    Camera matrix during animation
    4 Posts 0 Posters 363 Views
      On 26/08/2012 at 11:53, xxxxxxxx wrote:
      Cinema 4D Version:   13
      I'm trying to get the inverse camera matrix of the render basedraw for an animation export. I step through the animation keys of the active camera object:
      doc->SetTime(bt); // Set Time to key->GetTime();
      doc->ExecutePasses(NULL, TRUE, TRUE, TRUE, BUILDFLAGS_0);
      EventAdd(); // don't know whether that's required in this case
      BaseDraw *bd = doc->GetRenderBaseDraw();
      Matrix m = bd->GetMi();
      The matrix won't change during animation. It keeps the values from the first frame! Do I have to send another kind of update message?
      If I use the inverted global matrix of the camera object, it works, but I would prefer to use the matrix from the render basedraw.
        On 01/09/2012 at 13:29, xxxxxxxx wrote:
        I dunno if this will help or not, but after the EventAdd(), add this:
          DrawViews(DRAWFLAGS_FORCEFULLREDRAW | DRAWFLAGS_NO_THREAD, NULL);    // force completion of cache rebuild
        ...I use that sequence of calls when I'm dealing with animating the document.
          On 01/09/2012 at 13:32, xxxxxxxx wrote:
          ...more specifically, I have a 'version compatibility' routine that I call...
          // cmpAnimateDocument()
          void cmpAnimateDocument(BaseDocument *pDoc, const BaseTime& frameTime)
          //    StopAllThreads();
            pDoc->SetTime(frameTime);
          #ifdef _R12_SDK_
            pDoc->ExecutePasses(NULL, TRUE, TRUE, TRUE, BUILDFLAGS_0);
          #elif _R11p5_SDK_
            pDoc->ExecutePasses(NULL, TRUE, TRUE, TRUE);
          #else
            pDoc->AnimateDocument(NULL, TRUE, TRUE);
          #endif
            EventAdd();
          #ifdef _R12_SDK_
          #elif _R10p1_SDK_
            DrawViews(DA_FORCEFULLREDRAW | DA_NO_THREAD, NULL);
          #else
            DrawViews(DA_FORCEFULLREDRAW);
          #endif
            On 02/09/2012 at 13:41, xxxxxxxx wrote:
            OK, thanks. I'll try it tomorrow. But I dont't want the editor windows being redrawed since it's called very often.
