    Visual C++ 2010 Express
    4 Posts 0 Posters 312 Views
      On 13/08/2012 at 02:40, xxxxxxxx wrote:
      Cinema 4D Version:   R14
      Language(s) :
      It looks like the Cinema R14 SDK is now using Visual Studio 2010.
      Can Visual C++ 2010 Express be used to compile the SDK libs?
      I only have VS 2008. 😞
        On 13/08/2012 at 06:46, xxxxxxxx wrote:
        Yes it' s possible to compile and develop plugins with Visual C++ 2010 Express but you have to install also the Windows SDK to get the 64 bit compiler (to compile for Cinema 4D 64 bit version) :
        http://stackoverflow.com/questions/1865069/how-to-compile-a-64-bit-application-using-visual-c-2010-express
          Thanks, got it compiled, both 32-bit and 64-bit!
          BTW, if anybody tries to install the Windows SDK 7.1 and it fails, you must un-install all
          versions of "Microsoft Visual C++ 2010 x86/x64 Redistributables" from your computer,
          before you can install this SDK.  It was a pain to figure out, but got it working.
          And the Windows SDK will install on Windows XP SP3 too, even though it might say "Windows 7".
            On 16/08/2012 at 01:05, xxxxxxxx wrote:
            I don't recommend installing Visual Studio 2010 Service Pack 1 either.
            Your x64 projects will suddenly go missing.   Really buggy.
            Can't even import/export theme settings (broken by design?), so you're stuck with the ugly default theme.
