    Why use InitAttr ?
    5 Posts 0 Posters 769 Views
      On 31/07/2012 at 18:35, xxxxxxxx wrote:
      To initialize the elements of the description of my tag, should I use something like:
      def Init(self,node) :
           data = node.GetDataInstance()
           data.SetData(SD_ON,True)
      or something like:
      [COLOR=blue]
      def Init(self, node) :
          self.InitAttr(host=node, type=bool, desc=[SD_ON])
          node[SD_ON] = True
      What is the difference?
        On 31/07/2012 at 19:50, xxxxxxxx wrote:
        You only need self.InitAttr() for initializing GUI elements,
        then setting the values to the GUI's.
        Regular values you set directly using your IDs.
        Such as:
             def Init(self, pconnector) :
                  pconnector[DIRTYSUM]               = c4d.BaseContainer()
                  # Source Settings
                  pconnector[c4d.PC_SHIDE]          = True
                  pconnector[c4d.PC_MODE_ALL]          = 0
                  pconnector[c4d.PC_AMOUNT]          = 1.0
                  pconnector[c4d.PC_CONNECT]          = 0
                  # Point Settings
                  pconnector[c4d.PC_STARTPOINT]            = 1.0
                  pconnector[c4d.PC_ENDPOINT]             = 100.0
                  pconnector[c4d.PC_OFFSETPOINT]           = 0.0
                  pconnector[c4d.PC_DIRECTION]             = 0
                  pconnector[c4d.PC_POINTSTEP]             = 1.0
                  pconnector[c4d.PC_CONNECTSTEP]           = 1.0
                  pconnector[c4d.PC_MAXPOINTDIF]           = 1000.0
                  pconnector[c4d.PC_RANDOM]          = 0.0
                  # Spline Settings
                  pconnector[c4d.PC_MAKESPLINE]          = True
                  pconnector[c4d.PC_SPLINE_MIN]          = 0.0
                  pconnector[c4d.PC_SPLINE_MAX]          = 1000.0
                  pconnector[c4d.PC_SEGMENT_START]     = 0.0
                  pconnector[c4d.PC_SEGMENT_END]          = 1.0
                  pconnector[c4d.PC_DISTANCE_GROW]     = 0
                  pconnector[c4d.PC_DISTANCE_SENSE]     = 0.8
                  pconnector[c4d.PC_SPLINE_SUB]          = 0
                  #TP life
                  self.InitAttr(pconnector, c4d.SplineData, [c4d.PC_TPCURVE])
                  icurve = pconnector[c4d.PC_TPCURVE]
                  icurve.SetRange(0.0, 1.0, 0.01, 0.0, 1.0, 0.01)
                  icurve.InsertKnot(1,1,0)
                  icurve.InsertKnot(0,1,0)
                  pconnector[c4d.PC_TPCURVE] = icurve
                  # General
                  pconnector[c4d.PC_SPACE]          = 0
                  pconnector[c4d.PC_CACHE]          = False
                  pconnector[c4d.PC_INFO]               = 'Ready'
                  #etc
        Lennart
          On 31/07/2012 at 20:00, xxxxxxxx wrote:
          I have been initializing the values of the GUI elements of the description in the Init method, using:
               data.SetData(SD_USE_CHILDREN,False)
               data.SetData(SD_NO_INTERPOLATE,False)
               data.SetData(SD_INSTANCES,False)
               data.SetData(SD_DRAW_SPHERES,True)
          Is this incorrect?
            On 31/07/2012 at 20:17, xxxxxxxx wrote:
            It's incorrect as we are not recommended to use the basecontainer (.GetDataInstance()).
            What I mean by GUI elements is things like the Spline GUI, it is just the
            "background" that holds no values. It needs to get the values set as you can see
            in my example before.
            Your init should/could look:
                 node[c4d.SD_ON] = True
                 node[c4d.SD_USE_CHILDREN] = False
                 node[c4d.SD_NO_INTERPOLATE] = False
                 node[c4d.SD_INSTANCES] = False
                 node[c4d.SD_DRAW_SPHERES] = True
            ..given the ID's are in your res/str/.h files
            Lennart
              On 31/07/2012 at 20:18, xxxxxxxx wrote:
              Much simpler 🙂
              Thank you, Lennart.
