    Set Keys, Interpolation problems
    2 Posts 0 Posters 245 Views
      On 30/07/2012 at 12:25, xxxxxxxx wrote:
      Has anyone done a straight simple SetKeys Command using DescID(DescLevel)
      for the length of a scene without any issues in that the original
      keys interpolation is not messed up?
      (Basically baking parameters).
      What I thought was pretty straight forward have had me in a loop for
      a couple of days.
      Simple scenario, set regular key at frame 0 and another one at the end of scene
      using Linear interpolation in Project settings.
      Then run a set keys (Baking) command that that sets a key for each frame.
      The result for me is that the keys are -not- linear (following the original curve)
      but in a easein shape.
      Using three keys, the set keys are in a easein shape between existing original keys.
      Lennart
        On 31/07/2012 at 08:01, xxxxxxxx wrote:
        Apparently, for me, setting keys for each frame on the same track I'm
        reading from, does make the interpolation faulty.
        Setting keys for an object without tracks/keys, i.e. is driven by expressions,
        all work as it should.
        This was my intention (bake expression driven objects) but when trying to
        bake already key framed objects, I ran into this issue.
        I guess for those cases I need to work on some sort of copy.
        Lennart
