    GetDEnabling() TypeError on parent-call
    2 Posts 0 Posters 364 Views
      On 08/08/2012 at 03:23, xxxxxxxx wrote:
      I'm still confused about the GetDEnabling() thing, where we should include a call to the base-classes' method. There are several topics where the issue I'm currently having appears, and we couldn't find a solution to it.
      Yannick told me he couldn't ever reproduce this error, and as soon as I wanted to show him some code that triggers it, I couldn't reproduce it either. 😂
      But now I have a piece of code that invokes the error, and I don't really understand it. Sometimes the parent-call works, and sometimes it doesn't. 😠
      This is my code so far:
          def GetDEnabling(self, op, descid, data, flags, itemdesc) :
            rid = descid[0].id
            value = True
            # Just like the original Cube primitive, we will disable PRIM_CUBE_SEP
            # when PRIM_CUBE_DOFILLET is active.
            if rid == c4d.PRIM_CUBE_SEP:
                value = not op[c4d.PRIM_CUBE_DOFILLET]
            # PRIM_CUBE_FRAD and PRIM_CUBE_SUBF will be disabled when
            # PRIM_CUBE_DOFILLET is not activeated.
            elif rid in (c4d.PRIM_CUBE_FRAD, c4d.PRIM_CUBE_SUBF) :
                value = op[c4d.PRIM_CUBE_DOFILLET]
            # NRPRIM_DCUBE_INNERFOFFSET will be disabled when PRIM_CUBE_DOFILLET
            # is not activated.
            elif rid == c4d.NRPRIM_DCUBE_INNERFOFFSET:
            # Otherwise, ask your parents!
                print "-> Parent Call for id", rid
                value = super(DoubleCubeData, self).GetDEnabling(op, descid, data,
        flags, itemdesc)
            return bool(value)
      Fine so far. It used to work some minutes ago, and then suddenly, it didn't work for some elements.
      I have made a screencast that is intended to show the error more precisely and understandable.
      At the last part of the video, I do print "Parent call for id xx failed" when the parent-call failed. It will not be printed for some of the elements. That is because no parent-call is made for those elements (for example when I click in the "Seperate Surfaces" element or drag on the "Fillet Radius").
      It seems like only the parent-call for the element that is currently being changed in the AM fails.
      The video is located here.
      Can someone enlighten me about the issue? 😠
      -Niklas
        On 08/08/2012 at 06:17, xxxxxxxx wrote:
        Thanks for investigating this.
        Yes, I've now been able to reproduce this issue calling NodeData.GetDEnabling().
        Please submit this bug.
