    Symbol stripping on OS X
    46 Posts 0 Posters 42.3k Views
      On 11/09/2012 at 08:17, xxxxxxxx wrote:
      Howdy,
      ...For the release build make sure stripping is enabled ("strip linked product -> Release: Yes"). Please check project and target settings for that....
      AHA! So my assumption was correct that the latest version's settings are the ones to use. Thanks. 🙂
      Edit:
      Or should the Debug be set to No?
      Adios,
      Cactus Dan
      You can change that, but I think the target settings for debug already do that (for you).
      Best regards,
      Wilfried
        On 11/09/2012 at 08:38, xxxxxxxx wrote:
        Howdy,
        ...Use the "nm <path> | c++filt -p -i" command to verify that new & delete symbols aren't exported...
        When I use that, it gives me an error:
        -bash: nm: command not found
        Adios,
        Cactus Dan
          On 11/09/2012 at 08:52, xxxxxxxx wrote:
          Howdy,
          DOH! disregard that previous post. I was trying that through the network from a different machine. When I did that on the machine where I did the compile, it gave me this readout:
                           U std::nothrow
                           U ___bzero
                           U ___cxa_atexit
                           U ___stack_chk_fail
                           U ___stack_chk_guard
                           U _asin
          00000000000340e0 T _c4d_main
                           U _cos
                           U _free
                           U _malloc
                           U _memcpy
                           U _memset
                           U dyld_stub_binder
          Adios,
          Cactus Dan
            Howdy, DOH! disregard that previous post. I was trying that through the network from a different machine. When I did that on the machine where I did the compile, it gave me this [...]
            Was that a debug build, or have you manually changed some settings or do you use some external libs? The "stack_chk_guard" isn't supposed to be in a release build, at least not in our usual builds.
            nm needs installed devtools on the machine to work.
            Best regards,
            Wilfried
              On 11/09/2012 at 09:13, xxxxxxxx wrote:
              Howdy,
              Well, crap! Now I'm not sure where to set whether it's a Release or Debug build (I'm somewhat lost in Xcode 4).
              This was the only place where I could find a choice between Debug and Release:
              Is that only for the command line build?
              Adios,
              Cactus Dan
                Howdy,
                Adios,
                Cactus Dan
                There is a XCode 4 transition guide @Apple: http://developer.apple.com/library/mac/#/legacy/mac/library/documentation/IDEs/Conceptual/Xcode4TransitionGuide/Introduction/Introduction.html
                To edit the scheme settings, press ALT-Cmd-R (or use the menu: Product -> Edit Scheme...). There you can switch between release, debug, etc.
                Best regards,
                Wilfried
                  On 11/09/2012 at 09:57, xxxxxxxx wrote:
                  Howdy,
                  ...To edit the scheme settings, press ALT-Cmd-R (or use the menu: Product -> Edit Scheme...). There you can switch between release, debug, etc...
                  Thanks. I did figure that out by googling it, and discovered that it was set to "Release":
                  Is there some other setting that needs to change, that's causing the "stack_chk_guard"?
                  I'm still compiling my original plugin project that was copied from the cinema4dsdk project from the R14.014 demo.
                  Edit:
                  Or does it really matter that the "stack_chk_guard" is showing up in the Terminal readout?
                  Adios,
                  Cactus Dan
                    Howdy,[...] Is there some other setting that needs to change, that's causing the "stack_chk_guard"?
                    Edit:
                    Adios,
                    Cactus Dan
                    Honestly I'm not sure yet what can cause it. It's a little bit sus**cious as Rick's (messed up) project created the same symbol and it still contained the debug symbols, when looking at the file with a hex editor (even though nm didn't show it!).
                    I've created two new projects for Rick, one based on R13.061 SDK (which lets the plugin run in R13 & R14), the other one based on the R14.025 SDK and both were much shorter than his versions, didn't contain the debug symbols or the "stack_chk_guard" symbol - and both didn't crash anymore on OS X 10.8.1 with 14.025.
                    If you like, PM me and send me the project file and the compiled plugin dylib to have a look at.
                    Best regards,
                    Wilfried
                      On 11/09/2012 at 11:43, xxxxxxxx wrote:
                      Howdy,
                      I had Holger check a newly compiled plugin on Mountain Lion with the changed build settings, and that seemed to eliminate the crash, so I think I'm good to go to recompile the rest of them changing those settings.
                      Adios,
                      Cactus Dan
                        On 11/09/2012 at 22:38, xxxxxxxx wrote:
                        When I change Strip Style to "Non-Global Symbols", I get an error:
                        "Command /Developer_3.2.6./usr/bin/strip failed with exit code 1"
                        Not much info online so far about how to fix this.  strip is definitely there.  Must I also change the api_lib settings?  Again, couldn't expect this to be simple.  Something always screws me.  You have screenshots of my configuration so let me know if something there is conflicting.  Note that there are no other libs in use for the project causing the error (Solid Chamfer 2.1).
                        ETA: This is using the R12 SDK.
                          On 11/09/2012 at 23:14, xxxxxxxx wrote:
                          Here is the full transcript of the command:
                          trip ./SolidChamfer2.1.dylib
                          cd /Users/roberttempleton/Documents/Cinema_4D_SDK/R12/plugins/SolidChamfer2.1
                          /Developer_3.2.6/usr/bin/strip -x /Users/roberttempleton/Documents/Cinema_4D_SDK/R12/plugins/SolidChamfer2.1/./SolidChamfer2.1.dylib
                          /Developer_3.2.6/usr/bin/strip: symbols referenced by indirect symbol table entries that can't be stripped in: /Users/roberttempleton/Documents/Cinema_4D_SDK/R12/plugins/SolidChamfer2.1/SolidChamfer2.1.dylib (for architecture x86_64)
                          __ZNSt6vectorI21SC_ChangePolyVertexOpSaIS0_EE13_M_insert_auxEN9__gnu_cxx17__normal_iteratorIPS0_S2_EERKS0_
                          __ZNSt6vectorI7LVectorSaIS0_EE13_M_insert_auxEN9__gnu_cxx17__normal_iteratorIPS0_S2_EERKS0_
                          __ZNSt6vectorI8CPolygonSaIS0_EE13_M_insert_auxEN9__gnu_cxx17__normal_iteratorIPS0_S2_EERKS0_
                          __ZNSt6vectorIiSaIiEE13_M_insert_auxEN9__gnu_cxx17__normal_iteratorIPiS1_EERKi
                          __ZNSt8_Rb_treeI7SC_EdgeS0_St9_IdentityIS0_ES0_SaIS0_EE13insert_uniqueERKS0_
                          __ZNSt8_Rb_treeI7SC_EdgeS0_St9_IdentityIS0_ES0_SaIS0_EE7_M_copyEPKSt13_Rb_tree_nodeIS0_EPS6_
                          __ZNSt8_Rb_treeI7SC_EdgeS0_St9_IdentityIS0_ES0_SaIS0_EE8_M_eraseEPSt13_Rb_tree_nodeIS0_E
                          __ZNSt8_Rb_treeI7SC_EdgeS0_St9_IdentityIS0_ES0_SaIS0_EE9_M_insertEPSt18_Rb_tree_node_baseS6_RKS0_
                          __ZNSt8_Rb_treeI7SC_EdgeSt4pairIKS0_11SC_EdgedataESt10_Select1stIS4_ES0_SaIS4_EE13insert_uniqueERKS4_
                          __ZNSt8_Rb_treeI7SC_EdgeSt4pairIKS0_11SC_EdgedataESt10_Select1stIS4_ES0_SaIS4_EE13insert_uniqueESt17_Rb_tree_iteratorIS4_ERKS4_
                          __ZNSt8_Rb_treeI7SC_EdgeSt4pairIKS0_11SC_EdgedataESt10_Select1stIS4_ES0_SaIS4_EE8_M_eraseEPSt13_Rb_tree_nodeIS4_E
                          __ZNSt8_Rb_treeI7SC_EdgeSt4pairIKS0_11SC_EdgedataESt10_Select1stIS4_ES0_SaIS4_EE9_M_insertEPSt18_Rb_tree_node_baseSA_RKS4_
                          __ZNSt8_Rb_treeI7SC_EdgeSt4pairIKS0_iESt10_Select1stIS3_ES0_SaIS3_EE13insert_uniqueERKS3_
                          __ZNSt8_Rb_treeI7SC_EdgeSt4pairIKS0_iESt10_Select1stIS3_ES0_SaIS3_EE13insert_uniqueESt17_Rb_tree_iteratorIS3_ERKS3_
                          __ZNSt8_Rb_treeI7SC_EdgeSt4pairIKS0_iESt10_Select1stIS3_ES0_SaIS3_EE8_M_eraseEPSt13_Rb_tree_nodeIS3_E
                          __ZNSt8_Rb_treeI7SC_EdgeSt4pairIKS0_iESt10_Select1stIS3_ES0_SaIS3_EE9_M_insertEPSt18_Rb_tree_node_baseS9_RKS3_
                          __ZNSt8_Rb_treeIiSt4pairIKi11SC_FacedataESt10_Select1stIS3_ESt4lessIiESaIS3_EE13insert_uniqueERKS3_
                          __ZNSt8_Rb_treeIiSt4pairIKi11SC_FacedataESt10_Select1stIS3_ESt4lessIiESaIS3_EE13insert_uniqueESt17_Rb_tree_iteratorIS3_ERKS3_
                          __ZNSt8_Rb_treeIiSt4pairIKi11SC_FacedataESt10_Select1stIS3_ESt4lessIiESaIS3_EE8_M_eraseEPSt13_Rb_tree_nodeIS3_E
                          __ZNSt8_Rb_treeIiSt4pairIKi11SC_FacedataESt10_Select1stIS3_ESt4lessIiESaIS3_EE9_M_insertEPSt18_Rb_tree_node_baseSB_RKS3_
                          __ZNSt8_Rb_treeIiSt4pairIKi13SC_VertexdataESt10_Select1stIS3_ESt4lessIiESaIS3_EE13insert_uniqueERKS3_
                          __ZNSt8_Rb_treeIiSt4pairIKi13SC_VertexdataESt10_Select1stIS3_ESt4lessIiESaIS3_EE13insert_uniqueESt17_Rb_tree_iteratorIS3_ERKS3_
                          __ZNSt8_Rb_treeIiSt4pairIKi13SC_VertexdataESt10_Select1stIS3_ESt4lessIiESaIS3_EE8_M_eraseEPSt13_Rb_tree_nodeIS3_E
                          __ZNSt8_Rb_treeIiSt4pairIKi13SC_VertexdataESt10_Select1stIS3_ESt4lessIiESaIS3_EE9_M_insertEPSt18_Rb_tree_node_baseSB_RKS3_
                          __ZNSt8_Rb_treeIiSt4pairIKi17VectorAccumulatorESt10_Select1stIS3_ESt4lessIiESaIS3_EE13insert_uniqueERKS3_
                          __ZNSt8_Rb_treeIiSt4pairIKi17VectorAccumulatorESt10_Select1stIS3_ESt4lessIiESaIS3_EE13insert_uniqueESt17_Rb_tree_iteratorIS3_ERKS3_
                          __ZNSt8_Rb_treeIiSt4pairIKi17VectorAccumulatorESt10_Select1stIS3_ESt4lessIiESaIS3_EE8_M_eraseEPSt13_Rb_tree_nodeIS3_E
                          __ZNSt8_Rb_treeIiSt4pairIKi17VectorAccumulatorESt10_Select1stIS3_ESt4lessIiESaIS3_EE9_M_insertEPSt18_Rb_tree_node_baseSB_RKS3_
                          __ZNSt8_Rb_treeIiSt4pairIKi9SC_OffsetESt10_Select1stIS3_ESt4lessIiESaIS3_EE13insert_uniqueERKS3_
                          __ZNSt8_Rb_treeIiSt4pairIKi9SC_OffsetESt10_Select1stIS3_ESt4lessIiESaIS3_EE13insert_uniqueESt17_Rb_tree_iteratorIS3_ERKS3_
                          __ZNSt8_Rb_treeIiSt4pairIKi9SC_OffsetESt10_Select1stIS3_ESt4lessIiESaIS3_EE7_M_copyEPKSt13_Rb_tree_nodeIS3_EPSB_
                          __ZNSt8_Rb_treeIiSt4pairIKi9SC_OffsetESt10_Select1stIS3_ESt4lessIiESaIS3_EE8_M_eraseEPSt13_Rb_tree_nodeIS3_E
                          __ZNSt8_Rb_treeIiSt4pairIKidESt10_Select1stIS2_ESt4lessIiESaIS2_EE13insert_uniqueERKS2_
                          __ZNSt8_Rb_treeIiSt4pairIKidESt10_Select1stIS2_ESt4lessIiESaIS2_EE13insert_uniqueESt17_Rb_tree_iteratorIS2_ERKS2_
                          __ZNSt8_Rb_treeIiSt4pairIKidESt10_Select1stIS2_ESt4lessIiESaIS2_EE7_M_copyEPKSt13_Rb_tree_nodeIS2_EPSA_
                          __ZNSt8_Rb_treeIiSt4pairIKidESt10_Select1stIS2_ESt4lessIiESaIS2_EE8_M_eraseEPSt13_Rb_tree_nodeIS2_E
                          __ZNSt8_Rb_treeIiSt4pairIKiiESt10_Select1stIS2_ESt4lessIiESaIS2_EE13insert_uniqueERKS2_
                          __ZNSt8_Rb_treeIiSt4pairIKiiESt10_Select1stIS2_ESt4lessIiESaIS2_EE13insert_uniqueESt17_Rb_tree_iteratorIS2_ERKS2_
                          __ZNSt8_Rb_treeIiSt4pairIKiiESt10_Select1stIS2_ESt4lessIiESaIS2_EE8_M_eraseEPSt13_Rb_tree_nodeIS2_E
                          __ZNSt8_Rb_treeIiiSt9_IdentityIiESt4lessIiESaIiEE13insert_uniqueERKi
                          __ZNSt8_Rb_treeIiiSt9_IdentityIiESt4lessIiESaIiEE7_M_copyEPKSt13_Rb_tree_nodeIiEPS7_
                          __ZNSt8_Rb_treeIiiSt9_IdentityIiESt4lessIiESaIiEE8_M_eraseEPSt13_Rb_tree_nodeIiE
                          __ZntRK7LMatrix
                          __ZplRK6StringS1_
                          Command /Developer_3.2.6/usr/bin/strip failed with exit code 1
                          And I get this for the default cinema4dsdk project Release:
                          Build cinema4dsdk of project cinema4dsdk with configuration Release
                          Strip ./cinema4dsdk.dylib
                          cd /Users/roberttempleton/Documents/Cinema_4D_SDK/R12/plugins/cinema4dsdk
                          /Developer_3.2.6/usr/bin/strip -x /Users/roberttempleton/Documents/Cinema_4D_SDK/R12/plugins/cinema4dsdk/./cinema4dsdk.dylib
                          /Developer_3.2.6/usr/bin/strip: symbols referenced by relocation entries that can't be stripped in: /Users/roberttempleton/Documents/Cinema_4D_SDK/R12/plugins/cinema4dsdk/cinema4dsdk.dylib (for architecture x86_64)
                          __ZTV17EdgeCutPointArray
                          __Z13blend_patternIfEvP7BM_TILET_
                          __Z13blend_patternIhEvP7BM_TILET_
                          __Z13blend_patternItEvP7BM_TILET_
                          __ZntRK7LMatrix
                          __ZplRK6StringS1_
                          What the heck!?
                            On 12/09/2012 at 00:12, xxxxxxxx wrote:
                            This is very frustrating.  Even using the R13 project for SolidChamfer has the same results.  The dylib is created but no stripping occurs due to the error.  How do I rectify this?
                            I have read the options for strip and '-r' does not help.  Relocation and indirect symbol table entries are kicking my arse and I have no idea how to fix this.
                            Help - user complaints are mounting and I am getting pissed very quickly.  I have two days before a 6-day work week to get this done (or they wait another week or more).  Hurts my sales, my business, my reputation, everything.  And, contrary to remarks at CGTalk, this is Apple's fault in the end.  Can't blame Maxon, can't ever blame plugin developers.
                              On 12/09/2012 at 00:34, xxxxxxxx wrote:
                              Update: the R13 cinema4dsdk builds properly.  So I am going to copy it to all of my projects and redo them using it - though I'm pretty sure that I did this for any plugins built against R13.  This might be something that changed from Xcode 3.2.1 to 3.2.6 that wasn't an issue or maybe an update in R13 that included the cinema4dsdk project?  So, wish me luck in this - though it will mean updating some code for R13 for R12 latest-builds.
                              Thanks for bearing with my frustration! 😉
                                This is very frustrating.  Even using the R13 project for SolidChamfer has the same results.  The dylib is created but no stripping occurs due to the error.  How do I rectify this?I have read the options for strip and '-r' does not help.  Relocation and indirect symbol table entries are kicking my arse and I have no idea how to fix this.Help - user complaints are mounting and I am getting pissed very quickly.  I have two days before a 6-day work week to get this done (or they wait another week or more).  Hurts my sales, my business, my reputation, everything.  And, contrary to remarks at CGTalk, this is Apple's fault in the end.  Can't blame Maxon, can't ever blame plugin developers.
                                Hi Robert, I updated my initial post to the latest findings. The problem you observed is created by Apple removing support for global stripping from the final linked product in XCode 3.2 - if you use the R12 SDK you don't even get a warning about this problem, just a remark in the compiler log.
                                We just found out about that yesterday when debugging the build process of Frank's plugin with the R12 SDK and XCode 3.2.6 ...
                                Best regards,
                                Wilfried
                                  On 12/09/2012 at 12:22, xxxxxxxx wrote:
                                  Thanks for the information, Wilfried.
                                  Builds with the R13 SDK and XCode 3.2.6 are now moving along and hope to get all of the plugins updated today.
                                  Take care,
                                    On 25/09/2012 at 09:49, xxxxxxxx wrote:
                                    Edit:
                                    Sorry didn't mean to hijack anything.
                                    Dan
                                      Hi.   I've been trying to get Xcode working with Cinema, I;ve got 3.2.6 running on my Mac right now and the R13 SDK examples refuse to build but the R13 Demo SDK examples build without a problem on the first try.  I've been reading through a lot of posts about getting Xcode to work, but I didn't see anything about the demo version working when the actual release one won't.  Could it still be my Xcode having the incorrect settings or would my R13 SDK examples be wrong?    Dan
                                      Please don't hi-jack other threads; stay at the thread you've opened with your question and make that one as descriptive as possible.
                                      Best regards,
                                      Wilfried
                                        On 12/10/2012 at 20:36, xxxxxxxx wrote:
                                        I made the changes to my projects but kept getting the strip failure error that Robert was getting.  I don't use any functionality of R13/R14, so the latest builds of my plugins are R12... so a lot of the info in these instructions don't apply to my current plugins.  It didn't matter if I used xcode 3.1.4 or 3.2.6, the error popped up and symbol stripping didn't occur (though, ironically, I sent one of these builds to someone who was having trouble with one of my plugins and their response was "hey, working perfectly, thanks!" and I haven't heard anything to the contrary from them and they're actively using it on a project).
                                        I started messing with some other symbol related project settings out of frustration and got a "strange" error about not being able to use both unexport and export lists.  So this is what I did to get a successfully stripped R12 build (out of both 3.1.4 and 3.2.6) :
                                        Uncheck "Separately Edit Symbols"
                                        Delete the path for "Unexported Symbols File"
                                        I tested this using clean cinema4dsdk projects from both R12 and R13 (so those settings were changed from default).
                                        -kvb
                                          On 13/11/2012 at 01:34, xxxxxxxx wrote:
                                          does anyone know where I could find the SDK 13.061 recommended by Maxon to build plugins for C4D R14 without these symbol stripping problems ??
                                          We can't update our plugins on MacOS for now because it crashes C4D at startup...
                                          Any help would very appreciated.
                                          I didn't find the SDK on http://beta.villa.maxon.net/, there is a post about an update for the SDK 13.061 but it does not contain any download link.
                                            The SDK 13.061 is the SDK that comes with R13.061. Update your installed CINEMA R13 to this version.
