    Load string from description?
    5 Posts 0 Posters 598 Views
      On 07/08/2012 at 01:04, xxxxxxxx wrote:
      I can load a string from the plugins resource using c4d.plugins.GeLoadString(). But this function
      does not work for description-elements. I want to get the string associated with the ID Tphong or
      PRIM_CUBE_LEN, just for example. How can I get it?
      Thanks in advance,
      Niklas
        To get the name of a tag type you can call c4d.GetTagName() function that was added in R13:
        c4d.GetTagName(c4d.Tphong)
        Also another function to get an object type's name was added, c4d.GetObjectName() :
        c4d.GetObjectName(c4d.Ocube)
        And it's currently not possible to access the description parameters of objects. So we cannot get the name of PRIM_CUBE_LEN parameter (would be the id c4d.DESC_NAME in the description container for the parameter). But it's possible to access dynamic descriptions with BaseList2D.GetUserDataContainer().
          On 07/08/2012 at 01:54, xxxxxxxx wrote:
          Thanks for your answer Yannick.The GetTagName() function is what I searched for, thanks. 🙂
          Wouldn't that require an instance of the actual object/tag so that we can obtain the description? (As you said, it's not possible Python anyway..)
          Regards,
          Niklas
            Yes, but that's not a big deal because the object doesn't need to be present in a document but in memory. Here's an handy function that returns the name of an object's parameter:
            String GetObjectParameterName(LONG type, LONG id)
                BaseObject *op = BaseObject::Alloc(type);
                if (op->GetType()==type)
                    AutoAlloc<Description> desc; if (!desc) return String();
                    if (!op->GetDescription(desc,DESCFLAGS_DESC_0)) return String();
                    const BaseContainer *bc = desc->GetParameterI(id,NULL);
                    if (bc)
                        return bc->GetString(DESC_NAME);
                return String();
            So for PRIM_CUBE_LEN we would call it like this:
            GetObjectParameterName(Ocube, PRIM_CUBE_LEN)
              On 07/08/2012 at 02:06, xxxxxxxx wrote:
              Haha, ok! I just thought that would be kind of a large overhead. 😉 But thanks for pointing it out.
              -Nik
