Niklas
            On 03/09/2012 at 01:08, xxxxxxxx wrote:
            Hello Klaus, BaseContainer::GetCustomDataType() accepts two arguments. The first one is the ID of the description element, the second the ID of the data-type.
            I think the 'd' in this case is a GeData, not a BaseContainer, and so there's only one argument. I would check the value in the DescID() call, is 1000 really correct?
            Steve
              On 03/09/2012 at 02:01, xxxxxxxx wrote:
              Hi Steve,
              yes, d is GeData d. I'm going this way successfully to get the gradient type :
              GeData     d;
              LONG     type = 0;
              if (sh->GetParameter(DescLevel(1001), d, DESCFLAGS_GET_0)) // SLA_GRADIENT_TYPE 1001
                   type = (LONG)d.GetLong(); // => e.g. 2000 for SLA_GRADIENT_TYPE_2D_U
              So I assume the way to get the data is pricipally right.
              @Niklas: no it's not my plugin using the gradient. I want to get it from a material.
              Here are the IDs of Xs**gradient.h
              Xs**gradient                          = 1000,
              SLA_GRADIENT_TYPE                     = 1001,   // LONG
                  SLA_GRADIENT_TYPE_2D_U              = 2000,
                  SLA_GRADIENT_TYPE_2D_V,
                  SLA_GRADIENT_TYPE_2D_DIAG,
                  SLA_GRADIENT_TYPE_2D_RAD,
                  SLA_GRADIENT_TYPE_2D_CIRC,
                  SLA_GRADIENT_TYPE_2D_BOX,
                  SLA_GRADIENT_TYPE_2D_STAR,
                  SLA_GRADIENT_TYPE_2D_FOUR_CORNER,
                  SLA_GRADIENT_TYPE_3D_LINEAR,
                  SLA_GRADIENT_TYPE_3D_CYLINDRICAL,
                  SLA_GRADIENT_TYPE_3D_SPHERICAL,
              SLA_GRADIENT_CYCLE                    = 1002,   // Bool
              SLA_GRADIENT_START                    = 1003,   // Vector
              SLA_GRADIENT_END                      = 1004,   // Vector
              SLA_GRADIENT_RADIUS                   = 1005,   // Real
              SLA_GRADIENT_SPACE                    = 1006,   // LONG
                  SLA_GRADIENT_SPACE_TEXTURE          = 2020,
                  SLA_GRADIENT_SPACE_OBJECT,
                  SLA_GRADIENT_SPACE_WORLD,
                  SLA_GRADIENT_SPACE_CAMERA,
                  SLA_GRADIENT_SPACE_SCREEN,
                  SLA_GRADIENT_SPACE_RASTER,
              SLA_GRADIENT_TURBULENCE               = 1011, // real
                On 03/09/2012 at 02:23, xxxxxxxx wrote:
                I tried the code from Niklas using a base container. That's also the way the gradient sdk eample uses. Type is correct, but the gradient pointer is NULL!
                BaseContainer *bc = sh->GetDataInstance();
                Gradient *gr = (Gradient* )bc->GetCustomDataType(1000, CUSTOMDATATYPE_GRADIENT); // => NULL
                LONG type = bc->GetLong(1001); => correct values
                  On 03/09/2012 at 07:09, xxxxxxxx wrote:
                  Right, 1001 does indeed work as the gradient type. However, the actual colour gradient is not 1000 but 1007 (defined as SLA_GRADIENT_GRADIENT) - try that and see if it works.
                  Steve
                    On 03/09/2012 at 08:09, xxxxxxxx wrote:
                    Yep! That's it. Don't understand, how I could miss it in the h file.
                    SLA_GRADIENT_GRADIENT                 = 1007,   // Gradient
                      On 03/09/2012 at 12:24, xxxxxxxx wrote:
                      Easily done, I've achieved that error many times 🙂
                      Steve
                        On 03/09/2012 at 13:12, xxxxxxxx wrote:
                        Hi Klaus,
                        why are you not using the actual symbols in the code?
                        -Nik
                          On 04/09/2012 at 02:27, xxxxxxxx wrote:
                          you mean the resource IDs? I do so normally, but xs**gradient.h couldn't be found by the compiler. So I would have to setup a path, but I wasn't sure until now, that it is the right file.
