    LineObject
    4 Posts 0 Posters 486 Views
      On 27/08/2012 at 11:07, xxxxxxxx wrote:
      I would like to triangulate a spline. I use LineObject.Triangulate() for that and it's work well if I have only one segment.
      If tey are more than one there is no function SetSegment to set the segments. How can I do ? (I don't want to use CallCommand or use an ExtrusionObject or other, I want realy triangulate into a PolygonObject)
      Script example when a spline is active :
          lo = c4d.LineObject(op.GetPointCount(),op.GetSegmentCount())
          for i,p in enumerate(op.GetAllPoints()) :
              lo.SetPoint(i,p)
          poly = lo.Triangulate(0.0)
          doc.InsertObject(poly)
      Thx
        On 23/04/2013 at 22:45, xxxxxxxx wrote:
        up !
        anyone had an idea, or it's impossible ? (if it's impossible -> wishing list for r2015 with the possibility to create ngons ...)
          On 24/04/2013 at 03:54, xxxxxxxx wrote:
          why don't you just create multiple LineObject out of your SplineObject (where you do
          have full access to the spline (segment) data) in python? i am also not quite sure if
          converting the spline object control points into LineObject points is a very suitable
          approach for a practical plugin, as this will cause you to loose any interpolation.
          ps : '  for r2015 with '. i would call that downright blasphemy 😉
            On 24/04/2013 at 08:49, xxxxxxxx wrote:
            For "classical" segments it's not a problem. It's only when a segment is within an other, triangulate in C++ make a hole into the polygon in python no way ...
