    Inserting as a child without cloning first ?
    4 Posts 0 Posters 416 Views
      On 08/08/2012 at 15:42, xxxxxxxx wrote:
      Cinema 4D Version:   R13
      Guys is it possible to insert an object already in the scene hierarchy as a child of another object ?
      I tried this and Cinema crashed.
      I think this is not possible using the insertObject() method because there can't be 2 instances of the same unique object in two different positions in the same hierarchy.
      This is my code (I use with a shorcut) where I had to clone the obj first to avoid crashing:
      main(doc,op)
      	var myObj = doc->GetActiveObject(); // Gets the Selected Object
      	if(!myObj) {
      		return;
      	var myObjParent = myObj->GetUp(); // Gets the Parent
      	if(myObjParent) {
      		if(myObjParent->GetType() == 1007455) { // Is HyperNurbs ?
      					Snippet to activate/deactivate visibilty on HyperNurbs Object
      			if (myObjParent#ID_BASEOBJECT_GENERATOR_FLAG == TRUE) { // Active ?
      				myObjParent#ID_BASEOBJECT_GENERATOR_FLAG = FALSE;
      			else {
      				myObjParent#ID_BASEOBJECT_GENERATOR_FLAG = TRUE;
      			return;
      	// If no parent Hypernurbs Object Found - Create One
      	CallCommand(1007455); // Create an HyperNurbs Object
      	var myHPN = doc->GetActiveObject(); // And Select that
      	if(!myHPN) {
      		return;
      	var newObj = myObj->GetClone(0);
      	doc->InsertObject(newObj, myHPN, NULL); // Need an Alternative
      	doc->SetActiveObject(myObj);
      Is there any way to access a method that instead of inserting the objects just move that in the hierarchy to avoid cloning ?
      And do you guys know the method to delete an object fron the hierarchy, programmatically, not by selecting it and deleting with CallCommand(100004787); // Delete
      The script is made to improve workflow in SDS modeling, to get a similar behaviour like in Modo.
      Thanks for the attention.
      EDIT: I've found how to delete the object (obj->Remove()).
      But that is not what I want basically because the behaviour I want to implement will make the tool selected or the selected geometry(Polygon,Edges,Points), remain selected.
        On 09/08/2012 at 00:24, xxxxxxxx wrote:
        First you have to remove the object from the document and then insert it as a child of the other object.  Everything is in a list (thus the derivation from BaseList2D) and you must insert things into the list and remove them before deletion or reinsertion.  You don't need a clone unless you want to have two objects.
        myObj->Remove();
        doc->InsertObject(newObj, myHPN);
          On 09/08/2012 at 07:14, xxxxxxxx wrote:
          So I can remove the Obj without unloading it from the memory, I'm simply removing from the hierarchy then placing it back again where I want.
          Yes with this correction now works flawlessly. I switch on the fly without touching the Hierarchy using TAB key, I'm also improving the script to include a switch between CClark with nGons and without it.
          And adding a check to avoid if the Hypernurbs object get selected in the Hierarchy to create a new One.
          SanX.
            On 09/08/2012 at 11:03, xxxxxxxx wrote:
            Exactly.  Removing it from the list does not Free (delete) it, it just removes it from the hierarchy.  That's a good thing to remember.  Before you can free anything in a list (objects, tags, materials, etc.), you must Remove() them first.
            Glad that you have it working! 🙂
