    Spline linked to Polygon points?
    9 Posts 0 Posters 934 Views
      On 22/08/2012 at 17:10, xxxxxxxx wrote:
      Could anyone help me work out this simple problem I have. I'm obviously not getting something right?
          ob = op.GetObject()    #Polygon Child
          spline = ob.GetUp()    #Spline Parent
          for i in xrange(spline.GetPointCount()) :
              polypoints = ob.GetPoint(i)
              point = c4d.Vector(polypoints.x, polypoints.y, polypoints.z)
              spline.SetPoint(i, point)
              ob.Message(c4d.MSG_UPDATE)
        On 23/08/2012 at 01:43, xxxxxxxx wrote:
        Do you call the main function with
        Why do you do
        ob = op.GetObject()
        Before the loop, you should resize the spline calling
        spline.ResizeObject(ob.GetPointCount())
        Also, you should loop over the polygon points
        for i in xrange(ob.GetPointCount())
        The c4d.MSG_UPDATE message has to be sent to the modified spline
        spline.Message(c4d.MSG_UPDATE)
        The update message sent to the spline and the global C4D event added should be sent once (not for each polygon point) after the loop.
        And to get a good result you can use c4d.utils.Neighbor class to get more information on the polygon points order, connections etc.
          On 23/08/2012 at 13:08, xxxxxxxx wrote:
          Thank you for your reply Yannick.
          The script was on a python tag so thats why I did:
          ob = op.GetObject()
          Is that not right?
          I dont understand how once I looped through the polygon points I then go back and fix the spline points to them?
          I also tried the spline.Message(c4d.MSG_UPDATE) and just lost the spline out of the scene completely.
          This is the xpresso setup I am trying to convert into python basically as a 'learning from' exercise, but I am getting very lost.
          http://dl.dropbox.com/u/2802779/Xpresso_Setup.png
          This is where up to at the moment
          #Python Tag on Polygon Child
              polygon = op.GetObject()    #Polygon Child with 17 points
              spline = polygon.GetUp()    #Spline Parent with 8 points
              spline.ResizeObject(spline.GetPointCount())
              for i in xrange(polygon.GetPointCount()) : #Get the 17 points of the polygon
                  polygonpoint = polygon.GetPoint(i)
                  point = c4d.Vector(polygonpoint.x, polygonpoint.y, polygonpoint.z)
              for s in xrange(spline.GetPointCount()) : #Get the 8 points of the Spline
                  spline.SetPoint(s, point)
          Would appreciate any further help.
            On 23/08/2012 at 14:52, xxxxxxxx wrote:
            Hello hypoly,
            _
            spline.ResizeObject(spline.GetPointCount())_
            This doesn't make any sense and has no effect. Try to translate it into normal language and you'll understand why. "We will make the spline have as many points as it currently has." Huh?
            You don't actually get all 17 points, you just iterate from 0 to 16.
            _
              point = c4d.Vector(polygonpoint.x, polygonpoint.y, polygonpoint.z)_
            The last line is redundant. The value returned by GetPoint() is a vector.
            The correct version would be
                pcount = polygon.GetPointCount()
              spline.ResizeObject(pcount)
              for i in xrange(pcount) :
            I suggest you to read some introduction to programming or specifically to Python. The official Python tutorial is a good start.
            -Niklas
              On 23/08/2012 at 15:34, xxxxxxxx wrote:
              Hello Niklas,
              Thank you for your reply. I am well aware my programming knowledge is thin side to say the least, and will continue to read up on it. I think I was just getting overly confused with what was what and got tripped up. I find it easier learning form actually trying, and in doing so, making mistakes along the way, so thank you for correcting my silly errors.
              I have amended the script.
                On 23/08/2012 at 16:33, xxxxxxxx wrote:
                When I first used that script it seemed to work fine, I then copy and paste the same script to another scene with similar set up and get unexpected results? The scene file is here : http://dl.dropbox.com/u/2802779/SplineAttachedToPolygon.c4d.zip
                I don't understand why it worked on that one situation and not others?
                  On 23/08/2012 at 16:41, xxxxxxxx wrote:
                  It does work. But you have rotated the polygon-object. The position of the points is stored relative to the object's axis. You either have to multiply each point you obtain from the polygon-object with the matrix of the polygon-object, or change the matrix of the spline-object to match exactly the matrix of the polygon-object.
                  -Niklas
                    On 23/08/2012 at 16:49, xxxxxxxx wrote:
                    I just noticed that, sorry. Thanks again Niklas.
                      On 23/08/2012 at 17:03, xxxxxxxx wrote:
                      Np. 😉
